Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.0.8846
other
Host Machine Version
native Ubuntu 18.04
other
Hello there,
I’m trying to install KVM onto a Drive AGX Xaier to run multiple guest OSes.
Installing qemu, libvirt and all the other required packages via apt works fine. Performing several checks like the ones below indicate that hardware virtualization is not available which is needed for KVM:
$ egrep -c '(vmx|svm)' /proc/cpuinfo
0
$ sudo kvm-ok
INFO: /dev/kvm does not exist
HINT: sudo modprobe kvm
modprobe: FATAL: Module msr not found in directory /lib/modules/4.14.102-rt53-tegra
$ virt-host-validate
QEMU: Checking if device /dev/kvm exists : FAIL (Check that CPU and firmware supports virtualization and kvm module is loaded)
QEMU: Checking if device /dev/vhost-net exists : WARN (Load the 'vhost_net' module to improve performance of virtio networking)
QEMU: Checking if device /dev/net/tun exists : PASS
QEMU: Checking for cgroup 'memory' controller support : PASS
QEMU: Checking for cgroup 'memory' controller mount-point : PASS
QEMU: Checking for cgroup 'cpu' controller support : PASS
QEMU: Checking for cgroup 'cpu' controller mount-point : PASS
QEMU: Checking for cgroup 'cpuacct' controller support : PASS
QEMU: Checking for cgroup 'cpuacct' controller mount-point : PASS
QEMU: Checking for cgroup 'cpuset' controller support : PASS
QEMU: Checking for cgroup 'cpuset' controller mount-point : PASS
QEMU: Checking for cgroup 'devices' controller support : PASS
QEMU: Checking for cgroup 'devices' controller mount-point : PASS
QEMU: Checking for cgroup 'blkio' controller support : PASS
QEMU: Checking for cgroup 'blkio' controller mount-point : PASS
WARN (Unknown if this platform has IOMMU support)
LXC: Checking for Linux >= 2.6.26 : PASS
LXC: Checking for namespace ipc : PASS
LXC: Checking for namespace mnt : PASS
LXC: Checking for namespace pid : PASS
LXC: Checking for namespace uts : PASS
LXC: Checking for namespace net : PASS
LXC: Checking for namespace user : PASS
LXC: Checking for cgroup 'memory' controller support : PASS
LXC: Checking for cgroup 'memory' controller mount-point : PASS
LXC: Checking for cgroup 'cpu' controller support : PASS
LXC: Checking for cgroup 'cpu' controller mount-point : PASS
LXC: Checking for cgroup 'cpuacct' controller support : PASS
LXC: Checking for cgroup 'cpuacct' controller mount-point : PASS
LXC: Checking for cgroup 'cpuset' controller support : PASS
LXC: Checking for cgroup 'cpuset' controller mount-point : PASS
LXC: Checking for cgroup 'devices' controller support : PASS
LXC: Checking for cgroup 'devices' controller mount-point : PASS
LXC: Checking for cgroup 'blkio' controller support : PASS
LXC: Checking for cgroup 'blkio' controller mount-point : PASS
LXC: Checking if device /sys/fs/fuse/connections exists : FAIL (Load the 'fuse' module to enable /proc/ overrides)
I believe, however, that hardware virtualization is available on the AGX (please correct me if I’m wrong). Therefore my question is how to enable hardware virtualization on the Drive AGX?
Thanks for your help!
