Hi Community,
I recently bought a new desktop with Nvidia NVS 315 installed, and planned to run some simple Cuda
code on it. Below is the procedure I did in order to run Cuda code. (command is included inside the quotation marks)
I typed “sudo apt-get install nvidia-cuda-toolkit”, therefore “nvcc --version” outputs the version of nvcc is 5.5. My OS version is Ubuntu 14.04. I also typed “nvidia-smi” to output the driver version, which is 331.113.
testing cuda code: 1) simple vector addition. C[i] = A[i] + B[i]; A and B are vectors with value of 1. It seems the GPU doesn’t do the computation because C[i] is 0.
2) cudaDeviceProp.cu program. It outputs endless Cuda devices up to 30,000, and I CTRL + C to kill the
output, and the Major revision number is 1191520582. Obviously, it indicates CUDA is not installed properly.
I installed NVCC toolkit, and driver seems also in use. Why I still not be able to run cuda code?
Any input is welcome. Thank you.
