Would you give us to improve the precision with using OpenALPR data?
Here is our results.
Epoch 120/120
Validation cost: 0.000082
Mean average_precision (in %): 63.5910
class name average precision (in %)
lpd 63.591
• Hardware (T4/V100/Xavier/Nano/etc) : A100
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) : detectnet_v2
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here): v3.0-py3
• Training spec file(If have, please share here)
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/workspace/output/lpd/experiments/lpd_tfrecord/*"
image_directory_path: "/workspace/output/lpd/experiments/lpd/data/"
image_extension: "jpg"
target_class_mapping {
key: "lpd"
value: "lpd"
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 640
output_image_height: 480
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "lpd"
value {
clustering_config {
coverage_threshold: 0.00499999988824
dbscan_eps: 0.20000000298
dbscan_min_samples: 0.0500000007451
minimum_bounding_box_height: 4
model_config {
pretrained_model_file: "/workspace/output/lpd/experiments/pretrained/usa_unpruned.tlt"
num_layers: 18
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: "resnet"
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "lpd"
value: 0.699999988079
evaluation_box_config {
key: "lpd"
value {
minimum_height: 10
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 4
num_epochs: 120
enable_qat: False
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.10000000149
annealing: 0.699999988079
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
bbox_rasterizer_config {
key: "lpd"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.40000000596
cov_radius_y: 0.40000000596
bbox_min_radius: 1.0
deadzone_radius: 0.400000154972
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
It was just followed the way in NV blog.
$ cat SPECS_tfrecord.txt
kitti_config {
root_directory_path: "/workspace/output/lpd/experiments/lpd/data"
image_dir_name: "image"
label_dir_name: "label"
image_extension: ".jpg"
partition_mode: "random"
num_partitions: 2
val_split: 20
num_shards: 4
image_directory_path: "/workspace/output/lpd/experiments/lpd/data"
$ detectnet_v2 dataset_convert -d specs/SPECS_tfrecord.txt -o $LOCAL_EXPERIMENT_DIR/lpd_tfrecord/lpd
$ detectnet_v2 train -e specs/SPECS_train.txt -r $LOCAL_EXPERIMENT_DIR/exp_unpruned_epoch -k nvidia_tlt
Best reagrds.
Kaka
