We are using a Jetson Orin NX with JetPack 6.2 (L4T R36.4.3). When we plug in a PCIe-to-USB adapter, the following kernel error appears:
[ 199.690703] xhci_hcd 0007:04:00.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 2 comp_code 13
[ 199.690706] xhci_hcd 0007:04:00.0: Looking for event-dma 00000000fff6e980 trb-start 00000000fff6e110 trb-end 00000000fff6e110 seg-start 00000000fff6e000 seg-end 00000000fff6eff0
Through research, we found that this closely matches the issue described in CVE-2025-22022:
https://ubuntu.com/security/CVE-2025-22022#description
The kernel version in JetPack 6.2 (L4T R36.4.3) is 5.15.148-tegra.
Does the L4T kernel include the fix for this CVE? Or could the above error be caused by a different issue?
Thank you!
