Install SDK MANAGER: Step 02 - 03: Install failed with a general error
Hello SteveNV,
Thanks for your answer. Here ist the full log of SDK Manager
2018-11-12 16:19:36.119 - info: cleaning up engine
2018-11-12 16:19:36.120 - info: installManager cleanup
2018-11-12 16:19:36.128 - info: The overall duration (Download + Install) is 00:20:06
2018-11-12 16:19:36.131 - info:
Download summary of 0 files (0B / 0B)
Download 0 files.
Cached 0 files.
Failed 0 files.
Download started on: .
Download ended on: Mon Nov 12 2018 16:19:36 GMT+0100 (CET).
Download duration: 00:20:06 - avg. download speed: 0B/s (using 2 threads, 1 processes from ).
Download details:
None
2018-11-12 16:19:36.136 - info:
Install summary of 0 components:
Install started on: did not start installing.
Install ended on: 0.
Install duration: 0.000s .
Install idle time: 0.000s .
Real install duration (duration - idle time): 0.000s .
Install 0 components.
- Already Install 0 components.
Install failed 0 files.
Install skipped 0 files.
Install details:
None
2018-11-12 16:19:42.875 - info: packageJson: /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar/package.json
2018-11-12 16:19:43.004 - info: imagesPath: /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar/output/dist/electron/images/
2018-11-12 16:19:43.181 - info: packageJson: /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar/package.json
2018-11-12 16:19:43.318 - info: config:
{ mainRepoURL: ‘https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json’,
PIDServer: ‘P’,
DevZoneServer: ‘P’ }
2018-11-12 16:19:43.330 - info: manifest: {“name”:“sdkmanager”,“version”:“0.9.8”,“revision”:“0”,“buildNumber”:“2002”,“release”:false}
2018-11-12 16:19:43.330 - info: Setting GA parameters: title SDK Manager - Beta 0.9.8.2002 version 0.9.8 dev: 0 internal: false offline false
2018-11-12 16:19:43.330 - info: Initializing GA analytics: SDK Manager - Beta 0.9.8.2002 0.9.8.2002 0 false
2018-11-12 16:19:43.333 - info: Initialized GA visitor with: TrackID: UA-59254929-46 UserID d451674a-036b-53fa-99ae-3e32fb3015d0
2018-11-12 16:19:43.333 - info: GA analytics: setting custom dimensions: UserType, SDKMode, SDKMVersion External UI 0.9.8.2002
2018-11-12 16:19:43.335 - info: mainRepoUrl: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-11-12 16:19:43.336 - info: logging in with l1 url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-11-12 16:20:11.758 - info: devzone signin page did start loading - https://login.developer.nvidia.com/authorize?response_type=code&method=login&state=login&redirect_uri=https%3A%2F%2Fdeveloper.nvidia.com%2Fauth0%2Fcallback&client_id=4jljTejN7RMO9suL0S33gFrYgjHX0VcW&scope=openid%20profile%20email&audience=https%3A%2F%2Fdevzone.auth0.com%2Fuserinfo&sdk-mgr=true
2018-11-12 16:20:13.118 - info: devzone signin page finished loading - https://login.developer.nvidia.com/login?state=PvyseSuDmCR_h7XuX5s0xqMhhcDqL3Zu&client=4jljTejN7RMO9suL0S33gFrYgjHX0VcW&protocol=oauth2&response_type=code&method=login&redirect_uri=https%3A%2F%2Fdeveloper.nvidia.com%2Fauth0%2Fcallback&scope=openid%20profile%20email&audience=https%3A%2F%2Fdevzone.auth0.com%2Fuserinfo&sdk-mgr=true
2018-11-12 16:20:13.238 - info: devzone signin page did start loading - https://login.developer.nvidia.com/login?state=PvyseSuDmCR_h7XuX5s0xqMhhcDqL3Zu&client=4jljTejN7RMO9suL0S33gFrYgjHX0VcW&protocol=oauth2&response_type=code&method=login&redirect_uri=https%3A%2F%2Fdeveloper.nvidia.com%2Fauth0%2Fcallback&scope=openid%20profile%20email&audience=https%3A%2F%2Fdevzone.auth0.com%2Fuserinfo&sdk-mgr=true
2018-11-12 16:20:35.940 - info: devzone signin page did start loading - https://login.developer.nvidia.com/login?state=PvyseSuDmCR_h7XuX5s0xqMhhcDqL3Zu&client=4jljTejN7RMO9suL0S33gFrYgjHX0VcW&protocol=oauth2&response_type=code&method=login&redirect_uri=https%3A%2F%2Fdeveloper.nvidia.com%2Fauth0%2Fcallback&scope=openid%20profile%20email&audience=https%3A%2F%2Fdevzone.auth0.com%2Fuserinfo&sdk-mgr=true
2018-11-12 16:20:37.486 - info: Devzone login succeeded
2018-11-12 16:20:37.487 - info: devzone login status - login-success
2018-11-12 16:20:37.498 - info: Logging in with devzone login method…
2018-11-12 16:20:37.524 - info: Retrieving Data…
2018-11-12 16:20:37.525 - info: devzone getUserProfile starts…
2018-11-12 16:20:37.982 - info: devzone getUserProfile success, took 0.457s
2018-11-12 16:20:37.982 - info: the DevZone programs that user can access:
2018-11-12 16:20:37.983 - info: { id: 874688, name: NVIDIA Developer Program }
2018-11-12 16:20:37.983 - info: { id: 876061, name: NVIDIA DRIVE™ Developer Program }
2018-11-12 16:20:38.032 - info: Processing Data…
2018-11-12 16:20:38.056 - info: Begin to create timing task for auto update.
2018-11-12 16:20:38.060 - info: Checking for update with mainRepoURL: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-11-12 16:20:38.145 - info: sdkml1_repo.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json has been downloaded to /home/ai-drivepx/.nvsdkm/dist successfully.
2018-11-12 16:20:38.206 - info: sdkml2_sdkm.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKM-APP/sdkml2_sdkm.json has been downloaded to /home/ai-drivepx/.nvsdkm/dist successfully.
2018-11-12 16:20:38.210 - info: packageJson: /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar/package.json
2018-11-12 16:20:38.213 - info: Create timing task for auto update successfully.
2018-11-12 16:20:38.239 - info: level1 url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2018-11-12 16:20:38.288 - info: sdkml1_repo.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json has been downloaded to /home/ai-drivepx/.nvsdkm/dist successfully.
2018-11-12 16:20:38.366 - info: sdkml2_drive_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/Linux/sdkml2_drive_linux.json has been downloaded to /home/ai-drivepx/.nvsdkm/dist successfully.
2018-11-12 16:20:38.385 - info: sdkml2_sdkm.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKM-APP/sdkml2_sdkm.json has been downloaded to /home/ai-drivepx/.nvsdkm/dist successfully.
2018-11-12 16:20:38.388 - info: validating product line for target OS: Linux
2018-11-12 16:20:38.392 - info: validating release: DRIVE Software 1.0
2018-11-12 16:20:38.394 - info: validating release: DRIVE OS 5.0.10.3 SDK with DriveWorks
2018-11-12 16:20:38.395 - info: validating release: DRIVE OS 5.0.10.3 PDK
2018-11-12 16:20:38.396 - info: validating release: DRIVE OS 5.0.13.0 SDK
2018-11-12 16:20:38.406 - info: validating release: DRIVE OS 5.0.13.0 PDK
2018-11-12 16:20:38.407 - warn: No access to devzone program id 879192
2018-11-12 16:20:38.408 - info: Can access to devzone program id 876061
2018-11-12 16:20:38.408 - warn: No access to devzone program id -1
2018-11-12 16:20:38.409 - warn: Empty devzone program id, user can access this program
2018-11-12 16:20:38.418 - warn: No access to release DRIVE Software 1.0
2018-11-12 16:20:38.419 - warn: No access to release DRIVE OS 5.0.10.3 PDK
2018-11-12 16:20:38.420 - info: sdkml2_drive_qnx.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/QNX/sdkml2_drive_qnx.json has been downloaded to /home/ai-drivepx/.nvsdkm/dist successfully.
2018-11-12 16:20:38.430 - info: validating product line for target OS:
2018-11-12 16:20:38.432 - info: validating product line for target OS: QNX
2018-11-12 16:20:38.435 - info: validating release: DRIVE OS 5.0.13.0 SDK
2018-11-12 16:20:38.437 - info: validating release: DRIVE OS 5.0.13.0 PDK
2018-11-12 16:20:38.437 - warn: Empty devzone program id, user can access this program
2018-11-12 16:20:38.587 - info: devzone signin page finished loading - https://developer.nvidia.com/
2018-11-12 16:20:39.095 - error: {“Message”:“Invalid token”,“Status”:“Forbidden”,“StatusCode”:403,“Output”:null}
2018-11-12 16:20:39.096 - warn: No access to release DRIVE OS 5.0.13.0 SDK
2018-11-12 16:20:39.102 - error: {“Message”:“Invalid token”,“Status”:“Forbidden”,“StatusCode”:403,“Output”:null}
2018-11-12 16:20:39.103 - warn: No access to release DRIVE OS 5.0.13.0 PDK
2018-11-12 16:20:39.112 - error: {“Message”:“Invalid token”,“Status”:“Forbidden”,“StatusCode”:403,“Output”:null}
2018-11-12 16:20:39.113 - warn: No access to release DRIVE OS 5.0.13.0 PDK
2018-11-12 16:20:39.133 - error: {“Message”:“Invalid token”,“Status”:“Forbidden”,“StatusCode”:403,“Output”:null}
2018-11-12 16:20:39.134 - warn: No access to release DRIVE OS 5.0.13.0 SDK
2018-11-12 16:20:39.140 - info: step1 load in ms: 900.260000000002
2018-11-12 16:20:53.547 - info: initializeGroups. User selections: Product: DRIVE Version: 5.0.10.3 OS selectedHW: host_target selectedTargetId: PX2_AUTOCHAUFFEUR selectedOS: Linux
2018-11-12 16:20:53.737 - info: EulaFolder: /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/Eula/
2018-11-12 16:20:54.477 - info: sdkml3_drive_linux_50103_sdk_os.json from https://developer.nvidia.com/drive/secure/drive_bundles/Drive_50103L_SDK_b135_OS_GA/sdkml3_drive_linux_50103_sdk_os.json has been downloaded to /home/ai-drivepx/.nvsdkm/dist successfully.
2018-11-12 16:20:54.481 - info: updateData level3 data
2018-11-12 16:20:54.505 - info: engine init InstallProxy
2018-11-12 16:20:54.517 - info: looking for install adapter from /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils
2018-11-12 16:20:56.132 - info: running /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_COMP -v=9.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/ai-drivepx/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-11-12 16:20:56.141 - info: running /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/ai-drivepx/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-11-12 16:20:56.150 - info: running /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_CROSS_COMPILATION_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/ai-drivepx/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-11-12 16:20:56.165 - info: running /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_SAMPLES_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/ai-drivepx/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS
2018-11-12 16:20:56.175 - info: Using GenericInstaller to query NV_CUDA_HOST_COMP
2018-11-12 16:20:56.175 - info: Using GenericInstaller to query NV_DRIVEWORKS_HOST_COMP
2018-11-12 16:20:56.175 - info: Using GenericInstaller to query NV_DRIVEWORKS_CROSS_COMPILATION_COMP
2018-11-12 16:20:56.181 - error: package [{cuda-toolkit-9-2 9.2}] not installed
2018-11-12 16:20:56.183 - info: finishing /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_COMP -v=9.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/ai-drivepx/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-11-12 16:20:56.223 - info: finishing /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/ai-drivepx/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-11-12 16:20:56.265 - info: finishing /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_CROSS_COMPILATION_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/ai-drivepx/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-11-12 16:20:56.284 - info: finishing /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/adapter -a=query -i=NV_DRIVEWORKS_HOST_SAMPLES_COMP -v=1.2 -b=NV_DRIVE_LINUX_BUNDLE -u=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil -x=SDK -c=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 -L=/home/ai-drivepx/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS with exit code 1
2018-11-12 16:20:56.432 - error: package [{driveworks_data 1.2.400}] not installed
2018-11-12 16:20:56.433 - info: Using GenericInstaller to query NV_DRIVEWORKS_HOST_SAMPLES_COMP
2018-11-12 16:20:56.433 - error: package [{driveworks_cross_linux 1.2.400}] not installed
2018-11-12 16:20:56.434 - error: package [{driveworks_samples 1.2.400}] not installed
2018-11-12 16:21:09.117 - info: Error accessing /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA: No such file or directory
2018-11-12 16:21:09.118 - error: command terminated with error
2018-11-12 16:21:09.118 - error: completeSetup failed command < pkexec --user root /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/sudo_daemon -installer=5867 -d=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/tmp > terminated with error
2018-11-12 16:21:09.119 - error: install process failure command < pkexec --user root /home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/sudo_daemon -installer=5867 -d=/home/ai-drivepx/Schreibtisch/DrivePx/NVIDIA SDK Manager/resources/app.asar.unpacked/output/installUtils/tmp > terminated with error
2018-11-12 16:21:15.097 - info: exporting logs from /home/ai-drivepx/.nvsdkm/logs
2018-11-12 16:21:15.335 - info: Exported 1 log files to /home/ai-drivepx/Downloads/nvidia/sdkm_downloads/SDKM_logs_11122018_1621.zip
Please help us to fix that problem.
Thanks in advance.
zml-koop
