Hello
I am trying to install tensorflow on my Jetson TX2 and am therefor following this tutorial from Jetsonhacks: Deprecated - See description TensorFlow Install on NVIDIA Jetson TX2 - YouTube
When trying to execute ./setTensorflowEV.sh I get the following output:
~/installTensorFlowTX2$ ./setTensorFlowEV.sh
mkdir: cannot create directory ‘/usr/lib/aarch64-linux-gnu/include/’: File exists
cp: cannot stat '/usr/include/cudnn.h': No such file or directory
You have bazel 0.5.2- installed.
Found possible Python library paths:
/usr/local/lib/python2.7/dist-packages
/usr/lib/python2.7/dist-packages
Please input the desired Python library path to use. Default is [/usr/local/lib/python2.7/dist- packages]
Using python library path: /usr/local/lib/python2.7/dist-packages
Invalid path to CUDA 8.0 toolkit. /usr/local/cuda/lib64/libcudart.so.8.0 cannot be found
The content of the file setTensorflowEV.sh: installTensorFlowTX2/setTensorFlowEV.sh at master · jetsonhacks/installTensorFlowTX2 · GitHub
I tried to locate cudnn.h on my system ($locate cudnn.h), but it isn’t anywhere. I also looked at what I need to install in the shared object (sudo apt-file search libcudart.so.8.0), but that returned nothing neither.
So I would like to know what I can do to not have this error message any more.
Important note: I don’t have physical access to the board to flash it or anything like that
I tried disabling cuda like so TF_CUDA_NEED=0
which gives:
Please input the desired Python library path to use. Default is [/usr/local/lib/python2.7/dist-packages]
Configuration finished
but when trying to build Tensorflow I get:
~/installTensorFlowTX2$ ./buildTensorFlow.sh
ERROR: /home/nvidia/.cache/bazel/_bazel_nvidia/d2751a49dacf4cb14a513ec663770624/external/local_config_cuda/crosstool/BUILD:4:1: Traceback (most recent call last):
File "/home/nvidia/.cache/bazel/_bazel_nvidia/d2751a49dacf4cb14a513ec663770624/external/local_config_cuda/crosstool/BUILD", line 4
error_gpu_disabled()
File "/home/nvidia/.cache/bazel/_bazel_nvidia/d2751a49dacf4cb14a513ec663770624/external/local_config_cuda/crosstool/error_gpu_disabled.bzl", line 3, in error_gpu_disabled
fail("ERROR: Building with --config=c...")
ERROR: Building with --config=cuda but TensorFlow is not configured to build with GPU support. Please re-run ./configure and enter 'Y' at the prompt to build with GPU support.
ERROR: no such target '@local_config_cuda//crosstool:toolchain': target 'toolchain' not declared in package 'crosstool' defined by /home/nvidia/.cache/bazel/_bazel_nvidia/d2751a49dacf4cb14a513ec663770624/external/local_config_cuda/crosstool/BUILD.
INFO: Elapsed time: 0.403s
I don’t have a ./configure script anywhere and set the line like so export TF_NEED_CUDA=0 in [u]my[\u] ./buildTensorFlow.sh file:
#this is my modified buildTensorFlow.sh file
export TF_CUDA_VERSION=8.0
export CUDA_TOOLKIT_PATH=/usr/local/cuda
export TF_CUDNN_VERSION=6.0.21
export CUDNN_INSTALL_PATH=/usr/lib/aarch64-linux-gnu/
export TF_CUDA_COMPUTE_CAPABILITIES=6.2
# Build Tensorflow
cd $HOME/tensorflow
bazel build -c opt --local_resources 3072,4.0,1.0 --verbose_failures --config=cuda //tensorflow/tools/pip_package:build_pip_package
