Hi there.
I have a GeForce GTX 1650 Ti Mobile in my HP Spectre x360, running Fedora 35.
I patched and compiled kernel 5.15.6 to fix a problem with my laptop’s speakers. The fix was successful, but now the NVIDIA modules won’t install.
At startup I get the error:
NVIDIA kernel module missing. Falling back to nouveau.
kernel-headers was successfully generated and I installed it, but the NVIDIA installer fails at DKMS:
[code]ERROR: Failed to run ‘/usr/sbin/dkms build -m nvidia -v 470.94 -k 5.15.16’: Error! Your kernel headers for kernel 5.15.16 cannnot be found at /lib/modules/5.15.16/build or /lib/modules/5.15.16/source.
Please install the linux-headers-5.15.16 package or use the --kernelsourcedir option to tell DMKS where it’s located.[/code]
I copied the source from the unpacked tar to /lib/modules/5.15.16/source, but the error remains.
When using the kernel from Fedora (or any other distro) the modules install fine, but not with the one I compiled.
I’m not very experienced with kernel compiling, so any help would be much appreciated.
Below is the process I used to compile the kernel.
Fedora 35, HP Spectre x360 15-eb0016TX.
[code]curl https://cdn.kernel.org/pub/linux/kernel/v5.x/linux-5.15.16.tar.xz|tar -xJ
cd linux-5.15.16
vim ~/linux-5.15.16/sound/pci/hda/patch_realtek.c[/code]
Added the following line
SND_PCI_QUIRK(0x103c, 0x86e8, "HP Spectre x360 15-eb0xxx",
Make menuconfig
make -j7
make binrpm-pkg
