The complete code is like this:
import tensorflow as tf
from tensorflow.examples.tutorials.mnist import input_data
import pycuda.driver as cuda
import pycuda.autoinit
import numpy as np
from random import randint # generate a random test case
from PIL import Image
import time #import system tools
import os
os.environ['TF_CPP_MIN_LOG_LEVEL'] = '2'
import uff
import tensorrt as trt
from tensorrt.parsers import uffparser
# test if the version if compatible
trt.utils.get_uff_version()
parser = uffparser.create_uff_parser()
def get_uff_required_version(parser):
return str(parser.get_uff_required_version_major()) + '.' + str(parser.get_uff_required_version_minor()) + '.' + str(parser.get_uff_required_version_patch())
if trt.utils.get_uff_version() != get_uff_required_version(parser):
raise ImportError("""ERROR: UFF TRT Required version mismatch""")
# training a model in tensorflow
STARTER_LEARNING_RATE = 1e-4
BATCH_SIZE = 10
NUM_CLASSES = 10
MAX_STEPS = 5000
IMAGE_SIZE = 28
IMAGE_PIXELS = IMAGE_SIZE ** 2
OUTPUT_NAMES = ["fc2/Relu"]
def WeightsVariable(shape):
return tf.Variable(tf.truncated_normal(shape, stddev=0.1, name='weights'))
def BiasVariable(shape):
return tf.Variable(tf.constant(0.1, shape=shape, name='biases'))
def Conv2d(x, W, b, strides=1):
# Conv2D wrapper, with bias and relu activation
filter_size = W.get_shape().as_list()
pad_size = filter_size[0]//2
pad_mat = np.array([[0,0], [pad_size,pad_size], [pad_size,pad_size],[0,0]])
x = tf.pad(x, pad_mat)
x = tf.nn.conv2d(x, W, strides=[1, strides, strides, 1], padding='VALID')
x = tf.nn.bias_add(x, b)
return tf.nn.relu(x)
def MaxPool2x2(x, k=2):
# MaxPool2D wrapper
pad_size = k//2
pad_mat = np.array([[0,0], [pad_size,pad_size], [pad_size,pad_size], [0,0]])
return tf.nn.max_pool(x, ksize=[1, k, k, 1], strides=[1, k, k, 1], padding='VALID')
def network(images):
# Convolution 1
with tf.name_scope('conv1'):
weights = WeightsVariable([5,5,1,32])
biases = BiasVariable([32])
conv1 = tf.nn.relu(Conv2d(images, weights, biases))
pool1 = MaxPool2x2(conv1)
# Convolution 2
with tf.name_scope('conv2'):
weights = WeightsVariable([5,5,32,64])
biases = BiasVariable([64])
conv2 = tf.nn.relu(Conv2d(pool1, weights, biases))
pool2 = MaxPool2x2(conv2)
# flatten the former layer and prepare for the fully connectted layer
pool2_flat = tf.reshape(pool2, [-1, 7 * 7 * 64])
# Fully Connected 1
with tf.name_scope('fc1'):
weights = WeightsVariable([7 * 7 * 64, 1024])
biases = BiasVariable([1024])
fc1 = tf.nn.relu(tf.matmul(pool2_flat, weights) + biases)
# Fully Connected 2
with tf.name_scope('fc2'):
weights = WeightsVariable([1024, 10])
biases = BiasVariable([10])
fc2 = tf.reshape(tf.matmul(fc1,weights) + biases, shape= [-1,10], name='Relu')
return fc2
def loss_metrics(logits, labels):
cross_entropy = tf.nn.sparse_softmax_cross_entropy_with_logits(labels=labels, logits=logits, name='softmax')
return tf.reduce_mean(cross_entropy, name='softmax_mean')
def training(loss):
tf.summary.scalar('loss', loss)
global_step = tf.Variable(0, name='global_step', trainable=False)
learning_rate = tf.train.exponential_decay(STARTER_LEARNING_RATE, global_step, 100000, 0.75, staircase=True)
tf.summary.scalar('learning_rate', learning_rate)
optimizer = tf.train.MomentumOptimizer(learning_rate, 0.9)
train_op = optimizer.minimize(loss, global_step=global_step)
return train_op
def evaluation(logits, labels):
correct = tf.nn.in_top_k(logits, labels, 1)
return tf.reduce_sum(tf.cast(correct, tf.int32))
def do_eval(sess, eval_correct, images_placeholder, labels_placeholder, data_set, summary):
true_count = 0
steps_per_epoch = data_set.num_examples // BATCH_SIZE
num_examples = steps_per_epoch * BATCH_SIZE
for step in range(steps_per_epoch):
feed_dict = fill_feed_dict(data_set, images_placeholder, labels_placeholder)
log, correctness = sess.run([summary, eval_correct], feed_dict=feed_dict)
true_count += correctness
precision = float(true_count) / num_examples
tf.summary.scalar('precision', tf.constant(precision))
print('Num examples %d, Num Correct: %d Precision @ 1: %0.04f' % (num_examples, true_count, precision))
return log
def placeholder_inputs(batch_size):
images_placeholder = tf.placeholder(tf.float32, shape=(None, 28, 28, 1))
labels_placeholder = tf.placeholder(tf.int32, shape=(None))
return images_placeholder, labels_placeholder
def fill_feed_dict(data_set, images_pl, labels_pl):
images_feed, labels_feed = data_set.next_batch(BATCH_SIZE)
feed_dict = {images_pl: np.reshape(images_feed, (-1,28,28,1)), labels_pl: labels_feed, }
return feed_dict
def run_training(data_sets):
with tf.Graph().as_default():
images_placeholder, labels_placeholder = placeholder_inputs(BATCH_SIZE)
logits = network(images_placeholder)
loss = loss_metrics(logits, labels_placeholder)
train_op = training(loss)
eval_correct = evaluation(logits, labels_placeholder)
summary = tf.summary.merge_all()
init = tf.global_variables_initializer()
saver = tf.train.Saver()
gpu_options = tf.GPUOptions(per_process_gpu_memory_fraction=0.5)
sess = tf.Session(config=tf.ConfigProto(gpu_options=gpu_options))
summary_writer = tf.summary.FileWriter("/tmp/tensorflow/mnist/log", graph=tf.get_default_graph())
test_writer = tf.summary.FileWriter("/tmp/tensorflow/mnist/log/validation", graph=tf.get_default_graph())
sess.run(init)
for step in range(MAX_STEPS):
start_time = time.time()
feed_dict = fill_feed_dict(data_sets.train, images_placeholder, labels_placeholder)
_, loss_value = sess.run([train_op, loss], feed_dict=feed_dict)
duration = time.time() - start_time
if step % 100 == 0:
print('Step %d: loss = %.2f (%.3f sec)' % (step, loss_value, duration))
summary_str = sess.run(summary, feed_dict=feed_dict)
summary_writer.add_summary(summary_str, step)
summary_writer.flush()
if (step + 1) % 1000 == 0 or (step + 1) == MAX_STEPS:
checkpoint_file = os.path.join("/tmp/tensorflow/mnist/log", "model.ckpt")
saver.save(sess, checkpoint_file, global_step=step)
print('Validation Data Eval:')
log = do_eval(sess, eval_correct, images_placeholder, labels_placeholder, data_sets.validation, summary)
test_writer.add_summary(log, step)
graphdef = tf.get_default_graph().as_graph_def()
frozen_graph = tf.graph_util.convert_variables_to_constants(sess, graphdef, OUTPUT_NAMES)
return tf.graph_util.remove_training_nodes(frozen_graph)
MNIST_DATASETS = input_data.read_data_sets('/tmp/tensorflow/mnist/input_data')
tf_model = run_training(MNIST_DATASETS)
# Converting A TensorFlow Model To UFF
uff_model = uff.from_tensorflow(tf_model, ["fc2/Relu"])
# Importing A UFF Model Into TensorRT
# generate a TensorRT engine by creating a logger for TensorRT
G_LOGGER = trt.infer.ConsoleLogger(trt.infer.LogSeverity.ERROR)
# Create a UFF parser and identify the desired input and output nodes
parser.register_input("Placeholder", (1,28,28),0)
parser.register_output("fc2/Relu")
