Greetings
In short, the nvidia driver has a maximum pixel clock of 225 MHz, and I can’t apply my screen resolution. But on the nouveau driver everything works correctly, the maximum pixel clock is 305 MHz.
My monitor supports a resolution of 2560x1440@60 (241.50 MHz Pixel Clock) Connected via hdmi
I don’t have this screen resolution in GUI (nvidia-settings), so I added a new mode via xrandr, but I got an error when adding it. The fact is that for some reason, the system does not accept a resolution that has a pixel clock higher than 225 MHz. And I can’t understand why the maximum frequency of 225 Mhz is set in the parameters.
My resolution setup:
$ cvt -r 2560 1440
# 2560x1440 59.95 Hz (CVT 3.69M9-R) hsync: 88.79 kHz; pclk: 241.50 MHz
Modeline “2560x1440R” 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync
When I try to set the resolution, /var/log/Xorg.0.log says:
[ 723.943] (WW) NVIDIA(GPU-0): Validating Mode “2560x1440R”:
[ 723.943] (WW) NVIDIA(GPU-0): Mode Sources: User Specified, RandR Specified
[ 723.943] (WW) NVIDIA(GPU-0): 2560 x 1440 @ 60 Hz
[ 723.943] (WW) NVIDIA(GPU-0): Pixel Clock : 241.50 MHz
[ 723.943] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 2560, 2608
[ 723.943] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 2640, 2720
[ 723.943] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 1440, 1443
[ 723.943] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 1448, 1481
[ 723.943] (WW) NVIDIA(GPU-0): Sync Polarity : +H -V
[ 723.943] (WW) NVIDIA(GPU-0): Mode is rejected: PixelClock (241.5 MHz) too high for
[ 723.943] (WW) NVIDIA(GPU-0): Display Device (Max: 225.0 MHz).
[ 723.943] (WW) NVIDIA(GPU-0): Mode “2560x1440R” is invalid.
When the nvidia driver is loaded, if you look in Xorg.0.log there you can see the following lines:
[ 50.156] (--) NVIDIA(GPU-0):
[ 50.170] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB258 (DFP-1): connected
[ 50.170] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB258 (DFP-1): Internal TMDS
[ 50.170] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB258 (DFP-1) Name Aliases:
[ 50.170] (--) NVIDIA(GPU-0): DFP
[ 50.170] (--) NVIDIA(GPU-0): DFP-1
[ 50.170] (--) NVIDIA(GPU-0): DPY-3
[ 50.170] (--) NVIDIA(GPU-0): HDMI-0
[ 50.170] (--) NVIDIA(GPU-0): DPY-EDID-8d10b4c6-bc31-7a8f-4a55-4e92a2205b6c
[ 50.171] (--) NVIDIA(GPU-0): HDMI-0
[ 50.171] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB258 (DFP-1): 225.0 MHz maximum pixel clock
[ 50.171] (--) NVIDIA(GPU-0): --- EDID for Ancor Communications Inc ASUS PB258 (HDMI-0) ---
[ 50.171] (--) NVIDIA(GPU-0): EDID Version : 1.3
[ 50.171] (--) NVIDIA(GPU-0): Manufacturer : ACI
[ 50.171] (--) NVIDIA(GPU-0): Monitor Name : Ancor Communications Inc ASUS PB258
[ 50.171] (--) NVIDIA(GPU-0): Product ID : 0x25a1
[ 50.171] (--) NVIDIA(GPU-0): 32-bit Serial Number : 0x00002086
[ 50.171] (--) NVIDIA(GPU-0): Serial Number String : F2LMTJ008326
[ 50.171] (--) NVIDIA(GPU-0): Manufacture Date : 2015, week 6
[ 50.171] (--) NVIDIA(GPU-0): DPMS Capabilities : Active Off
[ 50.171] (--) NVIDIA(GPU-0): Input Type : Digital
[ 50.171] (--) NVIDIA(GPU-0): Prefer first detailed timing : Yes
[ 50.171] (--) NVIDIA(GPU-0): Supports GTF : No
[ 50.171] (--) NVIDIA(GPU-0): Maximum Image Size : 550 mm x 310 mm
[ 50.171] (--) NVIDIA(GPU-0): Valid HSync Range : 24.0 kHz - 99.0 kHz
[ 50.171] (--) NVIDIA(GPU-0): Valid VRefresh Range : 23.0 Hz - 76.0 Hz
[ 50.171] (--) NVIDIA(GPU-0): EDID maximum pixel clock : 300.0 MHz
[ 50.171] (--) NVIDIA(GPU-0): CEA-861 extension block # : 0
[ 50.171] (--) NVIDIA(GPU-0): CEA-861 revision : 3
[ 50.171] (--) NVIDIA(GPU-0): IEEE Vendor Registration ID: 00-0c-03
[ 50.171] (--) NVIDIA(GPU-0): Supports YCbCr 4:4:4 : Yes
[ 50.171] (--) NVIDIA(GPU-0): Supports YCbCr 4:2:2 : Yes
[ 50.171] (--) NVIDIA(GPU-0): Supports Basic Audio : Yes
[ 50.171] (--) NVIDIA(GPU-0): Audio Descriptor : 0
[ 50.171] (--) NVIDIA(GPU-0): Audio Format : PCM
[ 50.171] (--) NVIDIA(GPU-0): Maximum Channels : 2
[ 50.171] (--) NVIDIA(GPU-0): Sample Rates : 32KHz, 44KHz, 48KHz, 96KHz
[ 50.171] (--) NVIDIA(GPU-0): Sample Sizes : 16-bits, 20-bits, 24-bits
[ 50.171] (--) NVIDIA(GPU-0): Speaker Allocation Data :
[ 50.171] (--) NVIDIA(GPU-0): Front Left + Front Right
Interestingly, the EDID of the monitor, writes about 300 MHz, but another line
[ 50.171] (–) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB258 (DFP-1): 225.0 MHz maximum pixel clock
writes about 225.00 MHz
But if you boot into the nouveau driver, then in Xorg. 0. log there are such lines:
[ 59.846] (II) modeset(0): Serial No: F2LMTJ008326
[ 59.846] (II) modeset(0): Ranges: V min: 23 V max: 76 Hz, H min: 24 H max: 99 kHz, PixClock max 305 MHz
[ 59.846] (II) modeset(0): Monitor name: ASUS PB258
I have:
Display: ASUS PB258
Linux kernel: 5.4.57
$ inxi -G
Graphics: Device-1: NVIDIA GF114 [GeForce GTX 560] driver: nvidia v: 390.141
Display: server: X.Org 1.20.8 driver: loaded: nvidia resolution: 1920x1080~60Hz
Xorg.0.log on nvidia driver with “debug mode on”: Xorg.0.log.nvidia.gz (33.3 KB)
Xorg.0.log on nouveau driver: Xorg.0.log.nouveau.gz (11.4 KB)
Thanks in advance.
