Integrating DeepStream RTSP inference events with an external Visitor Management System webhook
Hi everyone,
We are building an edge video analytics pipeline using NVIDIA DeepStream (on [Jetson Orin Nano / dGPU], DeepStream [version]) to detect visitor arrivals, tailgating, and badge/license-plate events at a building entrance, and sync those events into our Visitor Management System ([link to your technical API/webhook documentation or GitHub integration repo]).
Current pipeline:
  • Input: [number] RTSP camera streams ([resolution/FPS])
  • Inference: [model name, e.g., PeopleNet / custom TensorRT engine]
  • Output: Sending metadata via [Kafka / MQTT / HTTP webhook]
Question: What is the recommended way in DeepStream (nvmsgbroker / nvmsgconv) to attach custom cropped frame IDs or track IDs to outbound JSON payloads so our Visitor Management System can deduplicate repeated detections of the same visitor at a kiosk without flooding the API?
Reference docs we are following:
  • Our event payload schema: [link to your public API/schema doc]
  • Target architecture notes: [optional technical blog/architecture link]
Any guidance or sample configs would be appreciated!
The messages and broker implementation are open source. You may customize as you like.
You may refer to the DeepStream/src/apps/sample_apps/deepstream-test5/deepstream_test5_app_main.c at main · NVIDIA/DeepStream for a simple sample of customized even message.
