Installing Ubuntu 22.04 on BlueField 3 end up in hung state
I got a new Bluefield 3 out-of-the-box, this is my first attempt on set up Ubuntu 22.04 on the card.
State of the card:
  • /dev/rshim0 is discoverable from my host
  • I have access to dpu-bmc and redfish and UEFI via virtual console /dev/rshim0/console, I turned OFF secure boot on the UEFI because I found a thread saying it is needed to get Ubuntu 22.04 to install seamlessly.
  • physically, I am connecting the card on a PCIe Gen 5 slot with one network cable connected to the management RJ45 port (dpu-bmc)
  • I do not have the necessary QSFP to RJ45 converter at the moment (need advise what brand is compatible with Bluefield 3)
I am using the bf bundle package from Nvidia with this command line:
bfb-install --bfb bf-bundle-3.1.0-76_25.07_ubuntu-22.04_prod.bfb --config bf.cfg --rshim rshim0
Everything looks fine, until it just stopped here:
root@localhost:/home/user# bfb-install --bfb bf-bundle-3.1.0-76_25.07_ubuntu-22.04_prod.bfb --config bf.cfg --rshim rshim0
Checking if local host has root access...
/dev/rshim0 (0000:c1:00) is in NIC mode
Checking if rshim driver is running locally...
Warn: 'pv' command not found. Continue without showing BFB progress.
Unbinding pf0 (0000:c1:00.0)
Unbinding pf1 (0000:c1:00.1)
Pushing bfb + cfg
Collecting BlueField booting status. Press Ctrl+C to stop…
 INFO[PSC]: PSC BL1 START
 INFO[BL2]: start
 INFO[BL2]: boot mode (rshim)
 INFO[BL2]: VDD_CPU: 781 mV
 INFO[BL2]: VDDQ: 1118 mV
 INFO[BL2]: DDR POST passed
 INFO[BL2]: UEFI loaded
 INFO[BL31]: start
 INFO[BL31]: lifecycle GA Secured
 INFO[BL31]: runtime
 INFO[UEFI]: Partial NIC
 INFO[BL31]: MB ping success
 INFO[UEFI]: eMMC init
 INFO[UEFI]: eMMC probed
 INFO[UEFI]: UPVS valid
 INFO[UEFI]: PMI: updates started
 INFO[UEFI]: PMI: total updates: 1
 INFO[UEFI]: PMI: updates completed, status 0
 INFO[UEFI]: PCIe enum start
 INFO[UEFI]: PCIe enum end
 INFO[BL31]: Partial NIC
 INFO[BL31]: power capping disabled
 INFO[UEFI]: UEFI Secure Boot (disabled)
 INFO[UEFI]: PK configured
 INFO[UEFI]: Redfish enabled
 INFO[UEFI]: exit Boot Service
 INFO[MISC]: Found bf.cfg
 INFO[MISC]: Erasing eMMC drive: /dev/mmcblk0
 INFO[MISC]: Erasing NVME drive: /dev/nvme0n1
 INFO[MISC]: Ubuntu installation started
 INFO[MISC]: Installing OS image
 INFO[MISC]: Changing the default password for user ubuntu
 INFO[MISC]: Ubuntu installation completed
 INFO[MISC]: Installed NIC Firmware is the same as provided. Skipping NIC Firmware update.
 INFO[MISC]: Installation finished
 INFO[MISC]: Rebooting...
 INFO[BL2]: start
 INFO[BL2]: boot mode (emmc)
 INFO[BL2]: VDDQ: 1120 mV
 INFO[BL31]: start
 INFO[BL31]: runtime
 INFO[UEFI]: PMI: total updates: 8
 INFO[UEFI]: PMI: rebooting
 INFO[BL2]: start
 INFO[BL2]: VDD_CPU: 778 mV
 INFO[BL31]: start
 INFO[BL31]: runtime
 INFO[UEFI]: DPU-BMC RF credentials found
 INFO[UEFI]: In Enhanced NIC mode
Binding pf0 (0000:c1:00.0)
Binding pf1 (0000:c1:00.1)
This is what the virtual console print out, at this point there is no other response from the console:
Press ESC/F2/DEL twice    to enter UEFI Menu.
Press ENTER               to skip countdown.
3  seconds remain...
2  seconds remain...
1  seconds remain...
0  seconds remain...
** Redfish GET https://192.168.240.1/redfish/v1/, Success
ProcessVendorIdentification: Vendor: Nvidia
** XAUTH POST https://192.168.240.1/redfish/v1/SessionService/Sessions, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Oem/Nvidia/SystemConfigProfile/Status, Success
[Pcm] Profile pending activation: None.
** Redfish GET https://192.168.240.1/redfish/v1/Registries/BiosAttributeRegistry/BiosAttributeRegistry, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings, Success
** Redfish PATCH https://192.168.240.1/redfish/v1/Systems/Bluefield, Success
** Redfish POST https://192.168.240.1/redfish/v1/Systems/Bluefield/Actions/Oem/NvidiaComputerSystem.PushSmbiosTable, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Bios/Settings, Success
** Redfish PATCH https://192.168.240.1/redfish/v1/Systems/Bluefield/Bios, Success
** Redfish PATCH https://192.168.240.1/redfish/v1/UpdateService/FirmwareInventory, Access Denied
** Redfish GET https://192.168.240.1/redfish/v1/TaskService/Tasks/, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Oem/Nvidia/Truststore/Certificates, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/PK/Certificates, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/PK/Certificates/1, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/KEK/Certificates, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/KEK/Certificates/1, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/db/Certificates, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/db/Certificates/1, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/db/Certificates/2, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/db/Certificates/3, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/db/Certificates/4, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/db/Certificates/5, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/db/Certificates/6, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/db/Certificates/7, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Certificates, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/1, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/10, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/11, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/12, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/13, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/14, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/15, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/16, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/17, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/18, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/19, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/2, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/20, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/21, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/22, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/23, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/24, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/25, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/26, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/27, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/28, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/29, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/3, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/30, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/31, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/32, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/33, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/34, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/35, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/36, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/37, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/38, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/39, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/4, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/40, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/41, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/42, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/43, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/44, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/45, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/46, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/47, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/48, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/49, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/5, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/50, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/51, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/52, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/53, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/54, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/55, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/56, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/57, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/58, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/59, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/6, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/60, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/61, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/62, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/63, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/64, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/65, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/66, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/67, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/68, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/69, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/7, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/70, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/71, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/72, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/73, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/74, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/75, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/76, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/77, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/8, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot/SecureBootDatabases/dbx/Signatures/9, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot, Success
** Redfish PATCH https://192.168.240.1/redfish/v1/Systems/Bluefield/SecureBoot, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0000, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0001, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0002, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0003, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0004, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0005, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0006, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0007, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0008, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0009, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot000A, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot000B, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot000C, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot000D, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot000E, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot000F, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0010, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0011, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0012, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0013, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0014, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0015, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0016, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0017, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0018, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0000, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0001, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0002, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0004, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0005, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0006, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0007, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0008, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0009, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot000A, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot000B, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot000C, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot000D, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot000E, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot000F, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0010, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0011, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0012, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0013, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0014, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0015, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0016, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0017, Success
** Redfish GET https://192.168.240.1/redfish/v1/Systems/Bluefield/Settings/BootOptions/Boot0018, Success
** Redfish PATCH https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0003, Aborted
BootOptions: PATCH of whole boot option not supported, fall back to DELETE/POST.
** Redfish DELETE https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions/Boot0003, Success
** Redfish POST https://192.168.240.1/redfish/v1/Systems/Bluefield/BootOptions, Success
I am stuck here, dpu-bmc is still responding, I can perform the bfb-install again but it will be the same result
bf-bundle file sha256:
9ca6907432e203bee623b4bb351ffecc1d1b1516d473f3cc1b0c9769de82e53b  bf-bundle-3.1.0-76_25.07_ubuntu-22.04_prod.bfb
when i echo “SW_RESET 1” > /dev/rshim0/misc, this is the printing, before the bunch of redfish commands sent before hung state
Nvidia BlueField-3 rev1 BL1 V1.0
NOTICE:  Running as 9009D3D400NNHA0 system
NOTICE:  BL2: v2.2(release):4.12.0-27-gd9bafc95f
NOTICE:  BL2: Built : 20:36:13, Jul 30 2025
NOTICE:  BL2 built for hw (ver 2)
NOTICE:  # Finished initializing DDR MSS1
NOTICE:  DDR POST passed.
NOTICE:  HW watchdog disabled.
NOTICE:  BL31: v2.2(release):4.12.0-27-gd9bafc95f
NOTICE:  BL31: Built : 20:36:13, Jul 30 2025
NOTICE:  BL31 built for hw (ver 2), lifecycle GA Secured
NOTICE:  OP-TEE non functional as HW Crypto NOT ENABLED UEFI firmware (version BlueField:4.12.0-19-gdd4c9d8a10-BId13720 built at 20:36:55 on Jul 30 2025)
Mellanox BlueField-3 [A1] A78(D42) 8 Cores r0p1
Memory Information:DDR5 Memory Available: 16 GB Operating Frequency: 5200 MT/s
Storage Device Information:NVMe Device Address: 06:00.0 Vendor ID: 1344 Device ID: 6001Current Link Speed: 8.0 GT/s Negotiated Link WidthPTM:11129663568:2:0:6~: x2
[Pcm] Profile Root Key found (type: RSA, size: 4096 bits)[Pcm] Profile CA certificate found (NVIDIA certificate)Current Secure Boot State: disabledSecure Boot Mode         : User ModePK is  configuredRedfish enabledDPU BMC version: BF-25.07-6Getting BMC Credentials…DHCP Session Start
cat /dev/rshim0/misc
DISPLAY_LEVEL   2 (0:basic, 1:advanced, 2:log)
BF_MODE         NIC mode
BOOT_MODE       1 (0:rshim, 1:emmc, 2:emmc-boot-swap)
BOOT_TIMEOUT    300 (seconds)
USB_TIMEOUT     40 (seconds)
DROP_MODE       0 (0:normal, 1:drop)
SW_RESET        0 (1: reset)
DEV_NAME        pcie-0000:c1:00.3
DEV_INFO        BlueField-3(Rev 1)
OPN_STR         N/A
UP_TIME         2589(s)
SECURE_NIC_MODE 0 (0:no, 1:yes)
FORCE_CMD       0 (1: send Force command)
forgot to add:
bf.cfg contains these attributes, the password has a value (generated with “openssl passwd -1“):
device=/dev/nvme0n1
ubuntu_PASSWORD=''
mst status
MST modules:
    MST PCI module is not loaded
    MST PCI configuration module loaded
PCI devices:
DEVICE_TYPE                         MST                           PCI       RDMA            NET                                     NUMA
BlueField3(rev:1)                   /dev/mst/mt41692_pciconf0.2   c1:00.2                                           1
BlueField3(rev:1)                   /dev/mst/mt41692_pciconf0.1   c1:00.1   mlx5_0          net-enp193s0f1np0                       1
BlueField3(rev:1)                   /dev/mst/mt41692_pciconf0     c1:00.0   mlx5_1          net-enp193s0f0np0                       1
I just found out I have the same issue reported here: While update BlueField-3 dpu with bf-bundle-3.0.0-135_25.04_ubuntu-22.04_prod.bfb the os can not be run
The only difference is that my secureboot is disabled already. Yet facing the same issue. I have yet to try the suggestion to get 24.04 bfb bundle.
Where can I get 24.04 bfb bundle? I can only find Ubuntu 22.04 here NVIDIA DOCA Downloads | NVIDIA Developer
Thanks for your question.
Is your BF3 card in NIC mode?
If yes, it is expected that after boot you don’t see login prompt in the console, as in NIC mode no operating system is running on BF3, and it’s operating as a regular CX7 network adapter, and it’s managed from the host side only.
For more info about NIC mode:
NIC Mode
Moving Between Operation Modes
Best Regards,
Anatoly
You need to change the card from NIC Mode to DPU Mode. You can do this through the firmware by pressing Esc during boot and selecting DPU Mode. Ubuntu OS will not load in NIC Mode; it is only available in DPU Mode.
