Installation of Nsight Systems for JetPack 5.0.1 Developer Preview
I am trying to install Nsight Systems on Jetson AGX Orin with Jetpack 5.0.1 Developer Preview.
Nsight systems was not installed initially, so trying to install it additionally using sdkmanager.
I can see Nsight Systems 2021.5 is for 5.0.1 DP.
However, JetPack 5.0.1 DP is not available when doing “docker run -it --rm sdkmanager --cli --archived-versions”
JetPack 5.0.2 is available which is the closet version to 5.0.1 DP, but it supports Nsight Systems 2022.3.
How shall I install nsight systems Nsight Systems 2021.5?
The JetPack 5.0.1 is a developer preview version, and a bit too old.
Please use the latest JP6.2.
Hello @kayccc
20250314
Below issue was due to host machine setting (sudo required password twice).
sdkmanager works in another machine.
I am facing sudo validation error in using sdkmanager to install JP6.2.
After selecting required components to be installed, a box for password pops up to validate sudo right like below.
It fails somehow even if inputting correct password.
May I ask workaround?
Install Jetson Software with SDK Manager — SDK Manager
The latest version V2.2.0.12028 is used.
SDK Manager | NVIDIA Developer
No support is required.
The issue was due to LInux PAM setting.
JetPack 6.2 could be installed.
