CSI IMX219 is not working on Jetson Nano 2GB and Jetson Xavier nx
I am having Jetson Nano 2GB, Jetson Xavier nx, two CSI IMX 219 160FOV cameras. I am working on Jetbot project. Last night my both CSI cameras were working working. But today my both of the cameras are not working in any of my devices like Jetson Nano 2GB, Jetson Xavier nx. I do assure you that there is no hardware issues. I have also interchanged the wires and the ports but still not working. And also rebooted the system many times. And Have tried all the commands to make the camera work but it is still not working.
Please do let me know the solution as soon as possible its urgent.
While executing the commands it is showing:-
enord@enord:~$ nvgstcapture-1.0
Encoder null, cannot set bitrate!
Encoder Profile = High
Supported resolutions in case of ARGUS Camera
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Runtime ARGUS Camera Commands:
Help : ‘h’
Quit : ‘q’
Set Capture Mode:
mo:
(1): image
(2): video
Get Capture Mode:
gmo
Set sensor orientation:
so:
(0): none
(1): Rotate counter-clockwise 90 degrees
(2): Rotate 180 degrees
(3): Rotate clockwise 90 degrees
Get sensor orientation:
gso
Set sensor mode:
smo: e.g., smo:1
Get sensor mode:
gsmo
Set Whitebalance Mode:
wb:
(0): off
(1): auto
(2): incandescent
(3): fluorescent
(4): warm-fluorescent
(5): daylight
(6): cloudy-daylight
(7): twilight
(8): shade
(9): manual
Get Whitebalance Mode:
gwb
Set Saturation (0 to 2):
st: e.g., st:1.25
Get Saturation:
gst
Set Exposure Compensation (-2 to 2):
ec: e.g., ec:-2
Get Exposure Compensation:
gec
Set Auto Whitebalance Lock:
awbl: e.g., awbl:0
Get Auto Whitebalance Lock:
awbl
Set Auto Exposure Lock:
ael: e.g., ael:0
Get Auto Exposure Lock:
gael
Set TNR Mode:
tnrm: e.g., tnrm:1
(0): OFF
(1): FAST
(2): HIGH QUALITY
Get TNR Mode:
gtnrm
Set TNR Strength (-1 to 1):
tnrs: e.g., tnrs:0.5
Get TNR Strength:
gtnrs
Set EE Mode:
eem: e.g., eem:1
(0): OFF
(1): FAST
(2): HIGH QUALITY
Get EE Mode:
geem
Set EE Strength (-1 to 1):
ees: e.g., ees:0.5
Get EE Strength:
gees
Set Auto Exposure Anti-Banding (0 to 3):
aeab: e.g., aeab:2
(0): OFF
(1): MODE AUTO
(2): MODE 50HZ
(3): MODE 60HZ
Get Auto Exposure Anti-Banding:
gaeab
Set Gain Range:
gr: e.g., gr:1 16
Get Gain Range:
ggr
Set Exposure Time Range:
etr: e.g., etr:34000 35000
Get Exposure Time Range:
getr
Set ISP Digital Gain Range:
dgr: e.g., dgr:2 152
Get ISP Digital Gain Range:
gdgr
Capture: enter ‘j’ OR
followed by a timer (e.g., jx5000, capture after 5 seconds) OR
followed by multishot count (e.g., j:6, capture 6 images)
timer/multihot values are optional, capture defaults to single shot with timer=0s
Start Recording : enter ‘1’
Stop Recording : enter ‘0’
Video snapshot : enter ‘2’ (While recording video)
Get Preview Resolution:
gpcr
Get Image Capture Resolution:
gicr
Get Video Capture Resolution:
gvcr
Runtime encoder configuration options:
Set Encoding Bit-rate(in bytes):
br: e.g., br:4000000
Get Encoding Bit-rate(in bytes):
gbr
Set Encoding Profile(only for H.264):
ep: e.g., ep:1
(0): Baseline
(1): Main
(2): High
Get Encoding Profile(only for H.264):
gep
Force IDR Frame on video Encoder(only for H.264):
Enter ‘f’
bitrate = 4000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Opening in BLOCKING MODE
** Message: 18:50:01.400: main:4670 iterating capture loop …
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:645 No cameras available
(nvgstcapture-1.0:8164): GStreamer-CRITICAL : 18:50:01.456: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
^C
Message: 18:50:10.742: <_intr_handler:4261> User Interrupted…
Terminating the camera pipeline …
** Message: 18:50:11.147: main:4680 Capture completed
** Message: 18:50:11.147: main:4729 Camera application will now exit
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
Have a check if camera still probe without problem.
dmesg | grep -i imx219
v4l2-ctl --list-formats-ext
