Hi! I have problems with the Isaac ROS container on JetPack 5.1.1(ubuntu 20.04, ROS2 humble). To work with Leopard IMX390 cameras, apparently I need the isaac_ros_argus_camera package. I am working with the v0.30.0-dp branch of the isaac_ros_common repository. I’ve customized Dockerfile.ros2_humble a bit:
Dockerfile.aarch64.ros2_humble.txt (11.6 KB)
the container starts without problems:
Running isaac_ros_dev-aarch64-container
Get:1 http://ports.ubuntu.com/ubuntu-ports focal InRelease [265 kB]
Get:2 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/sbsa InRelease [1,579 B]
Get:3 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/sbsa Packages [1,181 kB]
Get:4 http://packages.ros.org/ros2/ubuntu focal InRelease [4,685 B]
Get:5 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [128 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease [128 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease [128 kB]
Get:8 http://packages.ros.org/ros2/ubuntu focal/main arm64 Packages [1,173 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports focal/restricted arm64 Packages [1,317 B]
Get:10 http://ports.ubuntu.com/ubuntu-ports focal/main arm64 Packages [1,234 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports focal/universe arm64 Packages [11.1 MB]
Get:12 http://ports.ubuntu.com/ubuntu-ports focal/multiverse arm64 Packages [139 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports focal-updates/multiverse arm64 Packages [12.0 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 Packages [3,369 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports focal-updates/restricted arm64 Packages [58.9 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 Packages [1,446 kB]
Get:17 http://ports.ubuntu.com/ubuntu-ports focal-backports/main arm64 Packages [54.8 kB]
Get:18 http://ports.ubuntu.com/ubuntu-ports focal-backports/universe arm64 Packages [27.8 kB]
Get:19 http://ports.ubuntu.com/ubuntu-ports focal-security/multiverse arm64 Packages [5,924 B]
Get:20 http://ports.ubuntu.com/ubuntu-ports focal-security/universe arm64 Packages [1,159 kB]
Get:21 http://ports.ubuntu.com/ubuntu-ports focal-security/restricted arm64 Packages [58.6 kB]
Get:22 http://ports.ubuntu.com/ubuntu-ports focal-security/main arm64 Packages [2,996 kB]
Fetched 24.7 MB in 4s (6,183 kB/s)
Reading package lists... Done
reading in sources list data from /etc/ros/rosdep/sources.list.d
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/osx-homebrew.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/base.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/python.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/ruby.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/releases/fuerte.yaml
Query rosdistro index https://raw.githubusercontent.com/ros/rosdistro/master/index-v4.yaml
Skip end-of-life distro "ardent"
Skip end-of-life distro "bouncy"
Skip end-of-life distro "crystal"
Skip end-of-life distro "dashing"
Skip end-of-life distro "eloquent"
Skip end-of-life distro "foxy"
Skip end-of-life distro "galactic"
Skip end-of-life distro "groovy"
Add distro "humble"
Skip end-of-life distro "hydro"
Skip end-of-life distro "indigo"
Add distro "iron"
Skip end-of-life distro "jade"
Add distro "jazzy"
Skip end-of-life distro "kinetic"
Skip end-of-life distro "lunar"
Skip end-of-life distro "melodic"
Add distro "noetic"
Add distro "rolling"
updated cache in /home/admin/.ros/rosdep/sources.cache
udev: unrecognized service
After " Add the repository to your apt sources.":
wget -qO - https://isaac.download.nvidia.com/isaac-ros/repos.key | sudo apt-key add -
grep -qxF "deb https://isaac.download.nvidia.com/isaac-ros/ubuntu/main $(lsb_release -cs) main" /etc/apt/sources.list || \
echo "deb https://isaac.download.nvidia.com/isaac-ros/ubuntu/main $(lsb_release -cs) main" | sudo tee -a /etc/apt/sources.list
sudo apt-get update
we have
Hit:1 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:2 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/sbsa InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Hit:6 http://packages.ros.org/ros2/ubuntu focal InRelease
Get:7 https://isaac.download.nvidia.com/isaac-ros/ubuntu/main focal InRelease [4,316 B]
Get:8 https://isaac.download.nvidia.com/isaac-ros/ubuntu/main focal/main arm64 Packages [514 kB]
Fetched 519 kB in 1s (463 kB/s)
When I try to install a package ros-humble-isaac-ros-argus-camera, I get problems with dependencies:
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ros-humble-isaac-ros-argus-camera : Depends: ros-humble-isaac-ros-image-proc but it is not going to be installed
Depends: ros-humble-isaac-ros-nitros but it is not going to be installed
Depends: ros-humble-isaac-ros-nitros-camera-info-type but it is not going to be installed
Depends: ros-humble-isaac-ros-nitros-image-type but it is not going to be installed
If we try to install these packages, we will eventually stop at negotiated packages.
ros2 pkg list shows that these packages are there:
negotiated
negotiated_examples
negotiated_interfaces
Next, I try to install the package manually according to the documentation:
rosdep install --from-paths /workspaces/isaac_ros-dev/src/isaac_ros_argus_camera --ignore-src -y
ERROR: the following packages/stacks could not have their rosdep keys resolved
to system dependencies:
isaac_ros_argus_camera: Cannot locate rosdep definition for [gxf_isaac_timestamp_correlator]
gxf_isaac_camera_utils: Cannot locate rosdep definition for [gxf_isaac_messages]
If you do not pay attention to the result of rosdep and run the build:
colcon build --symlink-install --packages-up-to isaac_ros_argus_camera
Starting >>> isaac_ros_common
Starting >>> isaac_ros_test
--- stderr: isaac_ros_common
CMake Error at CMakeLists.txt:22 (find_package):
By not providing "Findvpi.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "vpi", but
CMake did not find one.
Could not find a package configuration file provided by "vpi" with any of
the following names:
vpiConfig.cmake
vpi-config.cmake
Add the installation prefix of "vpi" to CMAKE_PREFIX_PATH or set "vpi_DIR"
to a directory containing one of the above files. If "vpi" provides a
separate development package or SDK, be sure it has been installed.
Failed <<< isaac_ros_common [1.48s, exited with code 1]
Aborted <<< isaac_ros_test [1.63s]
Summary: 0 packages finished [2.24s]
1 package failed: isaac_ros_common
1 package aborted: isaac_ros_test
1 package had stderr output: isaac_ros_common
2 packages not processed
If you use a non-customized dockerfile:
Dockerfile.aarch64.ros2_humble.txt (510 Bytes)
Then with “sudo apt-get install -y ros-humble-isaac-ros-argus-camera” we have the same dependency(negotiated) problem as before. ros2 pkg list still says that packages exist.
When building from source, rosdep still complains about the lack of:
and when trying to build, the result is slightly different:
we have this if we have GXF and NITROS repositories on the host and the docker image is assembled with .isaac_ros_common-config:
CONFIG_IMAGE_KEY=ros2_humble.user.gxf
CONFIG_DOCKER_SEARCH_DIRS=(…/…/gxf/docker)
The build GXF in the container itself failed
colcon build --symlink-install --packages-up-to isaac_ros_argus_cameracolcon build --symlink-install --packages-up-to isaac_ros_argus_camera
Finished <<< isaac_ros_test [3.49s]
Finished <<< isaac_ros_common [9.66s]
Starting >>> isaac_ros_gxf
Starting >>> isaac_ros_nitros_interfaces
Starting >>> gxf_isaac_timestamp_correlator
Finished <<< gxf_isaac_timestamp_correlator [3.68s]
Finished <<< isaac_ros_gxf [5.36s]
Starting >>> gxf_isaac_gems
Starting >>> gxf_isaac_message_compositor
Starting >>> gxf_isaac_optimizer
Starting >>> gxf_isaac_sight
Starting >>> gxf_isaac_argus
Finished <<< isaac_ros_nitros_interfaces [9.14s]
Finished <<< gxf_isaac_optimizer [4.30s]
Finished <<< gxf_isaac_sight [4.41s]
Finished <<< gxf_isaac_message_compositor [4.52s]
Finished <<< gxf_isaac_argus [4.44s]
Finished <<< gxf_isaac_gems [4.85s]
Starting >>> gxf_isaac_atlas
Starting >>> gxf_isaac_gxf_helpers
Starting >>> gxf_isaac_messages
Finished <<< gxf_isaac_atlas [3.73s]
Finished <<< gxf_isaac_gxf_helpers [3.75s]
Finished <<< gxf_isaac_messages [3.83s]
Starting >>> gxf_isaac_camera_utils
--- stderr: gxf_isaac_camera_utils
CMake Error at /workspaces/isaac_ros-dev/install/isaac_ros_gxf/share/isaac_ros_gxf/cmake/export_isaac_ros_gxfExport.cmake:56 (set_target_properties):
The link interface of target "isaac_ros_gxf::Core" contains:
magic_enum::magic_enum
but the target was not found. Possible reasons include:
* There is a typo in the target name.
* A find_package call is missing for an IMPORTED target.
* An ALIAS target is missing.
Call Stack (most recent call first):
/workspaces/isaac_ros-dev/install/isaac_ros_gxf/share/isaac_ros_gxf/cmake/ament_cmake_export_targets-extras.cmake:9 (include)
/workspaces/isaac_ros-dev/install/isaac_ros_gxf/share/isaac_ros_gxf/cmake/isaac_ros_gxfConfig.cmake:41 (include)
/workspaces/isaac_ros-dev/install/gxf_isaac_gems/share/gxf_isaac_gems/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
/workspaces/isaac_ros-dev/install/gxf_isaac_gems/share/gxf_isaac_gems/cmake/gxf_isaac_gemsConfig.cmake:41 (include)
/opt/ros/humble/install/share/ament_cmake_auto/cmake/ament_auto_find_build_dependencies.cmake:67 (find_package)
CMakeLists.txt:26 (ament_auto_find_build_dependencies)
CMake Error at /workspaces/isaac_ros-dev/install/gxf_isaac_messages/share/gxf_isaac_messages/cmake/export_gxf_isaac_messagesExport.cmake:56 (set_target_properties):
The link interface of target "gxf_isaac_messages::gxf_isaac_messages"
contains:
/workspaces/isaac_ros-dev/install/gxf_isaac_messages/share/gxf_isaac_messages/cmake/ament_cmake_export_targets-extras.cmake:9 (include)
/workspaces/isaac_ros-dev/install/gxf_isaac_messages/share/gxf_isaac_messages/cmake/gxf_isaac_messagesConfig.cmake:41 (include)
CMake Generate step failed. Build files cannot be regenerated correctly.
Failed <<< gxf_isaac_camera_utils [3.54s, exited with code 1]
Aborted <<< isaac_ros_nitros [3.91s]
Summary: 13 packages finished [28.1s]
1 package failed: gxf_isaac_camera_utils
1 package aborted: isaac_ros_nitros
2 packages had stderr output: gxf_isaac_camera_utils isaac_ros_nitros
3 packages not processed
It’s without GXF/NITROS repositories:
admin@EAC-6000:/workspaces/isaac_ros-dev$ rosdep install --from-paths /workspaces/isaac_ros-dev/src/isaac_ros_argus_camera --ignore-src -y
admin@EAC-6000:/workspaces/isaac_ros-dev$ colcon build --symlink-install --packages-up-to isaac_ros_argus_camera
Finished <<< isaac_ros_test [3.06s]
Finished <<< isaac_ros_common [9.63s]
In file included from /workspaces/isaac_ros-dev/src/isaac_ros_argus_camera/gxf_isaac_camera_utils/gxf/extensions/camera_utils/camera_utils.cpp:17:
/workspaces/isaac_ros-dev/src/isaac_ros_argus_camera/gxf_isaac_camera_utils/gxf/extensions/camera_utils/stereo_camera_synchronizer.hpp:19:10: fatal error: gxf/std/codelet.hpp: No such file or directory
19 | #include "gxf/std/codelet.hpp"
compilation terminated.
In file included from /workspaces/isaac_ros-dev/src/isaac_ros_argus_camera/gxf_isaac_camera_utils/gxf/extensions/camera_utils/stereo_camera_synchronizer.cpp:18:
make[2]: *** [CMakeFiles/gxf_isaac_camera_utils.dir/build.make:76: CMakeFiles/gxf_isaac_camera_utils.dir/gxf/extensions/camera_utils/camera_utils.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [CMakeFiles/gxf_isaac_camera_utils.dir/build.make:90: CMakeFiles/gxf_isaac_camera_utils.dir/gxf/extensions/camera_utils/stereo_camera_synchronizer.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:137: CMakeFiles/gxf_isaac_camera_utils.dir/all] Error 2
make: *** [Makefile:146: all] Error 2
Failed <<< gxf_isaac_camera_utils [3.47s, exited with code 2]
Summary: 2 packages finished [13.5s]
1 package had stderr output: gxf_isaac_camera_utils
1 package not processed
admin@EAC-6000:/workspaces/isaac_ros-dev$ exit
~/workspaces/isaac_ros-dev/src/isaac_ros_common
