I have problem with run camera on Jetson Nano Devkit B01 with Jetpack 4.6-b197. When I try run camera:
gst-launch-1.0 nvarguscamerasrc sensor_id=1 ! nvoverlaysink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:725 No cameras available
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.011917509
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Log from dmesg.dmesg_jetpack_4_6.log (59.4 KB)
I run cameras on Jetpack 4.3 without any problem. What I must additiona do to run camera on Jetpack 4.6?
this looks strange, we had IMX219 on Jetson Nano with r32.6.1 release and it just works well.
may I know which camera module you’re using? is it Raspberry Pi Camera Module V2, IMX219?
Arducam B0179
The only thing I changed is modify gpio in device-tree and I added driver to touchscreen. But in logs from boot I don’t see any problem with I2C, so I think that it doesn’t influent for cameras.
could you please confirm with the vendor to understand the workable JetPack versions.
please also share the kernel init messages for reference, i.e. $ dmesg > klog.txt
Hello dmesg > klog.txt from workable Jetpack 4.3: klog.txt (57.1 KB)
I don’t understand why cameras don’t work on newest Jetpack 4.6. Do you have any idea?
please share kernel logs with non-workable combination.
you should also include some device tree changes since this is Arducam instead of default Raspberry Pi Camera Module V2, IMX219 modules,
I sent logs in first post from non-workable combination.
I use this tutorial to run camera: Jetson Nano B01 - Dual Raspberry Pi Cameras - JetsonHacks.
I didn’t change anything in device tree in Jetpack 4.3 so I think that in Jetpack 4.6 I shouldn’t change too. Unfortunately, the cameras still don’t work on Jetpack 4.6.
