Imx219 board setup failed and no video in /dev/videox directory
When I run , sudo dmesg | grep imx219 in jetson orin nx developer kit (jetpack 5.1.2) L4T 35.4.1
[ 13.851482] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 13.866853] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 13.882882] imx219 9-0010: board setup failed
[ 13.898506] imx219: probe of 9-0010 failed with error -121
[ 13.898792] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 13.923009] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 13.938725] imx219 10-0010: board setup failed
[ 13.945293] imx219: probe of 10-0010 failed with error -121
Then, ls /dev/videoX*
Do not have any videoX in dev directory , even device have connected with CSI camera.
Is that any driver hot the camera has to be installed ?
Kindly aid me to get solve this issue.
Moving this topic to the Jetson forums for visibility.
hello nexncommunication2023,
it’s reported failure for device registration.
are you using developer kits with Raspberry pi v2, imx219 camera module?
if yes, please try running Jetson-IO to Configure CSI Connector.
Hello JerryChang,
Thank you for your reply.
Am using imx219 camera module. I will try how to configure CSI connector and let you know.
Hi JerryChang,
Even after the configuration of CSI connector , There is no videox in /dev/videox directory.
could I know the reason for the below log board setup failed
it sometimes due to false hardware connection.
please check you’ve having correct pin direction of your flex ribbon cable.
Hello JerryChang ,
I had even checked the ribbon cable. Still this error persists.
kindly tell how could I solve this issue.
I also attached the output of contain the set of commands regarding camera module.
Error while connecting CSI camera to deepstream
deepstream-app -c source1_csi_dec_infer_resnet_int8.txt
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 No cameras available
nvstreammux: Successfully handled EOS for source_id=0
** INFO: <bus_callback:262>: Received EOS. Exiting …
v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
Cannot open device /dev/video0, exiting.
nvgstcapture-1.0
  • Message: 13:12:28.617: main:4734 iterating capture loop …
NvMMLiteOpen : Block : BlockType = 4
===== NvVideo: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
ERROR on bus: by /GstPipeline:capture_native_pipeline: Output window was closed
debug info:
/dvs/git/dirty/git-master_linux/tests-multimedia/nvgstapps/nvgstcapture-1.0/nvgstcapture.c(4159): nvgst_handle_xevents (): /GstPipeline:capture_native_pipeline
** Message: 13:12:43.725: main:4744 Capture completed
** Message: 13:12:43.759: main:4795 Camera application will now exit
sudo dmesg | grep -i camera
[ 6.949321] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.956092] gpio-486 (camera-control-output-low): hogged as output/low
[ 14.327037] input: UVC Camera (046d:0825) as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/input/input9
[10099.040213] input: UVC Camera (046d:0825) as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/input/input10
ls /dev/video*
v4l2-ctl -d2 -D
gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,width=1920,height=1080,framerate=65/1 ! fpsdisplaysink text-overlay=false video-sink=waylandsink sync=false -v
cat /proc/config.gz | gunzip | grep IMX
CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
CONFIG_VIDEO_IMX214 is not set
CONFIG_VIDEO_IMX219 is not set
CONFIG_VIDEO_IMX258 is not set
CONFIG_VIDEO_IMX274 is not set
CONFIG_VIDEO_IMX290 is not set
CONFIG_VIDEO_IMX319 is not set
CONFIG_VIDEO_IMX355 is not set
CONFIG_NV_VIDEO_IMX185=m
CONFIG_NV_VIDEO_IMX477=m
CONFIG_NV_VIDEO_IMX219=m
CONFIG_NV_VIDEO_IMX268=m
CONFIG_NV_VIDEO_IMX274=m
CONFIG_NV_VIDEO_IMX318=m
CONFIG_NV_VIDEO_IMX390=y
CONFIG_VIDEO_IMX204 is not set
CONFIG_SND_SOC_IMX_AUDMUX is not set
CONFIG_USB_CHIPIDEA_IMX=m
CONFIG_PHY_FSL_IMX8MQ_USB=y
cat /proc/device-tree/compatible
nvidia,p3768-0000+p3767-0000nvidia,p3767-0000nvidia,tegra234nvidia,tegra23x
cat /proc/device-tree/nvidia,dtbbuildtime
Aug 1 202312:44:16
let’s confirm you’re using Orin developer kits with Raspberry pi v2, imx219 camera module.
could you please share a picture of your device, thanks
Hello @JerryChang
I have attached the picture of the Nvidia Device with camera
Device Name : Nvidia Orin NX Developer Kit
Camera : UC-439 Model
How can I fix this problem? Is it HW prblm or CSI interface (Driver prblm)?
this is not Raspberry pi v2, imx219 camera module…
Okay ,If i change the camera module ,is it works ? because error occur as Board setup fails
And Can you mention any related IMX219 camera module ??
please see-also… https://jetsonhacks.com/2019/04/02/jetson-nano-raspberry-pi-camera/
I have attached another camera module named as p5vq4a sunny Raspberry Pi v2 ,can i use that camera module ?
it’s not plug-n-play, please apply kernel and device tree update to adapt the camera driver.
you may also contact with Jetson Partner Supported Cameras.
Hello JerryChang,
Could you please share any links to update kernel and device tree update to adapt the camera driver
you may read developer guide, Building the Kernel and Flashing a Specific Partition.
besides, you may consider using USB camera.
please see-also Camera Architecture Stack, you could bypass libargus, running with v4l2 interface to fetch the stream directly.
Hi JerryChang,
Thank you, I will definitely have gaze on the kink you have shared.
Even I do not have /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp .
Here my USB camera is working fine with my nvidia device. Connection of CSI camera with my nvidia is the actual problem.
sudo media-ctl -p -d /dev/media0
Media controller API version 5.10.120
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.10.120
Device topology
  • entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 0 link)
    type V4L2 subdev subtype Unknown flags 0
    pad0: Sink
    pad1: Source
  • entity 4: 13e40000.host1x:nvcsi@15a00000- (2 pads, 0 link)
    pad0: Sink
    pad1: Source
How do I know my camera name because I do not have any details related to the name of the camera
Hello JerryChang,
sudo dmesg | grep -i csi
[ 1.590670] SCSI subsystem initialized
[ 2.241210] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 6.982541] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.992169] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.998646] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.007866] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
CSI is passive. it’s simply send controls and waiting for sensor output streams to CSI channel.
please check your sensor is actually enabled and outputting MIPI signaling.
Hello JerryChang,
I will try.
