When saying “installed Arduino” do you mean “Arduino IDE” and you have trouble selecting the “serial port” for uploading compiled binary code to the Arduino that is connected via USB to the Nano?
Hi, Yes installed Arduino IDE, downloaded the Arm 64bit version, it either compiled something or downloaded it, lot of text on screen flashed by, as I said I am a noob from the Arduino world so feel a little out of my depth at the moment, but iam told it’s a sharp learning curve and not as difficult as it seems?
I think you are referring to code compiled and sent to Arduino and yes I am unable to upload code to Arduino, I can select the Board i.e Uno, Mega etc… but the ports in the tools drop-down is greyed out.
When the Arduino is connected via the USB serial port it should be “visible” to the Jetson Nano. You should be able to verify that with command “lsusb”, this should give you a listing of devices on the USB bus. See also this video (for Jetson TX1 but should be applicable for the Nano as well):
