Also, please try to tell me what is the exact jetpack version that you think you are using… or which one do you want to use… I feel your flash is totally messed up …
i can try to download again the correct jetpack on my ubuntu. for a clean download is it sufficient to delete the already downloaded packages or are there some files that are hiddenly written on ubuntu?
i have a 128 GB SSD on my board, should i remove it?
ok, i have physically removed the ssd and now the GUI is started correctly without any problem.
in order to use the additional ssd is it possible to change the boot order and the format the ssd?
thank you very much for your informations
ok, thanks. now i’m evaluating if i need more space to install the packages, needing the use of ssd(in this case i’ll proceed with the procedure to boot from nvme), or if 16 gb are sufficient.
thank you very much for your help.
