Hello, I’ve been using CUDA 8 with visual studio 2015 up until now and decided to upgrade to CUDA 9 and visual studio 2017. So, I went ahead and installed visual studio, then went ahead and downloaded Windows 7 version of the toolkit, but it fails to install every time I try. The only way I managed to force it to install the runtime itself was to uncheck visual studio integration and it went smoothly. (note: I did this more than once and I’m 100% sure, I used win7 version, unless there’s some issue on the website itself)
There were no issues on my laptop with windows 10, but I can’t seem to be getting any luck on my primary PC, that is still running windows 7. Can anyone suggest what might be the issue?
Here are a few lines from the log, that were marked as “ERROR”:
71.243 | ERROR: [NVI2.NVOsConstraint] 87@CNVOsConstraint::PerformOperatingSystemCheck : Minimum OS version check fail - Version: 6.1.7601 < 6.3.
88.141 | ERROR: [NVI2UI.HtmlSharedControlScripting] 2061@CHtmlSharedControlScripting::error : "Presentation response bad format - code = 200 response = ".
97.825 | ERROR: [UpdateCore.UpdateCoreExtSite] 557@CUpdateCoreExtSite::ReportUpdateCoreTasksState : Failed to load NvTelemetryStatusReporter.dll: 126.
97.826 | ERROR: [UpdateCore.UpdateCoreExtSite] 557@CUpdateCoreExtSite::ReportUpdateCoreTasksState : Failed to load NvTelemetryStatusReporter.dll: 126.
103.519 | ERROR: [NVI2.NVMsiPhase] 826@CNVMsiPhase::InvokePhase : Caught exception Exception {0x80070643 - Fatal error during installation.; File: NVMsiPhase.cpp; Line: 75}.
103.523 | ERROR: [NVI2.NVInstaller] 1984@CNVInstaller::InternalPerformInstall : Package "visual_studio_integration_9.0" failed with error: Exception {0x80070643 - Fatal error during installation.; File: PerformInstall.cpp; Line: 3949; Phase failure}.
103.523 | ERROR: [NVI2.NVInstaller] 2043@CNVInstaller::InternalPerformInstall : Failing at package "visual_studio_integration_9.0" failed with error: Exception {0x80070643 - Fatal error during installation.} - aborting install.
103.524 | ERROR: [NVI2.InstallThread] 54@CInstallThread::ThreadProc : Install failed - Exception {0x80070643 - Fatal error during installation.; File: PerformInstall.cpp; Line: 3949; Phase failure} - going to fail state.
105.280 | ERROR: [NVI2.NVInstaller] 240@CNVInstaller::PerformSteps : Installation failed with error Exception {0x80070002 - The system cannot find the file specified.; File: FilePath.cpp; Line: 664; GetLastError()}.
