As your advice, I have confirmed that the device tree port setting of NVCSI/VI is wrong and it is not receiving data input.
After modifying the NVCSI/VI port and executing the v4l2-ctrl command, an error message occurred during data reception as shown below.
[ 1091.781440] imx686 2-0010: imx686_start_streaming: start streaming
[ 1092.049825] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1092.056278] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1092.269849] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1092.276311] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1092.286389] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1092.294299] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
[ 1092.605839] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1092.612303] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1092.622322] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1092.630223] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
[ 1092.937912] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1092.944459] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1092.954542] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1092.954555] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
[ 1093.269817] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1093.276329] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1093.286377] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000008
[ 1093.294406] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000008
[ 1093.601788] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1093.608327] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1093.618999] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1093.626975] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
[ 1093.937793] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1093.944348] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1093.954590] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1093.962574] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
[ 1094.269820] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1094.276357] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1094.287115] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1094.295092] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
[ 1094.601872] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1094.608352] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1094.620424] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1094.628541] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
[ 1094.933972] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1094.940499] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1094.951419] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000008
[ 1094.959391] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000008
[ 1095.269847] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1095.276354] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1095.286979] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1095.294968] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
[ 1095.601829] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1095.608333] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1095.618912] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000008
[ 1095.626811] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000008
[ 1095.787547] tegra-vi4 15700000.vi: Status: 7 channel:00 frame:0047
[ 1095.794023] tegra-vi4 15700000.vi: timestamp sof 1104020815072 eof 1104075719840 data 0x00000001
[ 1095.803420] tegra-vi4 15700000.vi: capture_id 71 stream 2 vchan 0
[ 1095.877956] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
[ 1095.883646] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1095.893766] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1095.901630] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
[ 1095.941360] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERROR_STATUS2VI_VC0 = 0x00000004
[ 1095.950240] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) INTR_STATUS 0x00000004
[ 1095.958172] nvcsi 150c0000.nvcsi: csi4_stream_check_status (2) ERR_INTR_STATUS 0x00000004
When I check INTR_STATUS 0x00000004 in the manual, it says payload CRC error. In this case, what should I check?
here is trace log message.
root@livsmed-desktop:/home/livsmed# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 781/781 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/3:1-789 [003] .... 77.061569: rtos_queue_peek_from_isr_failed: tstamp:2666061364 queue:0x0b4b4500
kworker/3:1-789 [003] .... 77.229560: rtos_queue_peek_from_isr_failed: tstamp:2671061357 queue:0x0b4b4500
kworker/3:1-789 [003] .... 77.341569: rtos_queue_peek_from_isr_failed: tstamp:2676061350 queue:0x0b4b4500
kworker/3:1-789 [003] .... 77.509471: rtos_queue_peek_from_isr_failed: tstamp:2681061387 queue:0x0b4b4500
kworker/3:1-789 [003] .... 77.677504: rtos_queue_peek_from_isr_failed: tstamp:2686061375 queue:0x0b4b4500
kworker/3:1-789 [003] .... 77.845483: rtos_queue_peek_from_isr_failed: tstamp:2691061374 queue:0x0b4b4500
kworker/3:1-789 [003] .... 78.013499: rtos_queue_peek_from_isr_failed: tstamp:2696061387 queue:0x0b4b4500
kworker/3:1-789 [003] .... 78.181535: rtos_queue_peek_from_isr_failed: tstamp:2701061394 queue:0x0b4b4500
kworker/3:1-789 [003] .... 78.293573: rtos_queue_peek_from_isr_failed: tstamp:2706061400 queue:0x0b4b4500
kworker/3:1-789 [003] .... 78.461570: rtos_queue_peek_from_isr_failed: tstamp:2711061407 queue:0x0b4b4500
kworker/3:1-789 [003] .... 78.629586: rtos_queue_peek_from_isr_failed: tstamp:2716061412 queue:0x0b4b4500
kworker/3:1-789 [003] .... 78.797585: rtos_queue_peek_from_isr_failed: tstamp:2721061445 queue:0x0b4b4500
kworker/3:1-789 [003] .... 78.965558: rtos_queue_peek_from_isr_failed: tstamp:2726061421 queue:0x0b4b4500
kworker/3:1-789 [003] .... 79.133602: rtos_queue_peek_from_isr_failed: tstamp:2731061434 queue:0x0b4b4500
kworker/3:1-789 [003] .... 79.301663: rtos_queue_peek_from_isr_failed: tstamp:2736061432 queue:0x0b4b4500
kworker/3:1-789 [003] .... 79.413573: rtos_queue_peek_from_isr_failed: tstamp:2741061457 queue:0x0b4b4500
kworker/3:1-789 [003] .... 79.585622: rtos_queue_peek_from_isr_failed: tstamp:2746061446 queue:0x0b4b4500
kworker/3:1-789 [003] .... 79.753616: rtos_queue_peek_from_isr_failed: tstamp:2751061463 queue:0x0b4b4500
kworker/3:1-789 [003] .... 79.921641: rtos_queue_peek_from_isr_failed: tstamp:2756061476 queue:0x0b4b4500
kworker/3:1-789 [003] .... 80.089583: rtos_queue_peek_from_isr_failed: tstamp:2761061467 queue:0x0b4b4500
kworker/3:1-789 [003] .... 80.257664: rtos_queue_peek_from_isr_failed: tstamp:2766061473 queue:0x0b4b4500
kworker/3:1-789 [003] .... 80.429587: rtos_queue_peek_from_isr_failed: tstamp:2771061488 queue:0x0b4b4500
kworker/3:1-789 [003] .... 80.541728: rtos_queue_peek_from_isr_failed: tstamp:2776061513 queue:0x0b4b4500
kworker/3:1-789 [003] .... 80.709655: rtos_queue_peek_from_isr_failed: tstamp:2781061495 queue:0x0b4b4500
kworker/3:1-789 [003] .... 80.877617: rtos_queue_peek_from_isr_failed: tstamp:2786061500 queue:0x0b4b4500
kworker/3:1-789 [003] .... 80.989609: rtos_queue_peek_from_isr_failed: tstamp:2789687934 queue:0x0b4b4500
v4l2-ctl-8301 [000] .... 86.311889: tegra_channel_open: vi-output, imx686 2-0010
v4l2-ctl-8301 [004] .... 86.313467: tegra_channel_set_power: imx686 2-0010 : 0x1
v4l2-ctl-8301 [004] .... 86.313478: camera_common_s_power: status : 0x1
v4l2-ctl-8301 [000] .... 86.332952: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-8301 [000] .... 86.332962: csi_s_power: enable : 0x1
v4l2-ctl-8301 [005] .... 86.373568: tegra_channel_capture_setup: vnc_id 0 W 4624 H 3472 fmt 20
kworker/3:1-789 [003] .... 86.373829: rtos_queue_peek_from_isr_failed: tstamp:2958536459 queue:0x0b4b4500
kworker/3:1-789 [003] .... 86.373837: rtcpu_start: tstamp:2958538458
kworker/3:1-789 [003] .... 86.373841: rtos_queue_send_from_isr_failed: tstamp:2958549970 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.373844: rtos_queue_send_from_isr_failed: tstamp:2958550080 queue:0x0b4aad68
kworker/3:1-789 [003] .... 86.373846: rtos_queue_send_from_isr_failed: tstamp:2958550187 queue:0x0b4ac998
kworker/3:1-789 [003] .... 86.373848: rtos_queue_send_from_isr_failed: tstamp:2958550296 queue:0x0b4ae518
kworker/3:1-789 [003] .... 86.373850: rtos_queue_send_from_isr_failed: tstamp:2958550401 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 86.373853: rtos_queue_send_from_isr_failed: tstamp:2958550506 queue:0x0b4b0098
kworker/3:1-789 [003] .... 86.373855: rtos_queue_send_from_isr_failed: tstamp:2958550611 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 86.373857: rtos_queue_send_from_isr_failed: tstamp:2958550716 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 86.373861: rtos_queue_send_failed: tstamp:2958551177 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.373863: rtos_queue_send_from_isr_failed: tstamp:2958556648 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.373865: rtos_queue_send_from_isr_failed: tstamp:2958556765 queue:0x0b4aad68
kworker/3:1-789 [003] .... 86.373867: rtos_queue_send_from_isr_failed: tstamp:2958556871 queue:0x0b4ac998
kworker/3:1-789 [003] .... 86.373869: rtos_queue_send_from_isr_failed: tstamp:2958556979 queue:0x0b4ae518
kworker/3:1-789 [003] .... 86.373872: rtos_queue_send_from_isr_failed: tstamp:2958557084 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 86.373874: rtos_queue_send_from_isr_failed: tstamp:2958557189 queue:0x0b4b0098
kworker/3:1-789 [003] .... 86.373876: rtos_queue_send_from_isr_failed: tstamp:2958557294 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 86.373878: rtos_queue_send_from_isr_failed: tstamp:2958557409 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 86.373880: rtos_queue_send_failed: tstamp:2958558364 queue:0x0b4a7258
vi-output, imx6-8302 [003] .... 86.374002: tegra_channel_set_stream: enable : 0x1
vi-output, imx6-8302 [005] .... 86.378580: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, imx6-8302 [005] .... 86.378582: csi_s_stream: enable : 0x1
vi-output, imx6-8302 [005] .... 86.378618: tegra_channel_set_stream: imx686 2-0010 : 0x1
kworker/3:1-789 [003] .... 86.542159: rtos_queue_peek_from_isr_failed: tstamp:2963536810 queue:0x0b4b4500
vi-output, imx6-8302 [004] .... 86.563117: tegra_channel_capture_frame: sof:86.453240238
kworker/3:1-789 [003] .... 86.597830: rtcpu_vinotify_event: tstamp:2964478094 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:2964477713 data:0x00000000
kworker/3:1-789 [003] .... 86.597837: rtcpu_vinotify_event: tstamp:2964481036 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:2964480673 data:0x00000001
kworker/3:1-789 [003] .... 86.597839: rtcpu_vinotify_event: tstamp:2964486933 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:1 vi_tstamp:2964486573 data:0x08000000
kworker/3:1-789 [003] .... 86.653816: rtcpu_vinotify_event: tstamp:2966197074 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:1 vi_tstamp:2966196447 data:0x00000001
kworker/3:1-789 [003] .... 86.653822: rtcpu_vinotify_event: tstamp:2966197299 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:2966196448 data:0x00000000
kworker/3:1-789 [003] .... 86.709817: rtos_queue_peek_from_isr_failed: tstamp:2968536816 queue:0x0b4b4500
vi-output, imx6-8302 [004] .... 86.782549: tegra_channel_capture_setup: vnc_id 0 W 4624 H 3472 fmt 20
vi-output, imx6-8302 [004] .... 86.782582: tegra_channel_capture_frame: sof:86.453240238
vi-output, imx6-8302 [005] .... 86.785032: tegra_channel_capture_frame: sof:86.675258885
kworker/3:1-789 [003] .... 86.821825: rtos_queue_send_from_isr_failed: tstamp:2971324308 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.821831: rtos_queue_send_from_isr_failed: tstamp:2971324430 queue:0x0b4aad68
kworker/3:1-789 [003] .... 86.821834: rtos_queue_send_from_isr_failed: tstamp:2971324548 queue:0x0b4ac998
kworker/3:1-789 [003] .... 86.821836: rtos_queue_send_from_isr_failed: tstamp:2971324666 queue:0x0b4ae518
kworker/3:1-789 [003] .... 86.821838: rtos_queue_send_from_isr_failed: tstamp:2971324783 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 86.821840: rtos_queue_send_from_isr_failed: tstamp:2971324900 queue:0x0b4b0098
kworker/3:1-789 [003] .... 86.821843: rtos_queue_send_from_isr_failed: tstamp:2971325016 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 86.821845: rtos_queue_send_from_isr_failed: tstamp:2971325136 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 86.821849: rtos_queue_send_failed: tstamp:2971325744 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.821851: rtos_queue_send_from_isr_failed: tstamp:2971330296 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.821853: rtos_queue_send_from_isr_failed: tstamp:2971330416 queue:0x0b4aad68
kworker/3:1-789 [003] .... 86.821856: rtos_queue_send_from_isr_failed: tstamp:2971330534 queue:0x0b4ac998
kworker/3:1-789 [003] .... 86.821858: rtos_queue_send_from_isr_failed: tstamp:2971330653 queue:0x0b4ae518
kworker/3:1-789 [003] .... 86.821860: rtos_queue_send_from_isr_failed: tstamp:2971330772 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 86.821863: rtos_queue_send_from_isr_failed: tstamp:2971330890 queue:0x0b4b0098
kworker/3:1-789 [003] .... 86.821865: rtos_queue_send_from_isr_failed: tstamp:2971331007 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 86.821867: rtos_queue_send_from_isr_failed: tstamp:2971331125 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 86.821870: rtos_queue_send_failed: tstamp:2971331605 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.821872: rtos_queue_send_from_isr_failed: tstamp:2971336330 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.821874: rtos_queue_send_from_isr_failed: tstamp:2971336448 queue:0x0b4aad68
kworker/3:1-789 [003] .... 86.821876: rtos_queue_send_from_isr_failed: tstamp:2971336566 queue:0x0b4ac998
kworker/3:1-789 [003] .... 86.821879: rtos_queue_send_from_isr_failed: tstamp:2971336684 queue:0x0b4ae518
kworker/3:1-789 [003] .... 86.821881: rtos_queue_send_from_isr_failed: tstamp:2971336801 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 86.821883: rtos_queue_send_from_isr_failed: tstamp:2971336933 queue:0x0b4b0098
kworker/3:1-789 [003] .... 86.821886: rtos_queue_send_from_isr_failed: tstamp:2971337056 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 86.821888: rtos_queue_send_from_isr_failed: tstamp:2971337173 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 86.821890: rtos_queue_send_failed: tstamp:2971337672 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.821892: rtos_queue_send_from_isr_failed: tstamp:2971339655 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.821895: rtos_queue_send_from_isr_failed: tstamp:2971339773 queue:0x0b4aad68
kworker/3:1-789 [003] .... 86.821897: rtos_queue_send_from_isr_failed: tstamp:2971339906 queue:0x0b4ac998
kworker/3:1-789 [003] .... 86.821899: rtos_queue_send_from_isr_failed: tstamp:2971340024 queue:0x0b4ae518
kworker/3:1-789 [003] .... 86.821901: rtos_queue_send_from_isr_failed: tstamp:2971340145 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 86.821904: rtos_queue_send_from_isr_failed: tstamp:2971340261 queue:0x0b4b0098
kworker/3:1-789 [003] .... 86.821906: rtos_queue_send_from_isr_failed: tstamp:2971340378 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 86.821908: rtos_queue_send_from_isr_failed: tstamp:2971340493 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 86.821910: rtos_queue_send_failed: tstamp:2971341650 queue:0x0b4a7258
kworker/3:1-789 [003] .... 86.821914: rtcpu_vinotify_event: tstamp:2971416356 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:2971415964 data:0x00000000
kworker/3:1-789 [003] .... 86.821917: rtcpu_vinotify_event: tstamp:2971419287 tag:CHANSEL_PXL_SOF channel:0x00 frame:5 vi_tstamp:2971418924 data:0x00000001
kworker/3:1-789 [003] .... 86.821919: rtcpu_vinotify_event: tstamp:2971421612 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:5 vi_tstamp:2971421253 data:0x08000000
kworker/3:1-789 [003] .... 86.877863: rtcpu_vinotify_event: tstamp:2973135282 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:5 vi_tstamp:2973134699 data:0x00000001
kworker/3:1-789 [003] .... 86.877871: rtcpu_vinotify_event: tstamp:2973135510 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:2973134700 data:0x00000000
kworker/3:1-789 [003] .... 86.877877: rtos_queue_peek_from_isr_failed: tstamp:2973536841 queue:0x0b4b4500
vi-output, imx6-8302 [005] .... 87.019306: tegra_channel_capture_setup: vnc_id 0 W 4624 H 3472 fmt 20
vi-output, imx6-8302 [005] .... 87.019343: tegra_channel_capture_frame: sof:86.675258885
kworker/3:1-789 [003] .... 87.045940: rtos_queue_send_from_isr_failed: tstamp:2978204671 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.045949: rtos_queue_send_from_isr_failed: tstamp:2978204794 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.045952: rtos_queue_send_from_isr_failed: tstamp:2978204913 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.045954: rtos_queue_send_from_isr_failed: tstamp:2978205031 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.045957: rtos_queue_send_from_isr_failed: tstamp:2978205148 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.045959: rtos_queue_send_from_isr_failed: tstamp:2978205263 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.045962: rtos_queue_send_from_isr_failed: tstamp:2978205380 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.045964: rtos_queue_send_from_isr_failed: tstamp:2978205495 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.045968: rtos_queue_send_failed: tstamp:2978206119 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.045970: rtos_queue_send_from_isr_failed: tstamp:2978209982 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.045973: rtos_queue_send_from_isr_failed: tstamp:2978210100 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.045975: rtos_queue_send_from_isr_failed: tstamp:2978210218 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.045977: rtos_queue_send_from_isr_failed: tstamp:2978210337 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.045980: rtos_queue_send_from_isr_failed: tstamp:2978210458 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.045982: rtos_queue_send_from_isr_failed: tstamp:2978210578 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.045984: rtos_queue_send_from_isr_failed: tstamp:2978210695 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.045986: rtos_queue_send_from_isr_failed: tstamp:2978210810 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.045989: rtos_queue_send_failed: tstamp:2978211315 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.045992: rtos_queue_peek_from_isr_failed: tstamp:2978536839 queue:0x0b4b4500
kworker/3:1-789 [003] .... 87.045995: rtos_queue_send_from_isr_failed: tstamp:2978734199 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.045997: rtos_queue_send_from_isr_failed: tstamp:2978734321 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.045999: rtos_queue_send_from_isr_failed: tstamp:2978734440 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.046002: rtos_queue_send_from_isr_failed: tstamp:2978734558 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.046004: rtos_queue_send_from_isr_failed: tstamp:2978734675 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.046006: rtos_queue_send_from_isr_failed: tstamp:2978734790 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.046009: rtos_queue_send_from_isr_failed: tstamp:2978734907 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.046011: rtos_queue_send_from_isr_failed: tstamp:2978735025 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.046013: rtos_queue_send_failed: tstamp:2978735549 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.046016: rtos_queue_send_from_isr_failed: tstamp:2978737994 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.046018: rtos_queue_send_from_isr_failed: tstamp:2978738128 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.046020: rtos_queue_send_from_isr_failed: tstamp:2978738248 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.046022: rtos_queue_send_from_isr_failed: tstamp:2978738366 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.046025: rtos_queue_send_from_isr_failed: tstamp:2978738484 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.046027: rtos_queue_send_from_isr_failed: tstamp:2978738600 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.046029: rtos_queue_send_from_isr_failed: tstamp:2978738718 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.046031: rtos_queue_send_from_isr_failed: tstamp:2978738836 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.046034: rtos_queue_send_failed: tstamp:2978739957 queue:0x0b4a7258
vi-output, imx6-8302 [005] .... 87.062137: tegra_channel_capture_frame: sof:86.952277329
kworker/3:1-789 [003] .... 87.101825: rtcpu_vinotify_event: tstamp:2980073400 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:2980073019 data:0x00000000
kworker/3:1-789 [003] .... 87.101831: rtcpu_vinotify_event: tstamp:2980076316 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:2980075952 data:0x00000001
kworker/3:1-789 [003] .... 87.101834: rtcpu_vinotify_event: tstamp:2980081360 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:10 vi_tstamp:2980081001 data:0x08000000
vi-output, imx6-8302 [005] .... 87.118130: tegra_channel_capture_frame: sof:87.8288529
kworker/3:1-789 [003] .... 87.157842: rtcpu_vinotify_event: tstamp:2981790879 tag:CHANSEL_PXL_EOF channel:0x00 frame:10 vi_tstamp:2981790210 data:0x0d8f0002
kworker/3:1-789 [003] .... 87.157849: rtcpu_vinotify_event: tstamp:2981791021 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:2981790249 data:0x00000000
kworker/3:1-789 [003] .... 87.157852: rtcpu_vinotify_event: tstamp:2981823716 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:2981823342 data:0x00000000
kworker/3:1-789 [003] .... 87.157854: rtcpu_vinotify_event: tstamp:2981826661 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:2981826302 data:0x00000001
kworker/3:1-789 [003] .... 87.157856: rtcpu_vinotify_event: tstamp:2981831110 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:11 vi_tstamp:2981830744 data:0x08000000
kworker/3:1-789 [003] .... 87.213838: rtos_queue_peek_from_isr_failed: tstamp:2983536863 queue:0x0b4b4500
kworker/3:1-789 [003] .... 87.213844: rtcpu_vinotify_event: tstamp:2983542644 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:11 vi_tstamp:2983542076 data:0x00000001
kworker/3:1-789 [003] .... 87.213846: rtcpu_vinotify_event: tstamp:2983542858 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:2983542077 data:0x00000000
vi-output, imx6-8302 [005] .... 87.354896: tegra_channel_capture_setup: vnc_id 0 W 4624 H 3472 fmt 20
vi-output, imx6-8302 [005] .... 87.354939: tegra_channel_capture_frame: sof:87.8288529
kworker/3:1-789 [003] .... 87.381862: rtos_queue_peek_from_isr_failed: tstamp:2988536845 queue:0x0b4b4500
kworker/3:1-789 [003] .... 87.381871: rtos_queue_send_from_isr_failed: tstamp:2988700797 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.381873: rtos_queue_send_from_isr_failed: tstamp:2988700920 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.381875: rtos_queue_send_from_isr_failed: tstamp:2988701055 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.381877: rtos_queue_send_from_isr_failed: tstamp:2988701173 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.381879: rtos_queue_send_from_isr_failed: tstamp:2988701289 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.381880: rtos_queue_send_from_isr_failed: tstamp:2988701405 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.381882: rtos_queue_send_from_isr_failed: tstamp:2988701520 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.381884: rtos_queue_send_from_isr_failed: tstamp:2988701637 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.381887: rtos_queue_send_failed: tstamp:2988702252 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.381888: rtos_queue_send_from_isr_failed: tstamp:2988707624 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.381890: rtos_queue_send_from_isr_failed: tstamp:2988707742 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.381892: rtos_queue_send_from_isr_failed: tstamp:2988707858 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.381894: rtos_queue_send_from_isr_failed: tstamp:2988707976 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.381895: rtos_queue_send_from_isr_failed: tstamp:2988708096 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.381897: rtos_queue_send_from_isr_failed: tstamp:2988708211 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.381899: rtos_queue_send_from_isr_failed: tstamp:2988708328 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.381900: rtos_queue_send_from_isr_failed: tstamp:2988708446 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.381902: rtos_queue_send_failed: tstamp:2988708920 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.381904: rtos_queue_send_from_isr_failed: tstamp:2989221948 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.381905: rtos_queue_send_from_isr_failed: tstamp:2989222069 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.381907: rtos_queue_send_from_isr_failed: tstamp:2989222187 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.381909: rtos_queue_send_from_isr_failed: tstamp:2989222306 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.381910: rtos_queue_send_from_isr_failed: tstamp:2989222423 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.381912: rtos_queue_send_from_isr_failed: tstamp:2989222540 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.381914: rtos_queue_send_from_isr_failed: tstamp:2989222655 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.381915: rtos_queue_send_from_isr_failed: tstamp:2989222770 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.381917: rtos_queue_send_failed: tstamp:2989223281 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.381919: rtos_queue_send_from_isr_failed: tstamp:2989225536 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.381920: rtos_queue_send_from_isr_failed: tstamp:2989225656 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.381922: rtos_queue_send_from_isr_failed: tstamp:2989225777 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.381924: rtos_queue_send_from_isr_failed: tstamp:2989225895 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.381925: rtos_queue_send_from_isr_failed: tstamp:2989226012 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.381927: rtos_queue_send_from_isr_failed: tstamp:2989226130 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.381929: rtos_queue_send_from_isr_failed: tstamp:2989226248 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.381930: rtos_queue_send_from_isr_failed: tstamp:2989226365 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.381932: rtos_queue_send_failed: tstamp:2989227474 queue:0x0b4a7258
vi-output, imx6-8302 [000] .... 87.395180: tegra_channel_capture_frame: sof:87.285305558
kworker/3:1-789 [003] .... 87.437845: rtcpu_vinotify_event: tstamp:2990480781 tag:ATOMP_FS channel:0x00 frame:16 vi_tstamp:2990480396 data:0x00000000
kworker/3:1-789 [003] .... 87.437852: rtcpu_vinotify_event: tstamp:2990483696 tag:CHANSEL_PXL_SOF channel:0x00 frame:16 vi_tstamp:2990483328 data:0x00000001
kworker/3:1-789 [003] .... 87.437854: rtcpu_vinotify_event: tstamp:2990490561 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:16 vi_tstamp:2990490195 data:0x08000000
vi-output, imx6-8302 [005] .... 87.451202: tegra_channel_capture_frame: sof:87.341316790
kworker/3:1-789 [003] .... 87.493843: rtcpu_vinotify_event: tstamp:2992198250 tag:CHANSEL_PXL_EOF channel:0x00 frame:16 vi_tstamp:2992197588 data:0x0d8f0002
kworker/3:1-789 [003] .... 87.493848: rtcpu_vinotify_event: tstamp:2992198393 tag:ATOMP_FE channel:0x00 frame:16 vi_tstamp:2992197626 data:0x00000000
kworker/3:1-789 [003] .... 87.493850: rtcpu_vinotify_event: tstamp:2992231091 tag:ATOMP_FS channel:0x00 frame:17 vi_tstamp:2992230719 data:0x00000000
kworker/3:1-789 [003] .... 87.493852: rtcpu_vinotify_event: tstamp:2992234038 tag:CHANSEL_PXL_SOF channel:0x00 frame:17 vi_tstamp:2992233679 data:0x00000001
kworker/3:1-789 [003] .... 87.493854: rtcpu_vinotify_event: tstamp:2992239601 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:17 vi_tstamp:2992239240 data:0x08000000
kworker/3:1-789 [003] .... 87.493858: rtos_queue_peek_from_isr_failed: tstamp:2993536864 queue:0x0b4b4500
kworker/3:1-789 [003] .... 87.549852: rtcpu_vinotify_event: tstamp:2993950030 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:17 vi_tstamp:2993949455 data:0x00000001
kworker/3:1-789 [003] .... 87.549859: rtcpu_vinotify_event: tstamp:2993950247 tag:ATOMP_FE channel:0x00 frame:17 vi_tstamp:2993949455 data:0x00000000
kworker/3:1-789 [003] .... 87.665765: rtos_queue_peek_from_isr_failed: tstamp:2998536866 queue:0x0b4b4500
vi-output, imx6-8302 [005] .... 87.686987: tegra_channel_capture_setup: vnc_id 0 W 4624 H 3472 fmt 20
vi-output, imx6-8302 [005] .... 87.687030: tegra_channel_capture_frame: sof:87.341316790
kworker/3:1-789 [003] .... 87.717894: rtos_queue_send_from_isr_failed: tstamp:2999077728 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.717902: rtos_queue_send_from_isr_failed: tstamp:2999077851 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.717905: rtos_queue_send_from_isr_failed: tstamp:2999077971 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.717907: rtos_queue_send_from_isr_failed: tstamp:2999078090 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.717910: rtos_queue_send_from_isr_failed: tstamp:2999078207 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.717912: rtos_queue_send_from_isr_failed: tstamp:2999078322 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.717915: rtos_queue_send_from_isr_failed: tstamp:2999078439 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.717917: rtos_queue_send_from_isr_failed: tstamp:2999078555 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.717921: rtos_queue_send_failed: tstamp:2999079194 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.717923: rtos_queue_send_from_isr_failed: tstamp:2999082649 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.717925: rtos_queue_send_from_isr_failed: tstamp:2999082767 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.717928: rtos_queue_send_from_isr_failed: tstamp:2999082885 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.717930: rtos_queue_send_from_isr_failed: tstamp:2999083003 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.717932: rtos_queue_send_from_isr_failed: tstamp:2999083126 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.717934: rtos_queue_send_from_isr_failed: tstamp:2999083243 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.717937: rtos_queue_send_from_isr_failed: tstamp:2999083360 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.717939: rtos_queue_send_from_isr_failed: tstamp:2999083475 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.717941: rtos_queue_send_failed: tstamp:2999083969 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.717944: rtos_queue_send_from_isr_failed: tstamp:2999600266 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.717946: rtos_queue_send_from_isr_failed: tstamp:2999600387 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.717948: rtos_queue_send_from_isr_failed: tstamp:2999600506 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.717950: rtos_queue_send_from_isr_failed: tstamp:2999600625 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.717953: rtos_queue_send_from_isr_failed: tstamp:2999600742 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.717955: rtos_queue_send_from_isr_failed: tstamp:2999600860 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.717957: rtos_queue_send_from_isr_failed: tstamp:2999600978 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.717960: rtos_queue_send_from_isr_failed: tstamp:2999601095 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.717962: rtos_queue_send_failed: tstamp:2999601600 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.717964: rtos_queue_send_from_isr_failed: tstamp:2999603724 queue:0x0b4a7258
kworker/3:1-789 [003] .... 87.717966: rtos_queue_send_from_isr_failed: tstamp:2999603845 queue:0x0b4aad68
kworker/3:1-789 [003] .... 87.717969: rtos_queue_send_from_isr_failed: tstamp:2999603965 queue:0x0b4ac998
kworker/3:1-789 [003] .... 87.717971: rtos_queue_send_from_isr_failed: tstamp:2999604083 queue:0x0b4ae518
kworker/3:1-789 [003] .... 87.717973: rtos_queue_send_from_isr_failed: tstamp:2999604200 queue:0x0b4af2d8
kworker/3:1-789 [003] .... 87.717975: rtos_queue_send_from_isr_failed: tstamp:2999604317 queue:0x0b4b0098
kworker/3:1-789 [003] .... 87.717977: rtos_queue_send_from_isr_failed: tstamp:2999604436 queue:0x0b4b0e58
kworker/3:1-789 [003] .... 87.717980: rtos_queue_send_from_isr_failed: tstamp:2999604557 queue:0x0b4b1c18
kworker/3:1-789 [003] .... 87.717982: rtos_queue_send_failed: tstamp:2999605647 queue:0x0b4a7258
vi-output, imx6-8302 [005] .... 87.728186: tegra_channel_capture_frame: sof:87.618334200
kworker/3:1-789 [003] .... 87.773965: rtcpu_vinotify_event: tstamp:3000888156 tag:ATOMP_FS channel:0x00 frame:22 vi_tstamp:3000887774 data:0x00000000
kworker/3:1-789 [003] .... 87.773972: rtcpu_vinotify_event: tstamp:3000891071 tag:CHANSEL_PXL_SOF channel:0x00 frame:22 vi_tstamp:3000890706 data:0x00000001
kworker/3:1-789 [003] .... 87.773974: rtcpu_vinotify_event: tstamp:3000895349 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:22 vi_tstamp:3000894989 data:0x08000000
vi-output, imx6-8302 [005] .... 87.784212: tegra_channel_capture_frame: sof:87.674345432
kworker/3:1-789 [003] .... 87.829926: rtcpu_vinotify_event: tstamp:3002605632 tag:CHANSEL_PXL_EOF channel:0x00 frame:22 vi_tstamp:3002604965 data:0x0d8f0002
kworker/3:1-789 [003] .... 87.829932: rtcpu_vinotify_event: tstamp:3002605770 tag:ATOMP_FE channel:0x00 frame:22 vi_tstamp:3002605004 data:0x00000000
kworker/3:1-789 [003] .... 87.829934: rtcpu_vinotify_event: tstamp:3002638471 tag:ATOMP_FS channel:0x00 frame:23 vi_tstamp:3002638097 data:0x00000000
kworker/3:1-789 [003] .... 87.829936: rtcpu_vinotify_event: tstamp:3002641416 tag:CHANSEL_PXL_SOF channel:0x00 frame:23 vi_tstamp:3002641057 data:0x00000001
kworker/3:1-789 [003] .... 87.829938: rtcpu_vinotify_event: tstamp:3002646174 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:23 vi_tstamp:3002645814 data:0x08000000
kworker/3:1-789 [003] .... 87.829943: rtos_queue_peek_from_isr_failed: tstamp:3003536902 queue:0x0b4b4500
kworker/3:1-789 [003] .... 87.885910: rtcpu_vinotify_event: tstamp:3004357415 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:23 vi_tstamp:3004356832 data:0x00000001
kworker/3:1-789 [003] .... 87.885916: rtcpu_vinotify_event: tstamp:3004357640 tag:ATOMP_FE channel:0x00 frame:23 vi_tstamp:3004356832 data:0x00000000
kworker/3:1-789 [003] .... 87.997924: rtos_queue_peek_from_isr_failed: tstamp:3008536870 queue:0x0b4b4500
vi-output, imx6-8302 [005] .... 88.021277: tegra_channel_capture_setup: vnc_id 0 W 4624 H 3472 fmt 20
vi-output, imx6-8302 [005] .... 88.021326: tegra_channel_capture_frame: sof:87.674345432
What if all the test packets are received, but an error occurs in the middle of transmission?
