After an installation with JetPack-L4T-2.3.1-linux-x64.run, CUDA is missing except the following
/usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1
/usr/lib/aarch64-linux-gnu/libcuda.so
ubuntu@tegra-ubuntu:~$ nvidia-detector
none
none
ubuntu@tegra-ubuntu:~ update-pciids
update-pciids: /usr/share/misc/pci.ids.new is read-only
ubuntu@tegra-ubuntu:~ lspci | grep -i nvidia
ubuntu@tegra-ubuntu:~$ uname -m && cat /etc/*release
aarch64
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION=“Ubuntu 16.04 LTS”
R24 (release), REVISION: 2.1, GCID: 8028265, BOARD: t210ref, EABI: aarch64, DATE: Thu Nov 10 03:51:59 UTC 2016
ubuntu@tegra-ubuntu:~$ gcc --version
gcc (Ubuntu/Linaro 5.3.1-14ubuntu2.1) 5.3.1 20160413
Copyright © 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
ubuntu@tegra-ubuntu:~$ uname -r
3.10.96-tegra
As per the 4.3.1.1 section on http://developer.download.nvidia.com/compute/cuda/8.0/secure/prod/docs/sidebar/CUDA_Quick_Start_Guide.pdf?autho=1482994795_0ac284e35bd8e16826302ea4eca8c414&file=CUDA_Quick_Start_Guide.pdf, a worklist happens as below:
scp cuda-repo-l4t-8-0-local_8.0.34-1_arm64.deb JTX1
ubuntu@tegra-ubuntu:~ sudo dpkg --install cuda-repo-l4t-8-0_local_8.0.34-1_arm64.deb
ubuntu@tegra-ubuntu:~ sudo apt-get update
ubuntu@tegra-ubuntu:~ sudo apt-get install cuda-toolkit-8-0
ubuntu@tegra-ubuntu:~ sudo reboot
ubuntu@tegra-ubuntu:~ export PATH=/usr/local/cuda-8.0/bin{PATH:+:{PATH}}
ubuntu@tegra-ubuntu:~ export LD_LIBRARY_PATH=/usr/local/cuda-8.0/lib64${LD_LIBRARY_PATH:+:{LD_LIBRARY_PATH}}
ubuntu@tegra-ubuntu:~ cuda-install-samples-8.0.sh ~
ubuntu@tegra-ubuntu:~ cd ~/NVIDIA_CUDA-8.0_Samples/0_Simple/vectorAdd
ubuntu@tegra-ubuntu:~ make
ubuntu@tegra-ubuntu:~$ ./vectorAdd
ubuntu@tegra-ubuntu:~$ nvcc -V
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2016 NVIDIA Corporation
Built on Fri_Jul_15_14:52:12_CDT_2016
Cuda compilation tools, release 8.0, V8.0.33
