engine = trt.utils.uff_to_trt_engine(G_LOGGER,
uff_model,
parser,
1,
1 << 20)
my model is vgg16
in this tutorial
uff_model,
parser,
1,
1 << 20)
my model is vgg16
in this tutorial
We can launch TensorRT engine with the VGG16 model you mentioned successfully.
Here is our source code for your reference:
import tensorflow as tf
import tensorrt as trt
import numpy as np
import uff
from tensorrt.parsers import uffparser
MAX_WORKSPACE = 1 << 20
MAX_BATCHSIZE = 1
G_LOGGER = trt.infer.ConsoleLogger(trt.infer.LogSeverity.INFO)
class vgg16:
if __name__ == '__main__':
sess = tf.Session()
imgs = tf.placeholder(tf.float32, [None, 224, 224, 3])
vgg = vgg16(imgs, None, sess)
sess.run(tf.global_variables_initializer())
graphdef = tf.get_default_graph().as_graph_def()
frozen_graph = tf.graph_util.convert_variables_to_constants(sess, graphdef, ['Softmax'])
tf_model = tf.graph_util.remove_training_nodes(frozen_graph)
uff_model = uff.from_tensorflow(tf_model, ["Softmax"])
parser = uffparser.create_uff_parser()
parser.register_input("Placeholder", (3, 224, 224), 0)
parser.register_output('Softmax')
uff_model,
parser,
MAX_BATCHSIZE,
MAX_WORKSPACE)
on the following line
uff_model,
parser,
MAX_BATCHSIZE,
MAX_WORKSPACE)
/usr/lib/python3.5/dist-packages/tensorrt/utils/_utils.py in uff_to_trt_engine(logger, stream, parser, max_batch_size, max_workspace_size, datatype, plugin_factory, calibrator)
185 parser_result = parser.parse(stream, network, datatype)
→ 186 assert(parser_result)
187 except AssertionError:
AssertionError:
During handling of the above exception, another exception occurred:
AssertionError Traceback (most recent call last)
in ()
19 parser,
20 MAX_BATCHSIZE,
—> 21 MAX_WORKSPACE)
192 filename, line, func, text = tb_info[-1]
193
→ 194 raise AssertionError(‘UFF parsing failed on line {} in statement {}’.format(line, text))
195
196
AssertionError: UFF parsing failed on line 186 in statement assert(parser_result)
i got this error
It’s not easy for us to handle issue without detail information.
Could you share a complete sample code for this assertion with us?
ok thank you for your reply
this my model
import numpy as np
from scipy.misc import imread, imresize
from imagenet_classes import class_names
import numpy as np
import uff
MAX_BATCHSIZE = 1
class vgg16:
def __init__(self, imgs, weights=None, sess=None):
self.imgs = imgs
self.convlayers()
self.fc_layers()
self.probs = tf.nn.softmax(self.fc3l)
if weights is not None and sess is not None:
self.load_weights(weights, sess)
def convlayers(self):
self.parameters = []
# zero-mean input
with tf.name_scope('preprocess') as scope:
mean = tf.constant([123.68, 116.779, 103.939], dtype=tf.float32, shape=[1, 1, 1, 3], name='img_mean')
images = self.imgs-mean
# conv1_1
with tf.name_scope('conv1_1') as scope:
kernel = tf.Variable(tf.truncated_normal([3, 3, 3, 64], dtype=tf.float32,
stddev=1e-1), name='weights')
conv = tf.nn.conv2d(images, kernel, [1, 1, 1, 1], padding='SAME')
biases = tf.Variable(tf.constant(0.0, shape=[64], dtype=tf.float32),
trainable=True, name='biases')
out = tf.nn.bias_add(conv, biases)
self.conv1_1 = tf.nn.relu(out, name=scope)
self.parameters += [kernel, biases]
# conv1_2
with tf.name_scope('conv1_2') as scope:
kernel = tf.Variable(tf.truncated_normal([3, 3, 64, 64], dtype=tf.float32,
conv = tf.nn.conv2d(self.conv1_1, kernel, [1, 1, 1, 1], padding='SAME')
self.conv1_2 = tf.nn.relu(out, name=scope)
# pool1
self.pool1 = tf.nn.max_pool(self.conv1_2,
ksize=[1, 2, 2, 1],
strides=[1, 2, 2, 1],
padding='SAME',
name='pool1')
# conv2_1
with tf.name_scope('conv2_1') as scope:
kernel = tf.Variable(tf.truncated_normal([3, 3, 64, 128], dtype=tf.float32,
conv = tf.nn.conv2d(self.pool1, kernel, [1, 1, 1, 1], padding='SAME')
biases = tf.Variable(tf.constant(0.0, shape=[128], dtype=tf.float32),
self.conv2_1 = tf.nn.relu(out, name=scope)
# conv2_2
with tf.name_scope('conv2_2') as scope:
kernel = tf.Variable(tf.truncated_normal([3, 3, 128, 128], dtype=tf.float32,
conv = tf.nn.conv2d(self.conv2_1, kernel, [1, 1, 1, 1], padding='SAME')
self.conv2_2 = tf.nn.relu(out, name=scope)
# pool2
self.pool2 = tf.nn.max_pool(self.conv2_2,
ksize=[1, 2, 2, 1],
padding='SAME',
name='pool2')
# conv3_1
with tf.name_scope('conv3_1') as scope:
kernel = tf.Variable(tf.truncated_normal([3, 3, 128, 256], dtype=tf.float32,
conv = tf.nn.conv2d(self.pool2, kernel, [1, 1, 1, 1], padding='SAME')
biases = tf.Variable(tf.constant(0.0, shape=[256], dtype=tf.float32),
self.conv3_1 = tf.nn.relu(out, name=scope)
# conv3_2
with tf.name_scope('conv3_2') as scope:
kernel = tf.Variable(tf.truncated_normal([3, 3, 256, 256], dtype=tf.float32,
conv = tf.nn.conv2d(self.conv3_1, kernel, [1, 1, 1, 1], padding='SAME')
self.conv3_2 = tf.nn.relu(out, name=scope)
# conv3_3
with tf.name_scope('conv3_3') as scope:
conv = tf.nn.conv2d(self.conv3_2, kernel, [1, 1, 1, 1], padding='SAME')
self.conv3_3 = tf.nn.relu(out, name=scope)
# pool3
self.pool3 = tf.nn.max_pool(self.conv3_3,
ksize=[1, 2, 2, 1],
padding='SAME',
name='pool3')
# conv4_1
with tf.name_scope('conv4_1') as scope:
kernel = tf.Variable(tf.truncated_normal([3, 3, 256, 512], dtype=tf.float32,
conv = tf.nn.conv2d(self.pool3, kernel, [1, 1, 1, 1], padding='SAME')
biases = tf.Variable(tf.constant(0.0, shape=[512], dtype=tf.float32),
self.conv4_1 = tf.nn.relu(out, name=scope)
# conv4_2
with tf.name_scope('conv4_2') as scope:
kernel = tf.Variable(tf.truncated_normal([3, 3, 512, 512], dtype=tf.float32,
conv = tf.nn.conv2d(self.conv4_1, kernel, [1, 1, 1, 1], padding='SAME')
self.conv4_2 = tf.nn.relu(out, name=scope)
# conv4_3
with tf.name_scope('conv4_3') as scope:
conv = tf.nn.conv2d(self.conv4_2, kernel, [1, 1, 1, 1], padding='SAME')
self.conv4_3 = tf.nn.relu(out, name=scope)
# pool4
self.pool4 = tf.nn.max_pool(self.conv4_3,
ksize=[1, 2, 2, 1],
padding='SAME',
name='pool4')
# conv5_1
with tf.name_scope('conv5_1') as scope:
conv = tf.nn.conv2d(self.pool4, kernel, [1, 1, 1, 1], padding='SAME')
self.conv5_1 = tf.nn.relu(out, name=scope)
# conv5_2
with tf.name_scope('conv5_2') as scope:
conv = tf.nn.conv2d(self.conv5_1, kernel, [1, 1, 1, 1], padding='SAME')
self.conv5_2 = tf.nn.relu(out, name=scope)
# conv5_3
with tf.name_scope('conv5_3') as scope:
conv = tf.nn.conv2d(self.conv5_2, kernel, [1, 1, 1, 1], padding='SAME')
self.conv5_3 = tf.nn.relu(out, name=scope)
# pool5
self.pool5 = tf.nn.max_pool(self.conv5_3,
ksize=[1, 2, 2, 1],
padding='SAME',
name='pool4')
def fc_layers(self):
# fc1
with tf.name_scope('fc1') as scope:
shape = int(np.prod(self.pool5.get_shape()[1:]))
fc1w = tf.Variable(tf.truncated_normal([shape, 4096],
dtype=tf.float32,
fc1b = tf.Variable(tf.constant(1.0, shape=[4096], dtype=tf.float32),
pool5_flat = tf.reshape(self.pool5, [-1, shape])
fc1l = tf.nn.bias_add(tf.matmul(pool5_flat, fc1w), fc1b)
self.fc1 = tf.nn.relu(fc1l)
self.parameters += [fc1w, fc1b]
# fc2
with tf.name_scope('fc2') as scope:
fc2w = tf.Variable(tf.truncated_normal([4096, 4096],
dtype=tf.float32,
fc2b = tf.Variable(tf.constant(1.0, shape=[4096], dtype=tf.float32),
fc2l = tf.nn.bias_add(tf.matmul(self.fc1, fc2w), fc2b)
self.fc2 = tf.nn.relu(fc2l)
self.parameters += [fc2w, fc2b]
# fc3
with tf.name_scope('fc3') as scope:
fc3w = tf.Variable(tf.truncated_normal([4096, 1000],
dtype=tf.float32,
fc3b = tf.Variable(tf.constant(1.0, shape=[1000], dtype=tf.float32),
self.fc3l = tf.nn.bias_add(tf.matmul(self.fc2, fc3w), fc3b)
self.parameters += [fc3w, fc3b]
def load_weights(self, weight_file, sess):
weights = np.load(weight_file)
keys = sorted(weights.keys())
for i, k in enumerate(keys):
print (i, k, np.shape(weights[k]))
sess.run(self.parameters[i].assign(weights[k]))
sess = tf.Session()
imgs = tf.placeholder(tf.float32, [None, 224, 224, 1])
vgg = vgg16(imgs, 'vgg16_weights.npz', sess)
parser.register_input("Placeholder", (1, 224, 224), 0)
uff_model,
parser,
MAX_BATCHSIZE,
MAX_WORKSPACE)
G_LOGGER = trt.infer.ConsoleLogger(trt.infer.LogSeverity.ERROR)
parser.register_input("Placeholder", (3,244,244),0)
parser.register_output("conv5_3")
uff_model, parser, 1, 1 << 20)
Could you also try our latest TensorRT 4 and share results with us?
https://developer.nvidia.com/nvidia-tensorrt-download
