Nova orin init error
Install from nova-orin-init Nova Orin Init — nova_docs documentation
An error occurs while performing the installation.
I want to know how to solve this
And I want to use realsense, but it seems only Hawk is available.
a-jetson-clocks.service.
Attempting to setup dtb…
WARN: /boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb is older than last jetson build Fri Jul 19 23:24:25 UTC 2024, replacing with /boot/tegra234-p3737-0000+p3701-0005-nv.dtb
INFO: found overlay file /opt/nvidia/nova/dtb/nova-p3762.dtsi
INFO: /opt/nvidia/jetson-io/config-by-hardware.py -n 2=Jetson Camera Hawk-Owl p3762 module 1=Nova p3762 Sensor Config
File “/opt/nvidia/jetson-io/config-by-hardware.py”, line 126, in
main()
File “/opt/nvidia/jetson-io/config-by-hardware.py”, line 122, in main
configure_dt(jetson, dtbos)
File “/opt/nvidia/jetson-io/config-by-hardware.py”, line 44, in configure_dt
messages = jetson.configure_dt_for_next_boot(dtbos)
File “/opt/nvidia/jetson-io/Jetson/board.py”, line 414, in configure_dt_for_next_boot
return self.configure_overlays(dtbos)
File “/opt/nvidia/jetson-io/Jetson/board.py”, line 396, in configure_overlays
shutil.copyfile(dtbo, os.path.join(self.appdir, dtbo[1:]))
File “/usr/lib/python3.10/shutil.py”, line 234, in copyfile
raise SameFileError(“{!r} and {!r} are the same file”.format(src, dst))
shutil.SameFileError: ‘/boot/tegra234-p3737-nova-p3762.dtbo’ and ‘/mnt/APP/boot/tegra234-p3737-nova-p3762.dtbo’ are the same file
ERROR: /opt/nvidia/nova/dtb/setup.sh:65 (‘/opt/nvidia/jetson-io/config-by-hardware.py “${args_[@]}”’ exited with code 1)
File “/opt/nvidia/nova/setup_nova.py”, line 237, in
main()
File “/opt/nvidia/nova/setup_nova.py”, line 233, in main
setup_manager.run()
File “/opt/nvidia/nova/setup_nova.py”, line 181, in run
raise ValueError(
ValueError: Failed at calling /opt/nvidia/nova/dtb/setup.sh in step dtb with response 1.
ERROR: /opt/nvidia/nova/install.sh:30 (‘$NOVA_BASE_DIR/python/venv/bin/python3 $NOVA_BASE_DIR/setup_nova.py -p $processed_setup setup $@’ exited with code 1)
File “/usr/bin/nova_manager”, line 192, in
main()
File “/usr/bin/nova_manager”, line 184, in main
args.func(args)
File “/usr/bin/nova_manager”, line 131, in install
raise RuntimeError(f"Couldn’t execute {cmd}")
RuntimeError: Couldn’t execute /opt/nvidia/nova/install.sh -s /etc/nova/examples/nova-devkit.yaml
dpkg: error processing package nova-orin-init (–configure):
installed nova-orin-init package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
nova-orin-init
E: Sub-process /usr/bin/dpkg returned an error code (1)
