**• Hardware Platform: A2
**• DeepStream Version: 6.3
**• NVIDIA GPU Driver Version: 535.154.05
**• Issue Type: bug
I have noticed a bug in our deepstream pipeline that is tricky to re-produce. We have are inferencing on several RTSP camera feeds using the nvurisrcbin
element (full pipeline below). The pipeline is stable for long periods of time and can handle short (a few minutes) amounts of time with cameras disconnected and re-connected. The rtsp-reconnect-interval
is set as 5 and works well to re-connect the streams.
We have recently noticed an issue that after long periods of a single camera being disconnected (tested after 3 days, but possibly re-producible with much smaller time periods) the camera is unable to re-connect via the usual RTSP re-connect loop. At this time we see the error:
121:03:00.320621000 e[332m 1e[00m 0x7f2930011000 e[31;01mERROR e[00m e[00m nvvideoconvert gstnvvideoconvert.c:3712:gst_nvvideoconvert_transform:e[00m Input buffer is not NvBufSurface
121:03:00.320756195 e[332m 1e[00m 0x7f2930011000 e[31;01mERROR e[00m e[00m nvvideoconvert gstnvvideoconvert.c:4095:gst_nvvideoconvert_transform:e[00m buffer transform failed
In the logs and then continue to see the Resetting source rtsp://x.x.x.x:8554/xxx
periodically. I have verified that the I can view the raw RTSP stream independent of deepstream.
Research on this forum suggests that it might be because the nvvideoconvert
is unable to convert the input data type, so perhaps I need to enforce some caps on my pipeline? Any help is much appreciated. Full pipeline below. Note that I am using the python bindings, so the below is a simplified version of our pipeline. Notably, we use the 'create_source_bin` function from the python examples here deepstream_python_apps/apps/deepstream-rtsp-in-rtsp-out/deepstream_test1_rtsp_in_rtsp_out.py at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
nvurisrcbin rtsp-reconnect-interval= 5 cudadec-memtype=0 | nvstreammux live-source=1 | nvinfer | nvtracker | nvdsanalytics | nvstreamdemux | nvvideoconvert | nvdsosd | tee | nvvideoconvert | nvv4l2h264enc | h264parse | rtph264pay | udpsink
