Import problem in nvfortran 25.9
Hello! A file that used to be able to compile with nvfortran < 25.9 is failing now with 25.9 with the error code: NVFORTRAN-S-1257-Interface test_interface must be declared. (mre.f90)
Attached is an MRE with the fix I had to do. Essentially, the compiler seems to not be looking further down and needs specific import xyz to work. I don’t know if this is a compiler bug or a really strict enforcing of the standard :)
module td_mre
  implicit none
  private
  public :: run_testsuite, new_unittest, unittest_type
  public :: test_interface, collect_interface
  ! A simple error type in host scope
  type :: error_type
    integer :: stat = 0
    character(len=:), allocatable :: message
  end type error_type
  ! Abstract interface for tests; uses error_type from host via import
  abstract interface
    subroutine test_interface(error)
      import
      type(error_type), allocatable, intent(out) :: error
    end subroutine test_interface
  end interface
  ! Type that stores a procedure pointer with that interface
  type :: unittest_type
    character(len=:), allocatable :: name
    procedure(test_interface), pointer, nopass :: test => null()
  end type unittest_type
  public :: unittest_type
  ! Abstract interface that imports only unittest_type
  ! (missing: test_interface)  <-- this triggers S-1257 indirectly
  abstract interface
    subroutine collect_interface(testsuite)
      import :: unittest_type
      !works:
      !import :: unittest_type, test_interface
      type(unittest_type), allocatable, intent(out) :: testsuite(:)
    end subroutine collect_interface
  end interface
  public :: collect_interface
contains
  recursive subroutine run_testsuite(collect, unit, stat)
    procedure(collect_interface) :: collect   ! <-- NVFORTRAN-S-1257 here
    integer, intent(in)  :: unit
    integer, intent(out) :: stat
    type(unittest_type), allocatable :: tests(:)
    stat = 0
    call collect(tests)
  end subroutine run_testsuite
  function new_unittest(name, test) result(u)
    character(len=*), intent(in) :: name
    procedure(test_interface)    :: test
    type(unittest_type)          :: u
    u%name = name
    u%test => test
  end function new_unittest
end module td_mre
Hi jg4,
Thanks for the report and nice reproducer. I was able to recreate the error here and have filed a problem report, TPR #37894. I’ve asked engineer to investigate especially since this is a regression.
-Mat
