Installing DeepStream 4 on Nano
Thank you.
I also found out a few more things over the weekend. On Nvidia Zoo there are links to Docker Containers to install the Machine Learning stuff (Deepstream and many others) also for the Deep Learning Institute course I am taking, it is a different SD card image for each course. So in thinking I already had set up my Nano in the previous course it caused me to not be able to find all the info needed for the new course I am taking. Once I downloaded the specific image for the course, Deepstream and the notebooks were all installed. The naming of the SD card image was very close to the other course I took (still a dlinano sign in). A brain cell finally clicked on and I looked closer at the name and it was different. It is now flashed on a separate SD card. I would still like to get one SD card image set up to do all the stuff I want so I am still working on that. I am going to use some of the commands that are in the scripts on the new course SD card image.
I apologize for all the confusion and frustration I showed in this process. Attention to detail is important and I did not practice that.
I appreciate you putting up with me and continuing to support us newbies on the forum.
Kent N Smith
Kent N Smith Consulting Services LLC
No need to apologize. People are imperfect. At least on my part I gave you bad instructions for the same reason. Hope you enjoy the software, and continue asking questions if you need any help. There are no “dumb questions” and this forum gives you the opportunity to speak directly with the engineers, which is rare.
