Hi Ahung,
I managed to replace the cable, and now I have a constant connection at 3.2. I also updated the firmware to version 5.13.0.50, but I still got the same result.
Below is only the camera log, as once again, the results of the other launches executed were the same.
admin@ubuntu:/workspaces/isaac_ros-dev$ ros2 launch realsense2_camera rs_launch.py enable_accel:=true enable_gyro:=true unite_imu_method:=2
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2025-03-17-15-47-37-109102-ubuntu-10500
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [realsense2_camera_node-1]: process started with pid [10501]
[realsense2_camera_node-1] [INFO] [1742237257.523666645] [camera.camera]: RealSense ROS v4.51.1
[realsense2_camera_node-1] [INFO] [1742237257.523874299] [camera.camera]: Built with LibRealSense v2.55.1
[realsense2_camera_node-1] [INFO] [1742237257.523903964] [camera.camera]: Running with LibRealSense v2.55.1
[realsense2_camera_node-1] [INFO] [1742237258.015797449] [camera.camera]: Device with serial number 841512071104 was found.
[realsense2_camera_node-1] [INFO] [1742237258.015954125] [camera.camera]: Device with physical ID 1-2.1-8 was found.
[realsense2_camera_node-1] [INFO] [1742237258.015982350] [camera.camera]: Device with name Intel RealSense D435I was found.
[realsense2_camera_node-1] [INFO] [1742237258.016710883] [camera.camera]: Device with port number 1-2.1 was found.
[realsense2_camera_node-1] [INFO] [1742237258.017288820] [camera.camera]: Device USB type: 3.2
[realsense2_camera_node-1] [INFO] [1742237258.027491133] [camera.camera]: getParameters…
[realsense2_camera_node-1] [INFO] [1742237258.028129712] [camera.camera]: JSON file is not provided
[realsense2_camera_node-1] [INFO] [1742237258.028172401] [camera.camera]: Device Name: Intel RealSense D435I
[realsense2_camera_node-1] [INFO] [1742237258.028196530] [camera.camera]: Device Serial No: 841512071104
[realsense2_camera_node-1] [INFO] [1742237258.028213938] [camera.camera]: Device physical port: 1-2.1-8
[realsense2_camera_node-1] [INFO] [1742237258.028230323] [camera.camera]: Device FW version: 5.13.0.50
[realsense2_camera_node-1] [INFO] [1742237258.028244723] [camera.camera]: Device Product ID: 0x0B3A
[realsense2_camera_node-1] [INFO] [1742237258.028257396] [camera.camera]: Sync Mode: Off
[realsense2_camera_node-1] [INFO] [1742237261.305250681] [camera.camera]: Set ROS param depth_module.profile to default: 640x480x15
[realsense2_camera_node-1] [INFO] [1742237262.179225804] [camera.camera]: Set ROS param rgb_camera.profile to default: 640x480x15
[realsense2_camera_node-1] [INFO] [1742237262.180134630] [camera.camera]: Set ROS param gyro_fps to default: 200
[realsense2_camera_node-1] [INFO] [1742237262.180245577] [camera.camera]: Set ROS param accel_fps to default: 63
[realsense2_camera_node-1] [INFO] [1742237262.194869393] [camera.camera]: Stopping Sensor: Stereo Module
[realsense2_camera_node-1] [INFO] [1742237262.349398929] [camera.camera]: Starting Sensor: Stereo Module
[realsense2_camera_node-1] [INFO] [1742237262.471030168] [camera.camera]: Open profile: stream_type: Depth(0), Format: Z16, Width: 640, Height: 480, FPS: 15
[realsense2_camera_node-1] [INFO] [1742237262.471369570] [camera.camera]: Stopping Sensor: RGB Camera
[realsense2_camera_node-1] 17/03 15:47:42,472 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[realsense2_camera_node-1] [INFO] [1742237262.475835523] [camera.camera]: Starting Sensor: RGB Camera
[realsense2_camera_node-1] [INFO] [1742237262.502587883] [camera.camera]: Open profile: stream_type: Color(0), Format: RGB8, Width: 640, Height: 480, FPS: 15
[realsense2_camera_node-1] [INFO] [1742237262.502811185] [camera.camera]: Stopping Sensor: Motion Module
[realsense2_camera_node-1] [INFO] [1742237262.514766412] [camera.camera]: Starting Sensor: Motion Module
[realsense2_camera_node-1] [INFO] [1742237262.531617652] [camera.camera]: Open profile: stream_type: Accel(0)Format: MOTION_XYZ32F, FPS: 63
[realsense2_camera_node-1] [INFO] [1742237262.531868892] [camera.camera]: Open profile: stream_type: Gyro(0)Format: MOTION_XYZ32F, FPS: 200
[realsense2_camera_node-1] [INFO] [1742237262.535646185] [camera.camera]: RealSense Node Is Up!
[realsense2_camera_node-1] [WARN] [1742237262.553194598] [camera.camera]:
[realsense2_camera_node-1] 17/03 15:47:42,799 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[realsense2_camera_node-1] 17/03 15:47:42,810 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[realsense2_camera_node-1] 17/03 15:47:42,822 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[realsense2_camera_node-1] 17/03 15:47:42,833 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[realsense2_camera_node-1] 17/03 15:47:43,458 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[realsense2_camera_node-1] 17/03 15:47:43,469 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[realsense2_camera_node-1] 17/03 15:47:43,480 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[realsense2_camera_node-1] 17/03 15:47:43,490 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[realsense2_camera_node-1] 17/03 15:47:43,501 WARNING [281472870967520] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
Best,
Enzo Guido
