Device: Jetson Nano Devkit(4GB)
os: Jetpack 4.5.1
cuda: 10.2
I am trying to run a use case using caffe model for person detection.
I have the following 2 files:
- Mobile_SSD_deploy.caffemodel
- Mobile_SSD_deploy_prototxt.txt
I ran the following command as usggested by @AastaLLL:
/usr/src/tensorrt/bin/trtexec --deploy=MobileNetSSD_deploy.prototxt.txt --model=MobileNetSSD_deploy.caffemodel --output=detection_out --output=keep_count
And following is the result:
After this when I ran the use case I get the following error:
I tried to find a solution online but not able to fix it.
