Isaac ROS RealSense Setup: Cannot launch docker
I am using Jetson Orin Nano 8GB Developer Kit with jetpack 6.0 and NVMe SSD. I would like to use Isaac ROS with Intel Realsense D455 but have a problem when doing Sensor Setup with the instructions from this website:
https://nvidia-isaac-ros.github.io/getting_started/hardware_setup/sensors/realsense_setup.html
Before Sensor Setup, I have already finished Compute Setup and Developer Environment Setup from these two wesites:
https://nvidia-isaac-ros.github.io/getting_started/hardware_setup/compute/index.html
https://nvidia-isaac-ros.github.io/getting_started/dev_env_setup.html
For Sensor Setup (Realsense) this is what I typed in terminal, I don’t think the docker container is launched successfully:
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src$ git clone -b release-3.1 GitHub - NVIDIA-ISAAC-ROS/isaac_ros_common: Common utilities, packages, scripts, Dockerfiles, and testing infrastructure for Isaac ROS packages.
fatal: could not create work tree dir ‘isaac_ros_common’: Permission denied
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src$ sudo git clone -b release-3.1 GitHub - NVIDIA-ISAAC-ROS/isaac_ros_common: Common utilities, packages, scripts, Dockerfiles, and testing infrastructure for Isaac ROS packages.
Cloning into ‘isaac_ros_common’
remote: Enumerating objects: 1056, done.
remote: Counting objects: 100% (295/295), done.
remote: Compressing objects: 100% (169/169), done.
remote: Total 1056 (delta 184), reused 180 (delta 121), pack-reused 761 (from 1)
Receiving objects: 100% (1056/1056), 574.92 KiB | 3.42 MiB/s, done.
Resolving deltas: 100% (467/467), done.
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src$ sudo git clone -b 4.51.1 GitHub - IntelRealSense/realsense-ros: ROS Wrapper for Intel(R) RealSense(TM) Cameras
Cloning into ‘realsense-ros’
remote: Enumerating objects: 17212, done.
remote: Counting objects: 100% (329/329), done.
remote: Total 17212 (delta 194), reused 261 (delta 159), pack-reused 16883 (from 1)
Receiving objects: 100% (17212/17212), 32.75 MiB | 9.76 MiB/s, done.
Resolving deltas: 100% (10980/10980), done.
Note: switching to ‘2a65533ee7431bdc05fe5744798efc7f5713f866’.
You are in ‘detached HEAD’ state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src$ sudo rm -rf ${ISAAC_ROS_WS}/src/isaac_ros_common ${ISAAC_ROS_WS}/src/realsense-ros
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src$ git clone -b release-3.1 GitHub - NVIDIA-ISAAC-ROS/isaac_ros_common: Common utilities, packages, scripts, Dockerfiles, and testing infrastructure for Isaac ROS packages. isaac_ros_common
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src$ sudo git clone -b release-3.1 GitHub - NVIDIA-ISAAC-ROS/isaac_ros_common: Common utilities, packages, scripts, Dockerfiles, and testing infrastructure for Isaac ROS packages. isaac_ros_common
Receiving objects: 100% (1056/1056), 574.92 KiB | 3.64 MiB/s, done.
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src$ sudo git clone GitHub - IntelRealSense/realsense-ros: ROS Wrapper for Intel(R) RealSense(TM) Cameras -b 4.51.1
Receiving objects: 100% (17212/17212), 32.75 MiB | 9.51 MiB/s, done.
git switch -c
git switch -
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common/scripts &&
touch .isaac_ros_common-config &&
echo CONFIG_IMAGE_KEY=ros2_humble.realsense > .isaac_ros_common-config
touch: cannot touch ‘.isaac_ros_common-config’: Permission denied
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts$ sudo cd ${ISAAC_ROS_WS}/src/isaac_ros_common/scripts &&
sudo: cd: command not found
sudo: “cd” is a shell built-in command, it cannot be run directly.
sudo: the -s option may be used to run a privileged shell.
sudo: the -D option may be used to run a command in a specific directory.
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common/scripts
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts$ sudo touch .isaac_ros_common-config
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts$ echo CONFIG_IMAGE_KEY=ros2_humble.realsense > .isaac_ros_common-config
bash: .isaac_ros_common-config: Permission denied
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts$ sudo echo CONFIG_IMAGE_KEY=ros2_humble.realsense > .isaac_ros_common-config
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts$ echo CONFIG_IMAGE_KEY=ros2_humble.realsense | sudo tee .isaac_ros_common-config
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common &&
./scripts/run_dev.sh -d ${ISAAC_ROS_WS}
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common$
Can anyone help? Thanks a lot.
Hi @AustinCTH
Thank you for your post.
The reason could be that you executed mkdir -p /mnt/nova_ssd/workspaces/isaac_ros-dev/src with root permission. Please go through following commands, clone source and try again.
sudo rm -rf /mnt/nova_ssd
sudo mkdir -p /mnt/nova_ssd
sudo chown ${USER}:${USER} /mnt/nova_ssd
Let me know,
Ahung
Yep thanks @Ahung it started to try launching the docker container instead of skipping it. However, it showed this:
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common &&
Launching Isaac ROS Dev container with image key aarch64.ros2_humble.realsense.user: /mnt/nova_ssd/workspaces/isaac_ros-dev/
Building aarch64.ros2_humble.realsense.user base as image: isaac_ros_dev-aarch64
Building layered image for key aarch64.ros2_humble.realsense.user as isaac_ros_dev-aarch64
Using configured docker search paths: /mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/
/docker
Checking if base image nvcr.io/isaac/ros:aarch64-ros2_humble-realsense-user_474334a38bc61614605d8bc1af11882f exists on remote registry
Checking if base image nvcr.io/isaac/ros:aarch64-ros2_humble-realsense_6c677b302ddf2d9594dd22518b05fcae exists on remote registry
Checking if base image nvcr.io/isaac/ros:aarch64-ros2_humble_5d698e0d23e98e2567b1c9b70abd0c1f exists on remote registry
Checking if base image nvcr.io/isaac/ros:aarch64_614b366df729318fe81c054b575cee53 exists on remote registry
Resolved the following 4 Dockerfiles for target image: aarch64.ros2_humble.realsense.user
/docker/Dockerfile.user
/docker/Dockerfile.realsense
/docker/Dockerfile.ros2_humble
/docker/Dockerfile.aarch64
Building /mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/
/docker/Dockerfile.aarch64 as image: aarch64-image with base:
[+] Building 1.6s (26/26) FINISHED docker:default
=> [internal] load build definition from Dockerfile.aarch64 0.0s
=> => transferring dockerfile: 8.32kB 0.0s
=> [internal] load metadata for nvcr.io/nvidia/l4t-cuda:12.2.12-devel 1.5s
=> [internal] load .dockerignore 0.0s
=> => transferring context: 2B 0.0s
=> [stage-0 1/22] FROM nvcr.io/nvidia/l4t-cuda:12.2.12-devel@sha256:f9c4057f9c5dde81bf9d17be0eb89724fcfe2f709b3fbd1c8d9359b221b2686e 0.0s
=> CACHED [stage-0 2/22] RUN mkdir -p /opt/nvidia/isaac_ros_dev_base && dpkg-query -W | sort > /opt/nvidia/isaac_ros_dev_base/aarch64-start-packages.csv 0.0s
=> CACHED [stage-0 3/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y software-properties-common && add-apt-repository universe && apt-get update 0.0s
=> CACHED [stage-0 4/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y apt-utils bash-completion build-essential ca-certificates curl g 0.0s
=> CACHED [stage-0 5/22] RUN --mount=type=cache,target=/var/cache/apt wget -qO - https://isaac.download.nvidia.com/isaac-ros/repos.key | apt-key add - && grep -qxF "deb https://isaac.down 0.0s
=> CACHED [stage-0 6/22] RUN --mount=type=cache,target=/var/cache/apt apt-key adv --fetch-keys https://repo.download.nvidia.com/jetson/jetson-ota-public.asc && apt-key adv --fetch-keys ht 0.0s
=> CACHED [stage-0 7/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y python3-dev python3-distutils python3-flake8 python3-pip python3-pyt 0.0s
=> CACHED [stage-0 8/22] RUN update-alternatives --install /usr/bin/python python /usr/bin/python3 1 0.0s
=> CACHED [stage-0 9/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y ffmpeg gfortran graphicsmagick-libmagick-dev-compat jq kmod lcov 0.0s
=> CACHED [stage-0 10/22] RUN python3 -m pip install -U Cython pymongo wheel scikit-learn ninja networkx “numpy>=1.24.4,<2” numpy-quaternion pyyaml "setupto 0.0s
=> CACHED [stage-0 11/22] RUN update-alternatives --install /usr/bin/llvm-config llvm-config /usr/bin/llvm-config-14 14 0.0s
=> CACHED [stage-0 12/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y --no-install-recommends cuda-cudart-12-2 cuda-libraries-12-2 cuda-nvml-dev-1 0.0s
=> CACHED [stage-0 13/22] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /lib/firmware && apt-get update && apt-get install -y libnvvpi3 tensorrt vpi3-dev 0.0s
=> CACHED [stage-0 14/22] RUN mkdir -p /opt/nvidia/tao && cd /opt/nvidia/tao && wget --content-disposition 'https://api.ngc.nvidia.com/v2/resources/org/nvidia/team/tao/tao-converter/v5.1.0_jp6 0.0s
=> CACHED [stage-0 15/22] RUN python3 -m pip install --no-cache https://developer.download.nvidia.com/compute/redist/jp/v60dp/pytorch/torch-2.2.0a0+6a974be.nv23.11-cp310-cp310-linux_aarch6 0.0s
=> CACHED [stage-0 16/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y --no-install-recommends libb64-0d libre2-9 rapidjson-dev libopenblas-dev 0.0s
=> CACHED [stage-0 17/22] RUN --mount=type=cache,target=/var/cache/apt cd /opt && wget https://github.com/triton-inference-server/server/releases/download/v2.40.0/tritonserver2.40.0-igpu.t 0.0s
=> CACHED [stage-0 18/22] RUN --mount=type=cache,target=/var/cache/apt wget -O /tmp/boost.tar.gz https://boostorg.jfrog.io/artifactory/main/release/1.80.0/source/boost_1_80_0.tar.gz && 0.0s
=> CACHED [stage-0 19/22] RUN --mount=type=cache,target=/var/cache/apt cd /tmp && wget https://github.com/CVCUDA/CV-CUDA/releases/download/v0.5.0-beta/nvcv-lib-0.5.0_beta_DP-cuda12-aarch64 0.0s
=> CACHED [stage-0 20/22] RUN --mount=type=cache,target=/var/cache/apt apt-add-repository ppa:mosquitto-dev/mosquitto-ppa && apt-get update && apt-get install -y mosquitto mosquitt 0.0s
=> CACHED [stage-0 21/22] RUN python3 -m pip install -U jetson-stats 0.0s
=> CACHED [stage-0 22/22] RUN mkdir -p /opt/nvidia/isaac_ros_dev_base && dpkg-query -W | sort > /opt/nvidia/isaac_ros_dev_base/aarch64-end-packages.csv 0.0s
=> exporting to image 0.0s
=> => exporting layers 0.0s
=> => writing image sha256:95e57c22b73207a19593592a29be22ebf77aaa5d209ccc86f9f2c77a18d98655 0.0s
=> => naming to Docker Hub Container Image Library | App Containerization 0.0s
1 warning found (use docker --debug to expand):
  • LegacyKeyValueFormat: “ENV key=value” should be used instead of legacy “ENV key value” format (line 18)
/docker/Dockerfile.ros2_humble as image: ros2_humble-image with base: aarch64-image
    [+] Building 0.2s (27/27) FINISHED docker:default
    => [internal] load build definition from Dockerfile.ros2_humble 0.0s
    => => transferring dockerfile: 13.71kB 0.0s
    => WARN: InvalidDefaultArgInFrom: Default value for ARG $BASE_IMAGE results in empty or invalid base image name (line 10) 0.0s
    => WARN: LegacyKeyValueFormat: “ENV key=value” should be used instead of legacy “ENV key value” format (line 17) 0.0s
    => [internal] load metadata for Docker Hub Container Image Library | App Containerization 0.0s
    => [stage-0 1/22] FROM Docker Hub Container Image Library | App Containerization 0.0s
    => [internal] load build context 0.0s
    => => transferring context: 276.05kB 0.0s
    => CACHED [stage-0 2/22] RUN mkdir -p /opt/nvidia/isaac_ros_dev_base && dpkg-query -W | sort > /opt/nvidia/isaac_ros_dev_base/ros2_humble-start-packages.csv 0.0s
    => CACHED [stage-0 3/22] RUN locale-gen en_US en_US.UTF-8 && update-locale LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 0.0s
    => CACHED [stage-0 4/22] RUN echo “Warning: Using the PYTHONWARNINGS environment variable to silence setup.py and easy_install deprecation warnings caused by colcon” 0.0s
    => CACHED [stage-0 5/22] RUN --mount=type=cache,target=/var/cache/apt curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg 0.0s
    => CACHED [stage-0 6/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y devscripts dh-make fakeroot libxtensor-dev pytho 0.0s
    => CACHED [stage-0 7/22] RUN python3 -m pip install -U flake8-blind-except flake8-builtins flake8-class-newline flake8-comprehensions flake8-deprecated 0.0s
    => CACHED [stage-0 8/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y ros-humble-ros-base ros-humble-angles ros-humble-apriltag ros-humble-beh 0.0s
    => CACHED [stage-0 9/22] COPY rosdep/extra_rosdeps.yaml /etc/ros/rosdep/sources.list.d/nvidia-isaac.yaml 0.0s
    => CACHED [stage-0 10/22] RUN --mount=type=cache,target=/var/cache/apt rosdep init && echo “yaml file:///etc/ros/rosdep/sources.list.d/nvidia-isaac.yaml” | tee /etc/ros/rosdep/sources.list 0.0s
    => CACHED [stage-0 11/22] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src && git clone GitHub - osrf/negotiated && cd negotiat 0.0s
    => CACHED [stage-0 12/22] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src && git clone GitHub - ros-perception/image_pipeline: An image processing pipeline for ROS.. 0.0s
    => CACHED [stage-0 13/22] COPY patches/rclcpp-disable-tests.patch /tmp/ 0.0s
    => CACHED [stage-0 14/22] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src && export RCLCPP_VERSION="release/humble/rclcpp/$(apt-cache ma 0.0s
    => CACHED [stage-0 15/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y ros-humble-ament-cmake ros-humble-ament-cmake-gtest ros-humble-control-msgs 0.0s
    => CACHED [stage-0 16/22] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src && git clone GitHub - moveit/moveit_resources: URDFs, meshes, and config packages for MoveIt testing. 0.0s
    => CACHED [stage-0 17/22] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src && git clone https://github.com/ros-planning/moveit_task_const 0.0s
    => CACHED [stage-0 18/22] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y ros-humble-moveit-hybrid-planning 0.0s
    => CACHED [stage-0 19/22] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src && git clone GitHub - moveit/moveit2_tutorials: A sphinx-based centralized documentation repo for MoveIt 2 0.0s
    => CACHED [stage-0 20/22] RUN python3 -m pip install -U paho-mqtt==1.6.1 0.0s
    => CACHED [stage-0 21/22] RUN sudo sed -i ‘917i #ifdef GTEST_INTERNAL_NEED_REDUNDANT_CONSTEXPR_DECL’ /usr/src/googletest/googletest/include/gtest/internal/gtest-internal.h && sudo sed -i '920i 0.0s
    => CACHED [stage-0 22/22] RUN mkdir -p /opt/nvidia/isaac_ros_dev_base && dpkg-query -W | sort > /opt/nvidia/isaac_ros_dev_base/ros2_humble-end-packages.csv 0.0s
    => => writing image sha256:cb12713cc76a520d1a7a941eba92f3ef92e51d2d71b1552a4ba8bdc681b7c88b 0.0s
/docker/Dockerfile.realsense as image: realsense-image with base: ros2_humble-image
    [+] Building 0.2s (12/12) FINISHED docker:default
    => [internal] load build definition from Dockerfile.realsense 0.0s
    => => transferring dockerfile: 1.33kB 0.0s
    => WARN: InvalidDefaultArgInFrom: Default value for ARG ${BASE_IMAGE} results in empty or invalid base image name (line 12) 0.0s
    => [1/7] FROM Docker Hub Container Image Library | App Containerization 0.0s
    => => transferring context: 11.54kB 0.0s
    => CACHED [2/7] COPY scripts/build-librealsense.sh /opt/realsense/build-librealsense.sh 0.0s
    => CACHED [3/7] COPY scripts/install-realsense-dependencies.sh /opt/realsense/install-realsense-dependencies.sh 0.0s
    => CACHED [4/7] RUN chmod +x /opt/realsense/install-realsense-dependencies.sh && /opt/realsense/install-realsense-dependencies.sh; chmod +x /opt/realsense/build-librealsense.sh && /opt/rea 0.0s
    => CACHED [5/7] RUN mkdir -p /opt/realsense/ 0.0s
    => CACHED [6/7] COPY scripts/hotplug-realsense.sh /opt/realsense/hotplug-realsense.sh 0.0s
    => CACHED [7/7] COPY udev_rules/99-realsense-libusb-custom.rules /etc/udev/rules.d/99-realsense-libusb-custom.rules 0.0s
    => => writing image sha256:d1bfb53fa6b43ba2a5de0402fa5d61852a8a338a8e54568f37db21ad47062d33 0.0s
  • InvalidDefaultArgInFrom: Default value for ARG ${BASE_IMAGE} results in empty or invalid base image name (line 12)
/docker/Dockerfile.user as image: isaac_ros_dev-aarch64 with base: realsense-image
    [+] Building 0.2s (16/16) FINISHED docker:default
    => [internal] load build definition from Dockerfile.user 0.0s
    => => transferring dockerfile: 2.23kB 0.0s
    => WARN: InvalidDefaultArgInFrom: Default value for ARG ${BASE_IMAGE} results in empty or invalid base image name (line 10) 0.0s
    => [stage-0 1/11] FROM Docker Hub Container Image Library | App Containerization 0.0s
    => => transferring context: 2.00kB 0.0s
    => CACHED [stage-0 2/11] RUN --mount=type=cache,target=/var/cache/apt apt-get update && apt-get install -y sudo udev 0.0s
    => CACHED [stage-0 3/11] RUN if [ $(getent group triton-server) ]; then groupmod -o --gid 1001 -n admin triton-server ; usermod -l admin -u 1000 -m -d /home/admin triton-server ; 0.0s
    => CACHED [stage-0 4/11] RUN if [ ! $(getent passwd admin) ]; then groupadd --gid 1001 admin ; useradd --no-log-init --uid 1000 --gid 1001 -m admin ; fi 0.0s
    => CACHED [stage-0 5/11] RUN echo admin ALL=(root) NOPASSWD:ALL > /etc/sudoers.d/admin && chmod 0440 /etc/sudoers.d/admin && adduser admin video && adduser admin plugdev && adduser admin 0.0s
    => CACHED [stage-0 6/11] RUN mkdir -p /usr/local/bin/scripts 0.0s
    => CACHED [stage-0 7/11] COPY scripts/entrypoint.sh /usr/local/bin/scripts/ 0.0s
    => CACHED [stage-0 8/11] RUN chmod +x /usr/local/bin/scripts/
    .sh 0.0s
    => CACHED [stage-0 9/11] RUN mkdir -p /usr/local/share/middleware_profiles 0.0s
    => CACHED [stage-0 10/11] COPY middleware_profiles/*profile.xml /usr/local/share/middleware_profiles/ 0.0s
    => CACHED [stage-0 11/11] RUN --mount=type=cache,target=/var/cache/apt rosdep update 0.0s
    => => writing image sha256:0e657db478a3680d9f54a8fcf8558f83d251fb2de55f3adf9c1f7b18be999162 0.0s
  • InvalidDefaultArgInFrom: Default value for ARG ${BASE_IMAGE} results in empty or invalid base image name (line 10)
    Running isaac_ros_dev-aarch64-container
    docker: Error response from daemon: unknown or invalid runtime name: nvidia.
    See ‘docker run --help’.
Are there any dependencies that are not installed properly? What does it mean by “unknown or invalid runtime name: nvidia”
Hi @AustinCTH
It looks that NVIDIA Container Runtime is not installed. SDK Manager can install it after flashing so that you should also have the other JetPack components CUDA/cuDNN/TensorRT/ect installed for some containers to function correctly.
If you have the NVIDIA L4T apt repo (normally this is already setup for you in /etc/apt/sources.list.d/nvidia-l4t-apt-source.list ) you can try installing these packages via apt:
$ apt-cache search nvidia-container
libnvidia-container-tools - NVIDIA container runtime library (command-line tools)
libnvidia-container1 - NVIDIA container runtime library
nvidia-container - NVIDIA Container Meta Package
nvidia-container-toolkit - NVIDIA Container toolkit
nvidia-container-toolkit-base - NVIDIA Container Toolkit Base
Thanks @Ahung for your immediate response. However, I guess the problem persists after installing those packages:
mic-711on@ubuntu:~$ sudo apt update
sudo apt install -y libnvidia-container-tools libnvidia-container1 nvidia-container nvidia-container-toolkit nvidia-container-toolkit-base
[sudo] password for mic-711on:
Hit:1 https://download.docker.com/linux/ubuntu jammy InRelease
Hit:2 https://repo.download.nvidia.com/jetson/common r36.3 InRelease
Hit:3 https://repo.download.nvidia.com/jetson/t234 r36.3 InRelease
Hit:4 https://repo.download.nvidia.com/jetson/ffmpeg r36.3 InRelease
Hit:5 http://packages.ros.org/ros2/ubuntu jammy InRelease
Hit:6 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Hit:7 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease
Hit:8 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
Hit:9 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
28 packages can be upgraded. Run 'apt list --upgradable' to see them.
The following packages were automatically installed and are no longer required:
  libwpe-1.0-1 libwpebackend-fdo-1.0-1
Use 'sudo apt autoremove' to remove them.
The following NEW packages will be installed:
0 upgraded, 5 newly installed, 0 to remove and 28 not upgraded.
Need to get 3,721 kB of archives.
After this operation, 16.3 MB of additional disk space will be used.
Get:1 https://repo.download.nvidia.com/jetson/common r36.3/main arm64 nvidia-container-toolkit-base arm64 1.14.2-1 [2,073 kB]
Get:2 https://repo.download.nvidia.com/jetson/common r36.3/main arm64 libnvidia-container1 arm64 1.14.2-1 [809 kB]
Get:3 https://repo.download.nvidia.com/jetson/common r36.3/main arm64 libnvidia-container-tools arm64 1.14.2-1 [18.8 kB]
Get:4 https://repo.download.nvidia.com/jetson/common r36.3/main arm64 nvidia-container-toolkit arm64 1.14.2-1 [790 kB]
Get:5 https://repo.download.nvidia.com/jetson/common r36.3/main arm64 nvidia-container arm64 6.0+b106 [29.7 kB]
Fetched 3,721 kB in 1s (6,616 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package nvidia-container-toolkit-base.
(Reading database ... 268328 files and directories currently installed.)
Preparing to unpack .../nvidia-container-toolkit-base_1.14.2-1_arm64.deb ...
Unpacking nvidia-container-toolkit-base (1.14.2-1) ...
Selecting previously unselected package libnvidia-container1:arm64.
Preparing to unpack .../libnvidia-container1_1.14.2-1_arm64.deb ...
Unpacking libnvidia-container1:arm64 (1.14.2-1) ...
Selecting previously unselected package libnvidia-container-tools.
Preparing to unpack .../libnvidia-container-tools_1.14.2-1_arm64.deb ...
Unpacking libnvidia-container-tools (1.14.2-1) ...
Selecting previously unselected package nvidia-container-toolkit.
Preparing to unpack .../nvidia-container-toolkit_1.14.2-1_arm64.deb ...
Unpacking nvidia-container-toolkit (1.14.2-1) ...
Selecting previously unselected package nvidia-container.
Preparing to unpack .../nvidia-container_6.0+b106_arm64.deb ...
Unpacking nvidia-container (6.0+b106) ...
Setting up nvidia-container-toolkit-base (1.14.2-1) ...
Setting up libnvidia-container1:arm64 (1.14.2-1) ...
Setting up libnvidia-container-tools (1.14.2-1) ...
Setting up nvidia-container-toolkit (1.14.2-1) ...
Setting up nvidia-container (6.0+b106) ...
INFO[0000] Config file does not exist; using empty config
INFO[0000] Wrote updated config to /etc/docker/daemon.json
INFO[0000] It is recommended that docker daemon be restarted.
Processing triggers for libc-bin (2.35-0ubuntu3.8) ...
mic-711on@ubuntu:~$ cd ${ISAAC_ROS_WS}/src
git clone -b release-3.1 https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_common.git isaac_ros_common
git clone https://github.com/IntelRealSense/realsense-ros.git -b 4.51.1
fatal: destination path 'isaac_ros_common' already exists and is not an empty directory.
fatal: destination path 'realsense-ros' already exists and is not an empty directory.
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common/scripts && \
touch .isaac_ros_common-config && \
mic-711on@ubuntu:/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common && \
Using configured docker search paths: /mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker
Checking if base image nvcr.io/isaac/ros:aarch64-ros2_humble-realsense-user_32b155f63ddec545d52bb654c4b55f0e exists on remote registry
/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.user
/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.realsense
/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.ros2_humble
/mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.aarch64
Building /mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.aarch64 as image: aarch64-image with base:
[+] Building 1.7s (26/26) FINISHED        docker:default
 => [internal] load metadata for nvcr.io/nvidia/l4t-cuda:12.2.12-devel        1.6s
 => CACHED [stage-0 10/22] RUN python3 -m pip install -U     Cython     pymongo     wheel     scikit-learn     ninja     networkx     "numpy>=1.24.4,<2"     numpy-quaternion     pyyaml     "setupto  0.0s
 => => naming to docker.io/library/aarch64-image        0.0s
 - LegacyKeyValueFormat: "ENV key=value" should be used instead of legacy "ENV key value" format (line 18)
Building /mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.ros2_humble as image: ros2_humble-image with base: aarch64-image
 => WARN: LegacyKeyValueFormat: "ENV key=value" should be used instead of legacy "ENV key value" format (line 17)        0.0s
 => [internal] load metadata for docker.io/library/aarch64-image:latest        0.0s
 => [stage-0  1/22] FROM docker.io/library/aarch64-image:latest        0.0s
 => CACHED [stage-0  4/22] RUN echo "Warning: Using the PYTHONWARNINGS environment variable to silence setup.py and easy_install deprecation warnings caused by colcon"                                0.0s
 => CACHED [stage-0 10/22] RUN --mount=type=cache,target=/var/cache/apt     rosdep init     && echo "yaml file:///etc/ros/rosdep/sources.list.d/nvidia-isaac.yaml" | tee /etc/ros/rosdep/sources.list  0.0s
 => CACHED [stage-0 11/22] RUN --mount=type=cache,target=/var/cache/apt     mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src     && git clone https://github.com/osrf/negotiated && cd negotiat  0.0s
 => CACHED [stage-0 12/22] RUN --mount=type=cache,target=/var/cache/apt     mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src     && git clone https://github.com/ros-perception/image_pipeline.  0.0s
 => CACHED [stage-0 16/22] RUN --mount=type=cache,target=/var/cache/apt     mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src     && git clone https://github.com/ros-planning/moveit_resources.  0.0s
 => CACHED [stage-0 19/22] RUN --mount=type=cache,target=/var/cache/apt     mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src     && git clone https://github.com/ros-planning/moveit2_tutorials  0.0s
 => CACHED [stage-0 21/22] RUN sudo sed -i '917i #ifdef GTEST_INTERNAL_NEED_REDUNDANT_CONSTEXPR_DECL' /usr/src/googletest/googletest/include/gtest/internal/gtest-internal.h     && sudo sed -i '920i  0.0s
 => => naming to docker.io/library/ros2_humble-image        0.0s
Building /mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.realsense as image: realsense-image with base: ros2_humble-image
 => [internal] load metadata for docker.io/library/ros2_humble-image:latest        0.0s
 => [1/7] FROM docker.io/library/ros2_humble-image:latest        0.0s
 => => naming to docker.io/library/realsense-image        0.0s
 - InvalidDefaultArgInFrom: Default value for ARG ${BASE_IMAGE} results in empty or invalid base image name (line 12)
Building /mnt/nova_ssd/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.user as image: isaac_ros_dev-aarch64 with base: realsense-image
 => [internal] load metadata for docker.io/library/realsense-image:latest        0.0s
 => [stage-0  1/11] FROM docker.io/library/realsense-image:latest        0.0s
 => CACHED [stage-0  7/11] COPY scripts/*entrypoint.sh /usr/local/bin/scripts/        0.0s
 => CACHED [stage-0  8/11] RUN  chmod +x /usr/local/bin/scripts/*.sh        0.0s
 => => naming to docker.io/library/isaac_ros_dev-aarch64        0.0s
 - InvalidDefaultArgInFrom: Default value for ARG ${BASE_IMAGE} results in empty or invalid base image name (line 10)
See 'docker run --help'.
Or are there any adjustments that I can make in “run_dev.sh” or “daemon.json”?
Hi @AustinCTH
It looks the same issue. Please try this one to install the NVIDIA Container Toolkit using apt.
https://docs.nvidia.com/datacenter/cloud-native/container-toolkit/latest/install-guide.html#installing-with-apt
Yep it worked! When installing NVIDIA Container Toolkit using apt, it kinda downgrade something, and it worked. Thanks @Ahung !
