I am having trouble installing CUDA 8.0.27 on Ubuntu 16.04, I have a gtx1080, because of the gcc compiler. I can see that you have made a patch available to fix the problem, but I dont know how to use it :)
I have tried to use it as a normal run file:
sudo sh cuda_8.0.27.1_linux.run
but then after following the command-line prompts it complains that there are not CUDA installed as I could not installed the cuda 8.0.27.
“This patch requires the base installer to be installed first.”
So you will need to run the base installer first. If it prompts you that it is not a supported configuration, you should choose the prompt to install anyway.
I’m also using GTX 1080 and running on Ubuntu 16.04.1 LTS (GCC 5.4.0). I haven’t tried the patch and I also haven’t successfully run the test scripts after installing CUDA 8.0.27 RC yet.
That being said…
When running the *.run file you can use the -override flag to ignore the compiler version.
I’m actually trying to take advantage of GPU acceleration in GATE (OpenGATE) via CUDA but I haven’t had the time lately to try the patch. I’ll report back if I ever get it to work once I find the time.
