Hi
I have searched Quickstart Guide — DeepStream 6.3 Release documentation
And noticed that, DS 6.3 for L4T Ubuntu 20.04/Jetpack 5.1.2 GA. And the time of writing, there is deepstream-7.1_7.1.0-1 available.
Latest guide here: Installation — DeepStream documentation suggests
Ubuntu 22.04
GStreamer 1.20.3
NVIDIA driver 535.183.06 (for Data Center GPUs) and 560.35.03 (for RTX GPUs)
CUDA 12.6
TensorRT 10.3.0.26
I’m NOT sure Which DS version for Jetson Orin Nano/Jetpack 5.1.4/L4T 35.6.0?
And Is there any guide(or similar setup steps) avaliable for Jetson Orin Nano/Jetpack 5.1.4/L4T 35.6.0?
@nagesh_accord Thanks.
I didn’t find any direct/specific version related DeepStream TensorRT installation to Jetpack (Sorry)5.1.4 my latest flashed OS .
As NVIDIA jetson software is highly version dependent, especially on their priotery software. And if you installed other versions to try, might be broken some unknow version dependency, then stuck in a mess.
So I want to find their guide on steps first if possible.
Yeah, @nagesh_accord If there is no specific answer. Then maybe I have to try 5.1.2GA steps, which is close to 5.1.4.
But I have met kind of issue on tensorflow, which is very strange, those installtion got my system a mess.
Currently, I’m doing another project, which environment is quite stable. So I’ll wait for a while to see if it’s a direct way to make it happen. If try, try try, then it will be a mess on jetson’s current environment.
Ah, I’m NOT sure if there is a way to dd NVM SSD live system to a usb storage?
You can always install complete jetpack which has cuda and other related packages with the command
Sudo apt-get install jetpack
But this command can’t install DS. Just like tensorflow , not only dependency and installation sequence, and even those installation might get system a mess. Then you will need to re-install the OS.
Especially those higly version dependent software deployment.
Please check the compatibility table. Installation — DeepStream documentation
You can run with DeepStream 6.3 version. If you install JetPack with SDKManager, the corresponding DeepStream SDK is also in the UI to be chosen.
The link also says up to 5.1.2GA / L4T 35.4
OK. I might be close to 5.1.4 /LT35.6
Hmmmm… Currently I don’t have a PC with SDK Manager required resources
Is there any simple way to install, or command line script?
I don’t see the plan to do that as the SDK manager is not only for Jetson, but also for other platform and SDKs.
Sorry for that.
There is no “up to” in the page. The versions between 5.1.2 GA and 6.0 DP are all 5.1.2+ which compatible to DeepStream 6.3.
SDKManager is the standard way to install JetPack.
@DaneLLL Is there any instruction for installing JetPack 5.1.4 and DeepStream 6.3 without SDKManager?
DaneLLL
November 26, 2024, 2:06am
13
Please download the packages:
Jetson Linux | NVIDIA Developer
Driver Package (BSP)
Sample Root Filesystem
And follow the steps to extract and flash system image:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And install DeepStream SDK:
$ sudo apt update
$ sudo apt install deepstream-6.3
I didn’t find any deepstream-6.3 by apt on Jetpack 5.1.4 L4t 35.6.
There are 6.3/6.4/7.x series .
@DaneLLL What do you suggest for my Jetpack 5.1.4 L4t 35.6 Jetson Orin 8GB board?
@Fiona.Chen I think 6.4 is a 6.x series, which might be more ultimate version for L4T 35.6 (ubuntu20.04) , am i right?
daniel@daniel-nvidia:~/Work/jetson-fpv$ sudo apt update
[sudo] password for daniel:
Hit:3 http://packages.ros.org/ros/ubuntu focal InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:1 https://repo.download.nvidia.cn/jetson/common r35.6 InRelease
Hit:2 https://repo.download.nvidia.cn/jetson/t234 r35.6 InRelease
Hit:4 https://repo.download.nvidia.cn/jetson/ffmpeg r35.6 InRelease
Get:6 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [128 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease [128 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease [128 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 DEP-11 Metadata [276 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports focal-updates/restricted arm64 DEP-11 Metadata [212 B]
Get:11 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 DEP-11 Metadata [445 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports focal-updates/multiverse arm64 DEP-11 Metadata [212 B]
Get:13 http://ports.ubuntu.com/ubuntu-ports focal-backports/main arm64 DEP-11 Metadata [5,236 B]
Get:14 http://ports.ubuntu.com/ubuntu-ports focal-backports/restricted arm64 DEP-11 Metadata [216 B]
Get:15 http://ports.ubuntu.com/ubuntu-ports focal-backports/universe arm64 DEP-11 Metadata [30.5 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports focal-backports/multiverse arm64 DEP-11 Metadata [212 B]
Get:17 http://ports.ubuntu.com/ubuntu-ports focal-security/main arm64 DEP-11 Metadata [65.3 kB]
Get:18 http://ports.ubuntu.com/ubuntu-ports focal-security/restricted arm64 DEP-11 Metadata [212 B]
Get:19 http://ports.ubuntu.com/ubuntu-ports focal-security/universe arm64 DEP-11 Metadata [159 kB]
Get:20 http://ports.ubuntu.com/ubuntu-ports focal-security/multiverse arm64 DEP-11 Metadata [212 B]
Fetched 1,366 kB in 8s (166 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
12 packages can be upgraded. Run 'apt list --upgradable' to see them.
daniel@daniel-nvidia:~/Work/jetson-fpv$ sudo apt install deepstream-6.3
E: Unable to locate package deepstream-6.3
E: Couldn't find any package by glob 'deepstream-6.3'
daniel2008_12:
We can’t find any release info, but guess and try: (We DID follow the guide here: Quickstart Guide — DeepStream 6.3 Release documentation )
6.4 on jetpack 5.1.4 has issue.
$ ldd /usr/bin/deepstream-app
/usr/bin/deepstream-app: /lib/aarch64-linux-gnu/libstdc++.so.6: version GLIBCXX_3.4.29' not found (required by /usr/bin/deepstream-app)
/usr/bin/deepstream-app: /lib/aarch64-linux-gnu/libc.so.6: version GLIBC_2.32' not found (required by /usr/bin/deepstream-app)
/usr/bin/deepstream-app: /lib/aarch64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /usr/bin/deepstream-app)
/usr/bin/deepstream-app: /lib/aarch64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_utils.so)
/usr/bin/deepstream-app: /lib/aarch64-linux-gnu/libstdc++.so.6: version GLIBCXX_3.4.29' not found (required by /opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_msgbroker.so)
/usr/bin/deepstream-app: /lib/aarch64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_msgbroker.so)
linux-vdso.so.1 (0x0000ffffaa55f000)
libgstreamer-1.0.so.0 => /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0 (0x0000ffffaa250000)
libgstvideo-1.0.so.0 => /lib/aarch64-linux-gnu/libgstvideo-1.0.so.0 (0x0000ffffaa19b000)
libglib-2.0.so.0 => /lib/aarch64-linux-gnu/libglib-2.0.so.0 (0x0000ffffaa060000)
libgobject-2.0.so.0 => /lib/aarch64-linux-gnu/libgobject-2.0.so.0 (0x0000ffffa9fee000)
libgstrtspserver-1.0.so.0 => /lib/aarch64-linux-gnu/libgstrtspserver-1.0.so.0 (0x0000ffffa9f7b000)
libjson-glib-1.0.so.0 => /lib/aarch64-linux-gnu/libjson-glib-1.0.so.0 (0x0000ffffa9f42000)
libyaml-cpp.so.0.7 => not found
libnvdsgst_meta.so => /opt/nvidia/deepstream/deepstream-6.4/lib/libnvdsgst_meta.so (0x0000ffffa9f2c000)
libnvdsgst_smartrecord.so => /opt/nvidia/deepstream/deepstream-6.4/lib/libnvdsgst_smartrecord.so (0x0000ffffa9f15000)
libnvdsgst_helper.so => /opt/nvidia/deepstream/deepstream-6.4/lib/libnvdsgst_helper.so (0x0000ffffa9efc000)
libnvdsgst_customhelper.so => /opt/nvidia/deepstream/deepstream-6.4/lib/libnvdsgst_customhelper.so (0x0000ffffa9ee2000)
libnvds_meta.so => /opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_meta.so (0x0000ffffa9eca000)
libnvds_utils.so => /opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_utils.so (0x0000ffffa95f9000)
libnvds_msgbroker.so => /opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_msgbroker.so (0x0000ffffa95de000)
libX11.so.6 => /lib/aarch64-linux-gnu/libX11.so.6 (0x0000ffffa9499000)
libstdc++.so.6 => /lib/aarch64-linux-gnu/libstdc++.so.6 (0x0000ffffa92b4000)
libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000ffffa9209000)
libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000ffffa9096000)
/lib/ld-linux-aarch64.so.1 (0x0000ffffaa52f000)
libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000ffffa9072000)
libgmodule-2.0.so.0 => /lib/aarch64-linux-gnu/libgmodule-2.0.so.0 (0x0000ffffa905e000)
libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000ffffa904a000)
libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000ffffa9019000)
libgstbase-1.0.so.0 => /lib/aarch64-linux-gnu/libgstbase-1.0.so.0 (0x0000ffffa8f94000)
liborc-0.4.so.0 => /lib/aarch64-linux-gnu/liborc-0.4.so.0 (0x0000ffffa8f05000)
libpcre.so.3 => /lib/aarch64-linux-gnu/libpcre.so.3 (0x0000ffffa8e93000)
libffi.so.7 => /lib/aarch64-linux-gnu/libffi.so.7 (0x0000ffffa8e7a000)
libgstnet-1.0.so.0 => /lib/aarch64-linux-gnu/libgstnet-1.0.so.0 (0x0000ffffa8e53000)
libgstrtp-1.0.so.0 => /lib/aarch64-linux-gnu/libgstrtp-1.0.so.0 (0x0000ffffa8e1d000)
libgstrtsp-1.0.so.0 => /lib/aarch64-linux-gnu/libgstrtsp-1.0.so.0 (0x0000ffffa8de8000)
libgstsdp-1.0.so.0 => /lib/aarch64-linux-gnu/libgstsdp-1.0.so.0 (0x0000ffffa8dbf000)
libgstapp-1.0.so.0 => /lib/aarch64-linux-gnu/libgstapp-1.0.so.0 (0x0000ffffa8d9f000)
libgio-2.0.so.0 => /lib/aarch64-linux-gnu/libgio-2.0.so.0 (0x0000ffffa8ba2000)
libgstpbutils-1.0.so.0 => /lib/aarch64-linux-gnu/libgstpbutils-1.0.so.0 (0x0000ffffa8b56000)
libnvinfer.so.8 => /lib/aarch64-linux-gnu/libnvinfer.so.8 (0x0000ffff9b9fb000)
libnvds_logger.so => /opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_logger.so (0x0000ffff9b9e9000)
libxcb.so.1 => /lib/aarch64-linux-gnu/libxcb.so.1 (0x0000ffff9b9b2000)
libz.so.1 => /lib/aarch64-linux-gnu/libz.so.1 (0x0000ffff9b988000)
libmount.so.1 => /lib/aarch64-linux-gnu/libmount.so.1 (0x0000ffff9b918000)
libselinux.so.1 => /lib/aarch64-linux-gnu/libselinux.so.1 (0x0000ffff9b8e0000)
libresolv.so.2 => /lib/aarch64-linux-gnu/libresolv.so.2 (0x0000ffff9b8ba000)
libgstaudio-1.0.so.0 => /lib/aarch64-linux-gnu/libgstaudio-1.0.so.0 (0x0000ffff9b836000)
libgsttag-1.0.so.0 => /lib/aarch64-linux-gnu/libgsttag-1.0.so.0 (0x0000ffff9b7eb000)
librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000ffff9b7d1000)
libnvdla_compiler.so => /usr/lib/aarch64-linux-gnu/tegra/libnvdla_compiler.so (0x0000ffff9b096000)
libcudla.so.1 => /usr/local/cuda/targets/aarch64-linux/lib/libcudla.so.1 (0x0000ffff9b059000)
libXau.so.6 => /lib/aarch64-linux-gnu/libXau.so.6 (0x0000ffff9b045000)
libXdmcp.so.6 => /lib/aarch64-linux-gnu/libXdmcp.so.6 (0x0000ffff9b02f000)
libblkid.so.1 => /lib/aarch64-linux-gnu/libblkid.so.1 (0x0000ffff9afc7000)
libpcre2-8.so.0 => /lib/aarch64-linux-gnu/libpcre2-8.so.0 (0x0000ffff9af39000)
libnvos.so => /usr/lib/aarch64-linux-gnu/tegra/libnvos.so (0x0000ffff9af19000)
libnvdla_runtime.so => /usr/lib/aarch64-linux-gnu/tegra/libnvdla_runtime.so (0x0000ffff9a8c1000)
libcuda.so.1 => /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1 (0x0000ffff9926a000)
libbsd.so.0 => /lib/aarch64-linux-gnu/libbsd.so.0 (0x0000ffff99241000)
libnvrm_host1x.so => /usr/lib/aarch64-linux-gnu/tegra/libnvrm_host1x.so (0x0000ffff99220000)
libnvrm_mem.so => /usr/lib/aarch64-linux-gnu/tegra/libnvrm_mem.so (0x0000ffff99208000)
libnvsocsys.so => /usr/lib/aarch64-linux-gnu/tegra/libnvsocsys.so (0x0000ffff991f4000)
libnvrm_gpu.so => /usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so (0x0000ffff99187000)
libnvrm_sync.so => /usr/lib/aarch64-linux-gnu/tegra/libnvrm_sync.so (0x0000ffff9916e000)
libnvrm_chip.so => /usr/lib/aarch64-linux-gnu/tegra/libnvrm_chip.so (0x0000ffff9915a000)
libnvsciipc.so => /usr/lib/aarch64-linux-gnu/tegra/libnvsciipc.so (0x0000ffff99135000)
No. I’ve post the platform compatibility table before, I can post it again. Installation — DeepStream documentation
We must follow the compatibility limitation strictly.
The release note of DeepStream 6.3: https://docs.nvidia.com/metropolis/deepstream/DeepStream_6.3_Release_Notes.pdf
The release note of DeepStream 6.4: https://docs.nvidia.com/metropolis/deepstream/DeepStream_6.4_Release_Notes.pdf
And the Historical DeepStream documents and package links may be useful for you. DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
Yeah, I have asked about 6.4/6.3 version difference. Since I can’t get release notes, just make a guess on the series.
Now, the release docs says:
We’ll try 6.3, as DS is provided by binary release we can’t do much about it. Just have to follow the dependency or ask nvidia for help.
Yes, that’s why I creat this topic. The information is quite scattered, making it difficult to locate the corresponding details. This is especially true since some versions do not clearly indicate the corresponding NVIDIA binary versions.
Now, I got 6.3 installed on Jetpack 5.1.4
$ deepstream-app -i 2024-11-21_11-54-24.mp4 -c /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt
** ERROR: <main:716>: Failed to set pipeline to PAUSED
Quitting
ERROR from src_bin_muxer: Output width not set
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmultistream/gstnvstreammux.cpp(3029): gst_nvstreammux_change_state (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstNvStreamMux:src_bin_muxer
App run failed
The mp4 file can be played with video-viewer.
EDIT:
$ deepstream-app --version
deepstream-app version 6.3.0
DeepStreamSDK 6.3.0
system software stack info:
Software part of jetson-stats 4.2.12 - (c) 2024, Raffaello Bonghi
Model: NVIDIA Orin Nano Developer Kit - Jetpack 5.1.4 [L4T 35.6.0]
NV Power Mode[0]: 15W
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
- P-Number: p3767-0005
- Module: NVIDIA Jetson Orin Nano (Developer kit)
Platform:
- Distribution: Ubuntu 20.04 focal
- Release: 5.10.216-tegra
jtop:
- Version: 4.2.12
- Service: Active
Libraries:
- CUDA: 11.4.315
- cuDNN: 8.6.0.166
- TensorRT: 8.5.2.2
- VPI: 2.4.8
- OpenCV: 4.9.0 - with CUDA: YES
Python Environment:
Python 3.8.10
GStreamer: YES (1.16.3)
NVIDIA CUDA: YES (ver 11.4, CUFFT CUBLAS FAST_MATH)
OpenCV version: 4.9.0 CUDA True
YOLO version: 8.3.33
Torch version: 2.1.0a0+41361538.nv23.06
Torchvision version: 0.16.1+fdea156
Your command is wrong. This is nvinfer configuration file but not deepstream-app configuration file. DeepStream Reference Application - deepstream-app — DeepStream 6.3 Release documentation
You may try with the following steps if it is the first time to run DeepStream sample:
make sure there is a physical monitor connected with your board.
Run the following command in your boards’ ubuntu terminal.
sudo apt install \
libssl3 \
libssl-dev \
libgstreamer1.0-0 \
gstreamer1.0-tools \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly \
gstreamer1.0-libav \
libgstreamer-plugins-base1.0-dev \
libgstrtspserver-1.0-0 \
libjansson4 \
libyaml-cpp-dev
cd /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/
deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.yml
