I have met power down when run pytorch transfer learning using Jetson nano.
Hi, All
code: Transfer Learning for Computer Vision Tutorial — PyTorch Tutorials 1.12.1+cu102 documentation
In that moment, memory is near to 2.2GB of total 3.87GB.
So, I think that is not memory problems, but power problems …
I’m using usb 5pin power.
Is that right ?
Thanks in advance …
Hi bemore, it is recommended to either use 4A DC barrel jack adapter power supply, or to change your Nano to 5W power mode with this command to avoid over-taxing your USB power supply:
$ sudo nvpmodel -m 1
