ROS Argus Camera dies on Startup
I am using an AGX Xavier to try and use the isaac_ros_argus_camera module via a Docker container. I have followed the instructions here, successfully built the docker container via run_dev.sh, and installed the apt package in the docker as specified. But on runtime, I run into the following error:
[ERROR] [launch_ros.actions.load_composable_nodes]: Failed to load node 'argus_mono' of type 'nvidia::isaac_ros::argus::ArgusMonoNode' in container '/argus_mono_container': Failed to load library: Could not load library dlopen error: libnvToolsExt.so.1: cannot open shared object file: No such file or directory, at /tmp/binarydeb/ros-humble-rcutils-5.1.3/src/shared_library.c:99
The .so file it’s looking for doesn’t seem to exist on the host machine or in the docker container, nor could I figure out how it would normally be installed.
Any help is appreciated.
Hi @reid.christopher1
Thank you for being on the Isaac ROS forum.
Do you have installed your NVIDIA Jetson with Jetpack 5.1.2 following the system requirements?
Best,
Raffaello
It doesn’t look like I do.
apt list nvidia-jetpack returns nothing, and sudo apt installl nvidia-jetpack returns with E: Unable to locate package nvidia-jetpack
apt update looks like it’s having issues finding the apt repository properly:
Get:1 https://download.docker.com/linux/ubuntu bionic InRelease [64.4 kB]
Hit:2 https://nvidia.github.io/libnvidia-container/stable/deb/arm64  InRelease
Hit:3 https://dl-ssl.google.com/linux/chrome/deb stable InRelease
Ign:4 https://repo.download.nvidia.com/jetson/common r32.6.1 InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Hit:6 http://packages.ros.org/ros/ubuntu bionic InRelease
Ign:7 https://repo.download.nvidia.com/jetson/t194 r32.6.1 InRelease
Hit:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
Ign:9 https://repo.download.nvidia.com/jetson/common r32.6.1 Release
Hit:10 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
Ign:11 https://repo.download.nvidia.com/jetson/t194 r32.6.1 Release
Hit:12 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
Ign:13 https://repo.download.nvidia.com/jetson/common r32.6.1/main all Packages
Ign:14 https://repo.download.nvidia.com/jetson/common r32.6.1/main arm64 Packages
Ign:15 https://repo.download.nvidia.com/jetson/common r32.6.1/main Translation-en
Ign:16 https://repo.download.nvidia.com/jetson/common r32.6.1/main Translation-en_US
Ign:17 https://repo.download.nvidia.com/jetson/common r32.6.1/main arm64 DEP-11 Metadata
Ign:18 https://repo.download.nvidia.com/jetson/common r32.6.1/main all DEP-11 Metadata
Ign:19 https://repo.download.nvidia.com/jetson/common r32.6.1/main DEP-11 48x48 Icons
Ign:20 https://repo.download.nvidia.com/jetson/common r32.6.1/main DEP-11 64x64 Icons
Ign:21 https://repo.download.nvidia.com/jetson/common r32.6.1/main all Contents (deb)
Ign:22 https://repo.download.nvidia.com/jetson/common r32.6.1/main arm64 Contents (deb)
Ign:23 https://repo.download.nvidia.com/jetson/common r32.6.1 all Contents (deb)
Ign:24 https://repo.download.nvidia.com/jetson/common r32.6.1 arm64 Contents (deb)
Ign:25 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main all Packages
Ign:26 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main arm64 Packages
Ign:27 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main Translation-en_US
Ign:28 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main Translation-en
Ign:29 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main arm64 DEP-11 Metadata
Ign:30 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main all DEP-11 Metadata
Ign:31 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main DEP-11 48x48 Icons
Ign:32 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main DEP-11 64x64 Icons
Ign:33 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main all Contents (deb)
Ign:34 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main arm64 Contents (deb)
Ign:35 https://repo.download.nvidia.com/jetson/t194 r32.6.1 all Contents (deb)
Ign:36 https://repo.download.nvidia.com/jetson/t194 r32.6.1 arm64 Contents (deb)
Err:14 https://repo.download.nvidia.com/jetson/common r32.6.1/main arm64 Packages
  404  Not Found [IP: 23.221.220.81 443]
Err:26 https://repo.download.nvidia.com/jetson/t194 r32.6.1/main arm64 Packages
Fetched 64.4 kB in 26s (2,435 B/s)
Reading package lists... Done
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'https://dl-ssl.google.com/linux/chrome/deb stable InRelease' doesn't support architecture 'arm64'
E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r32.6.1/main/binary-arm64/Packages  404  Not Found [IP: 23.221.220.81 443]
E: Failed to fetch https://repo.download.nvidia.com/jetson/t194/dists/r32.6.1/main/binary-arm64/Packages  404  Not Found [IP: 23.221.220.81 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
If you didn’t install the NVIDIA Jetpack 5.1.2 I suggest following our official documentation.
I understood that was the issue, that is why I included the errors about apt since one of the ways (and how I was attempting to) install the JetPack SDK was through apt
I am also using the AGX Xavier with Jetpack 5.1.2, but I´m trying to run the apriltag example inside the provided container following the Isaac Ros documentation, but i get the exact same error.
Hi @mreparaz
Welcome to the NVIDIA Isaac ROS forum, Regarding your issue, please follow the other topic Error in trying to run isaac_ros_apriltag quickstart example - #3 by Raffaello
I know this is not in your support scope, but please bear with me for a moment. I am using a Jetson Nano running a custom Ubuntu 22.04 image with ROS2 installed.
I tried using gscam on Jetpack 4.6.4/Ubuntu 18.04 but the lack of hardware acceleration from it forces me to use isaac_ros_argus_camera. I almost got it running but i am getting the same error as OP.
Although libnvToolsExt.so exists in /usr/local/cuda/lib64/ on my device.
Is there anything i can do to make this work, even though i don’t have Jetpack 5.1.2 installed?
Thanks in advance!
Hi @julius.n
You are working with a custom installation, and I don’t have experience with this type of setup.
I suggest opening a new post on Jetson Embedded forum asking just about gscam or the libnvToolsExt.so library
Best,
Raffaello
Thank you for your help. I will do that.
