I found troubling trying to use my GPU in Jetson Nano. I have tried both, Tensorflow and Pytorch installed from Nvidia Docs. The code is simple ‘Hello AI World’ type, in short no problem with it. However, when I run it, it stuck in training. And it does not move on anywhere and Jetson just does not operate, i.e. closing terminal or rebooting. Nevertheless, when I run on CPU mode, everything works just fine.
Things I tried:
Latest Jetpack and Tensorflow installed from Nvidia Docs.
Latest Jetpack and PyTorch installed from Nvidia Docs.
Latest Jetpack and downgraded PyTorch (1.7.0, 1.8.0)
Downgraded Jetpack and latest PyTorch…
In short, whatever I do, it is impossible to train on GPU.
I don’t know where problem is. Could this be due to Power supply? (Jetson is connected to USB cable and travel adapted charger with 9 V and 1.67 A or 5 V and 2.0 A output.)
However if your Nano isn’t turning itself off, then it should still be possible to run with lower amperage power supply (albeit more slowly). Can you keep an eye on the memory usage with tegrastats or jtop? Do you have swap mounted, like shown here?
