IMX219 detected but not working on Jetson nano
I have a Jetson Nano Developer Kit, to which I am trying to connect the IMX219 camera. I have the camera module from two different vendors, one from Arducam (B0342) and one from WaveShare (IMX219-160). I have installed the latest Jetpack 4.6 on the micro SD card. I can detect the cameras using,
ls -l /dev/video*
to which the output is,
crw-rw----+ 1 root video 81, 0 Jan  7 07:09 /dev/video0
crw-rw----+ 1 root video 81, 3 Jan  7 07:09 /dev/video1
I can also do,
v4l2-ctl --list-devices
and get,
vi-output, imx219 7-0010 (platform:54080000.vi:0):
	/dev/video0
vi-output, imx219 8-0010 (platform:54080000.vi:4):
	/dev/video1
but when I try to read the video output using the below command,
gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! 'video/x raw(memory:NVMM),width=3264, height=2464, framerate=21/1, format=NV12' ! nvvidconv flip-method=2 ! 'video/x-raw, width=816, height=616' ! nvvidconv ! nvegltransform ! nveglglessink -e
I get the below error.
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 3264 H = 2464
   seconds to Run    = 0
   Frame Rate = 21.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
CONSUMER: ERROR OCCURRED
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Interrupt while waiting for EOS - stopping pipeline...
Execution ended after 0:00:04.969858150
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 2 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
I believe the important part of the error message is this section
Argus Error Status
Waiting for EOS...
I have seen a very similar post about the issue, but the solution proposed in that thread, doesn’t work for me, as I have the raspi v2 camera and I still get the same error. Below is the link to the post.
I’d deeply appreciate any comments/suggestions/questions.
We suggest try Raspberry Pi camera v2. The camera is supported by default. For other cameras, you would need to check with vendor for porting camera driver and device tree.
Thank you for the reply @DaneLLL . I actually did try the IMX219 camera module form Arducam (B0342). For some reason, it is not working. I also have two camera modules from Waveshare (IMX219-160), out of which one luckily worked today. Not sure if the other two are broken, or not just compatible with the JetPack 4.6 version, or maybe even a fault cable or CSI port combination on the Jetson Nano. In any case, I have one camera working now, which is great!
For others who stumble upon similar error, I’d suggest trying different cameras first. Marking this as the solution.
