I also have a MacBookPro with a GT 650M. Its native resolution is 2880x1800.
In my case, when I configured the resolution to 1440x900 in nvidia-settings, there was no panning. Instead, the xfwm4 window manager continued to position everything in the 2880x1800 region, but I could only see the topleft quadrant. Restarting X didn’t help.
I found a way to fix it, though – I ran the command:
xrandr --output DP-2 --scale 0.5x0.5
Using xrandr --verbose, I noticed that xrandr --scale changes the transformation matrix, but apparently NVIDIA’s default scaled resolution setting doesn’t?
This is the xrandr output after running --scale:
DP-2 connected 1440x900+0+0 (0x282) normal (normal left inverted right x axis y axis) 331mm x 207mm
Identifier: 0x281
Timestamp: 6021731
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
Transform: 0.500000 0.000000 0.000000
0.000000 0.500000 0.000000
0.000000 0.000000 1.000000
filter:
CscMatrix: 65536 0 0 0 0 65536 0 0 0 0 65536 0
EDID:
00ffffffffffff0006100fa000000000
10150104a5211578026fb1a7554c9e25
0c505400000001010101010101010101
010101010101ef8340a0b00834703020
36004bcf1000001a000000fc00436f6c
6f72204c43440a202020000000100000
00000000000000000000000000000010
000000000000000000000000000000e7
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: DisplayPort
supported: DisplayPort
ConnectorType: Panel
ConnectorNumber: 0
_ConnectorLocation: 0
2880x1800 (0x282) 337.750MHz +HSync -VSync *current +preferred
h: width 2880 start 2928 end 2960 total 3040 skew 0 clock 111.10KHz
v: height 1800 start 1803 end 1809 total 1852 clock 59.99Hz
Notice how the Transform matrix is (0.5, 0.5, 1.0) along the diagonal.
I was able to persist this change between X restarts by generating an xorg.conf with nvidia-settings, then changing the “metamodes” setting from:
(default xorg.conf with the 2880x1800 resolution – I think? This makes no sense to me.)
Option "metamodes" "nvidia-auto-select +0+0; nvidia-auto-select +0+0 {viewportin=1440x900}"
(xorg.conf after setting 1440x900 scaled resolution in nvidia-settings)
Option "metamodes" "nvidia-auto-select +0+0 {viewportin=1440x900}"
(Fixed – sets the xrandr transformation matrix and everything works.)
Option "metamodes" "nvidia-auto-select +0+0 {transform=(0.5,0,0, 0,0.5,0, 0,0,1)}"
My full screen section is:
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-3"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
I got the idea by reading NVIDIA’s documentation, which explained that ViewPortIn was just shorthand for Transform. I don’t understand what’s going on, but I suppose I got it to work, for now.
