I’m trying to install the Cuda 9.0 but installer everytime is failing. Here is my Setup LOG.
1.315 | SYSTEM: [NVI2.NVInstaller] 86@CNVInstaller::PerformSteps : Performing install steps, via module C:\Program Files\NVIDIA Corporation\Installer2\CoreTemp.{F563E06A-1FC8-4BB0-A3D1-21551776CB0E}\NVI2.DLL version 2.1002.291.0 - date "2018-05-22T22:00:54.000" - command ""C:\Users\umutb\AppData\Local\Temp\CUDA\setup.exe" -log:"C:\log" -loglevel6".
1.315 | SYSTEM: [NVI2.NVInstaller] 92@CNVInstaller::PerformSteps : Running on Windows 10.0.17134 - Arch ID: 9 - Wow-64 check: "true".
44.122 | ERROR: [NVI2.InstallThread] 54@CInstallThread::ThreadProc : Install failed - Exception {0xe0e00001; File: InstallationStepper.cpp; Line: 255} - going to fail state.
44.220 | ERROR: [NVI2.NVInstaller] 242@CNVInstaller::PerformSteps : Installation failed with error Exception {0xe0e00001; File: SimpleThread.h; Line: 228}.
0.323 | SYSTEM: [NVI2.NVInstaller] 86@CNVInstaller::PerformSteps : Performing install steps, via module C:\Program Files\NVIDIA Corporation\Installer2\CoreTemp.{5284F46E-0A64-4016-B642-7BC623EFA4CC}\NVI2.DLL version 2.1002.291.0 - date "2018-05-22T22:00:54.000" - command "setup.exe -log:"C:\log" -loglevel6".
0.323 | SYSTEM: [NVI2.NVInstaller] 92@CNVInstaller::PerformSteps : Running on Windows 10.0.17134 - Arch ID: 9 - Wow-64 check: "true".
44.245 | ERROR: [NVI2UI.HtmlSharedControlScripting] 2098@CHtmlSharedControlScripting::error : "Presentation response bad format - code = 200 response = ".
45.643 | ERROR: [UpdateCore.UpdateCoreExtSite] 560@CUpdateCoreExtSite::ReportUpdateCoreTasksState : Failed to load NvTelemetryStatusReporter.dll: 126.
45.645 | ERROR: [UpdateCore.UpdateCoreExtSite] 560@CUpdateCoreExtSite::ReportUpdateCoreTasksState : Failed to load NvTelemetryStatusReporter.dll: 126.
45.646 | ERROR: [UpdateCore.UpdateCoreExtSite] 560@CUpdateCoreExtSite::ReportUpdateCoreTasksState : Failed to load NvTelemetryStatusReporter.dll: 126.
104.486 | ERROR: [UpdateCore.UpdateCoreExtSite] 560@CUpdateCoreExtSite::ReportUpdateCoreTasksState : Failed to load NvTelemetryStatusReporter.dll: 126.
104.487 | ERROR: [UpdateCore.UpdateCoreExtSite] 560@CUpdateCoreExtSite::ReportUpdateCoreTasksState : Failed to load NvTelemetryStatusReporter.dll: 126.
153.221 | ERROR: [NVI2.NVMsiPhase] 853@CNVMsiPhase::InvokePhase : COM error: -2147467259.
153.223 | ERROR: [NVI2.NVInstaller] 2064@CNVInstaller::InternalPerformInstall : Package "visual_studio_integration_9.0" failed with error: Exception {0x80004005 - Belirtilmemiş hata; File: PerformInstall.cpp; Line: 4029; Phase failure}.
153.223 | ERROR: [NVI2.NVInstaller] 2123@CNVInstaller::InternalPerformInstall : Failing at package "visual_studio_integration_9.0" failed with error: Exception {0x80004005 - Belirtilmemiş hata} - aborting install.
153.226 | ERROR: [NVI2.InstallThread] 54@CInstallThread::ThreadProc : Install failed - Exception {0x80004005 - Belirtilmemiş hata; File: PerformInstall.cpp; Line: 4029; Phase failure} - going to fail state.
