Setup
- Jetson AGX Orin, JetPack (Isaac ROS dev container, aarch64)
- Isaac ROS Visual SLAM 3.2, cuVSLAM 12.6
- ROS 2 Humble
- Camera: Luxonis OAK-D Pro W (wide FOV), depthai_ros_driver, on-device rectified stereo pair, 1280x720 @ 30 FPS
- Vehicle: a wheel loader, camera pitched 14 deg down, stereo baseline 75 mm
num_cameras: 2,camera_optical_framesset,rectified_images: true, IMU fusion disabled
Issue 1 : camera_info R is composed into the rig even with rectified_images: true
The depthai ros driver publishes rect-mode camera_info with a malformed R (raw rectification rotations with the diagonal overwritten to 1.0). Using the debug dump (enable_debug_mode: true), I found those R matrices composed verbatim into the stereo.edex per-camera transforms, creating a phantom ~1.55 deg relative rotation (vergence) between cameras whose images are actually rectified parallel:
cam0 transform row 0: [0.99990, -0.005295, 0.012847, -0.0375]
cam1 transform row 0: [0.99990, 0.001139, -0.014210, 0.0375]
At fx=565 this is a ~15 px disparity bias. Depending on sign it produced either depth-dependent scale compression (odometry reporting 10-30% of true displacement) or rejection of essentially all stereo features (observations_cloud width 0-1, constant tracking loss).
Sanitizing camera_info before the node (R := identity, D := 0, unified intrinsics, Tx rescaled to preserve baseline) fixes the rig:
cam0/cam1 transform row 0: [1, ~0, ~0, +/-0.0375] (plus shared 14 deg pitch in rows 1-2)
horizontal_stereo_camera: 1 (was 0 before the fix)
distortion_params: all zero
After this, tracking is continuous and healthy. Question for the Isaac ROS team: is composing camera_info R into rig extrinsics with rectified_images: true intended? If yes, the requirement that R be identity for pre-rectified input would be worth documenting prominently, since at least one major driver publishes non-identity R in rect mode.
Issue 2 : residual uniform ~1.33x translation overestimate
With the corrected rig (verified in stereo.edex: baseline 0.0751 m, identity relative rotation, zero distortion, unified fx=565.32):
- A measured 60 m straight drive reports ~80 m displacement in
/visual_slam/tracking/odometry— ratio ~1.33, reproduced across two drives. - Runs so far had
enable_localization_n_mapping: trueandenable_ground_constraint_in_odometry/slam: trueon a flat farm terrain; z is pinned to exactly 0 with VO-only. - map → odom jumps erratically during these runs (observations_cloud width ranges from 24 to 160).
Questions:
With
enable_localization_n_mapping: true, does/visual_slam/tracking/odometryinclude SLAM/relocalization corrections, or is it pure VO in the odom frame? (i.e., can bad relocalizations inflate apparent displacement on this topic?) -
Can
enable_ground_constraint_in_odometry: trueon genuinely 3D terrain distort estimated translation scale / path shape, given it forces z=0 and roll=pitch=0 while the vehicle actually pitches and climbs? -
Is there any known path by which a uniform ~1.33x scale error survives a rig with verified baseline and identity relative rotation — e.g., cuVSLAM using an effective focal length different from camera_info K/P for pre-rectified wide-FOV input (alpha/FOV scaling), or resolution/intrinsics mismatch handling?
Recommended settings for repetitive outdoor agricultural environments to suppress spurious relocalization (and whether masking sky regions via img_mask_top is the suggested way to keep features off moving clouds)?
@Raffaello Could you please help in clarifying the above mentioned issues?
