I have flashed jetpack 3.3 on TX2 but I can not see CUDA, CUDNN and Tegra Multimedia API.
But I can see cuda-l4t , cudnn , NVIDIA_CUDA-9.0_Samples and tegra_multimedia_api on my host machine instead of TX2 after flashing jetpack. So I copied all these folders to my TX2.
I did following things and got following erros :
- When I build the code present in tegra_multimedia_api folder, it gives following error.
Make in samples/00_video_decode
make[1]: Entering directory ‘/home/nvidia/tegra_multimedia_api/samples/00_video_decode’
Linking: video_decode
/usr/bin/ld: cannot find -lcudart
/usr/bin/ld: cannot find -lnvinfer
/usr/bin/ld: cannot find -lnvparsers
collect2: error: ld returned 1 exit status
Makefile:52: recipe for target ‘video_decode’ failed
make[1]: *** [video_decode] Error 1
make[1]: Leaving directory ‘/home/nvidia/tegra_multimedia_api/samples/00_video_decode’
Makefile:52: recipe for target ‘all’ failed
make: *** [all] Error 1
When I run command “nvcc --version”, it says “nvcc: command not found”.
That means CUDA is not installed.
2)Installing CUDA
I tried installing CUDA using the script “cuda-l4t.sh” present in “cuda-l4t” folder.
The script requires .deb file as input so I downloaded “cuda-repo-ubuntu1604-9-0-local_9.0.176-1_amd64.deb” from NVIDIA’s website.
(Link : https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=x86_64&target_distro=Ubuntu&target_version=1604&target_type=deblocal)
But when I run the script to install CUDA, it gives following error.
dpkg: warning: overriding problem because --force enabled:
dpkg: warning: package architecture (amd64) does not match system (arm64)
Could someone help me fix the above issues #1 and #2 ?
Thanks in advance.
