When i give command : ./cuda cuda_5.5_linux_32.run
I get
Installing the NVIDIA display driver…
It appears that an X server is running. Please exit X before installation. If you’re sure that X is not running, but are getting this error, please delete any X lock files in /tmp.
[ it says you are running an X server, meaning a graphical desktop. Try this:
CTRL+Alt+F2 to open a terminal session. Try running the NVIDIA.run from here then. ]
i tried it but even when i got off the desktop by CTRL+Alt+F2, i got exactly the same error that is
[ It appears that an X server is running. Please exit X before installation. If you’re sure that X is not running, but are getting this error, please delete any X lock files in /tmp. ]
yeah, there are many answers and i even tried them but those dint work.
assuming X is not running, according to If you’re sure that X is not running, but are getting this error, please delete any X lock files in /tmp.
I used " sudo rm /tmp/.X*-lock "
and then after i dint get the same error but different one which was
The driver installation is unable to locate the kernel source. Please make sure that the kernel source packages are installed and set up correctly.
If you know that the kernel source packages are installed and set up correctly, you may pass the location of the kernel source with the ‘–kernel-source-path’ flag.
i tried it
That certainly made it sound like you had a window manager running (i.e. X).
sudo stop gdm or some variant should work. If it does not, the issue is a linux issue not a CUDA one.
Try finding a method to set your ubuntu system to run at runlevel 3. Then reboot into runlevel 3. That will certainly prevent X from running. After that, you should be able to install. When you are finished with the install, modify the runlevel back to 5 and reboot.
when I try “sudo stop gdm”, i get into a screen like its diagnostic one.
it looks like
Setting sensors limits [ OK ]
Starting Denyhosts denyhosts [ OK ]
Speech-dispatcher configured for user sessions [ OK ]
* Starting the Winbind daemon winbind [ OK ]
Saved ALSA mixer settings detected; aumix will not touch mixer.
* Starting DHCP server dhcpd3
check syslog for diagnostics. [fail]
Starting Common Unix Printing System: cupsd [ OK ]
PulseAudio confirmed for per-user sessions
* Enabling additional executable binary formats binfmt-support [ OK ]
Checking battery state… [ OK ]
THATS IT!
and then i get stuck at this screen and i cant get out of it unless I shut down the system forcefully and restart it.
OR
If i hit “Ctrl+Alt+F1/F2”, i enter into a termincal session. Normally,from here, when i hit “Ctrl+Alt+F7”, it brings me back to desktop but here, it takes me back to the screen i just showed ( d diagnostic one]
SO, i go in the loop between " Terminal session" and “Diagnostic screen” after using Ctrl+Alt+F1 & Ctrl+Alt+F7 OR ( Alt+Right/Left arrow )
UNLESS
i start the gdm by “sudo start gdm”
and it sends me to the screen we get right after restarting the system. I login and i get to the desktop all tabs and files closed LIKE I HAVE RESTARTED THE SYSTEM OR i get into another session or another user’s desktop"
Tell me if you got anything after the details i gave
otherwise
i will do as u said
[ Try finding a method to set your ubuntu system to run at runlevel 3. Then reboot into runlevel 3. That will certainly prevent X from running. After that, you should be able to install. When you are finished with the install, modify the runlevel back to 5 and reboot. ]
I tried to install after going at runlevel 3 yet i couldnt install it and i got the same error i was talking about
Yes, that error is different than the “X is running” error.
Changing runlevels has no effect on that.
Basically, your ubuntu OS is either missing the kernel source package, or else it is in some place that the driver doesn’t expect it to be.
If you have a clean load of ubuntu (i.e. no kernel updates applied) and the proper kernel sources loaded, you should not see this error.
On RHEL/CentOS/Fedora, I would be doing yum list kernel-devel to see what kernel source packages are installed and available. I don’t happen to know what the corresponding commands are for ubuntu, but googling “ubuntu install kernel headers” seems to give promising links. The README file that ships with the driver discusses this in some detail:
oprime@ubuntu:~/gpgpu-sim/ispass2009-benchmarks$ make -f Makefile.ispass-2009
THIS COMMAND should have been enough but I dont see even “BIN” directory in the “~gpgpu-sim/ispass2009-benchmarks” Directory which was SUPPOSED TO CONTAIN ALL .exe FILES OF BENCHMARKS.
THIS IS WHAT I GET
oprime@ubuntu:~/gpgpu-sim/ispass2009-benchmarks/BFS$ bash README.GPGPU-Sim
README.GPGPU-Sim: line 1: …/bin/release/BFS: No such file or directory
AND, when i had used “make -f Makefile.ispass-2009”
rm -f …/common; ln -s /C/common …/common;
cd CP; export PARBOIL_ROOT=pwd; cd common/src; make; cd -; ./parboil compile cp cuda_short; cp benchmarks/cp/build/cuda_short/cp /home/oprime/gpgpu-sim/ispass2009-benchmarks/bin//release/CP
make[1]: Entering directory /home/oprime/gpgpu-sim/ispass2009-benchmarks/CP/common/src' gcc -c -std=gnu99 -I/include -I/home/oprime/gpgpu-sim/ispass2009-benchmarks/CP/common/include -g /home/oprime/gpgpu-sim/ispass2009-benchmarks/CP/common/src/parboil.c -o /home/oprime/gpgpu-sim/ispass2009-benchmarks/CP/common/src/../lib/parboil.o ar rc /home/oprime/gpgpu-sim/ispass2009-benchmarks/CP/common/src/../lib/libparboil.a /home/oprime/gpgpu-sim/ispass2009-benchmarks/CP/common/src/../lib/parboil.o ranlib /home/oprime/gpgpu-sim/ispass2009-benchmarks/CP/common/src/../lib/libparboil.a make[1]: Leaving directory /home/oprime/gpgpu-sim/ispass2009-benchmarks/CP/common/src’
Parboil parallel benchmark suite, version 0.1
