how do I check If I install CUDA and CUDNN successfully?
I Flash TX2 with JetPack3.1.After it I tested CUDA example successfully!
And I typed nvcc -V on the terminal.it lists:
Copyright (c) 2005-2016 NVIDIA Corporation
Built on Mon_Mar_20_17:07:33_CDT_2017
Cuda compilation tools, release 8.0, V8.0.72
Then I typed: nvidia-smi,the result is:
bash: nvidia-smi: command not found
I typed:
sudo apt-get update
sudo apt-get install nvidia-smi
then it list:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package nvidia-smi is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'nvidia-smi' has no installation candidate
I do not know where is the problem.
Then I checked the folde /usr/local/cuda-8.0/include there is no cudnn.h
so do I successfully intsall CUDA and CuDNN
nvidia-smi is not available on Jetson platform.
If you want to check GPU/CUDA status, please use deviceQuery sample:
$ /usr/local/cuda-8.0/bin/cuda-install-samples-8.0.sh .
$ cd NVIDIA_CUDA-8.0_Samples/1_Utilities/deviceQuery
$ make && ./deviceQuery
CUDA and cuDNN can be installed via JetPack3.1 directly.
cuDNN libraries is located at /usr/lib/aarch64-linux-gnu/
Thanks for your answer.
When I ran the commands above, it cannot found any target file or folder at all.
But I do flash the Jetson TX2 with your Jetpack3.1
Any solution?
THX
Please remember to specify the installation folder to the script.
For example:
$ /usr/local/cuda-8.0/bin/cuda-install-samples-8.0.sh <b>~</b>
This will install CUDA sample to the home directory.
Moreover, according to the article, you can also run ./bandwidthTest:
cd /usr/local/cuda-8.0/samples
sudo make
cd bin/x86_64/linux/release
sudo ./deviceQuery
sudo ./bandwidthTest
This is for cuda 9 but I think i’d work with cuda 8 too:
āžœ pwd
/usr/local/cuda-9.0/bin
āžœ ./nvcc --version
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Sun_Nov_19_03:10:15_CST_2017
Cuda compilation tools, release 9.0, V9.0.252
āžœ
Device : Jetson Nano b01
JetPack Version : 4.4
Command used for checking CUDA version:
cat /usr/local/cuda/version.txt
