Is there any example of integrating external Object detectors like yolox with deepstream based trackers ? If not could you tell me how could i approach this problem?
Can you check the DeepStream samples? You can configure the PGIE to any detection model. nvtracker should works fine:
C/C++ Sample Apps Source Details — DeepStream documentation 6.4 documentation
Python Sample Apps and Bindings Source Details — DeepStream documentation 6.4 documentation
Thanks i took a look at them already , so what i exactly need is to only pass the output of external detector to NVDCF tracker , would that be possible without integrating the whole detector?
Yes, but you need to feed the same gstbuffer(meta data) as the output of nvinfer.
Ok , so NvDsBatchMeta is what we need in this case?
Yes, you are right. The NvDsBatchMeta need include the bboxes which generated by detector.
def stream_buffer_probe(pad, info, u_data):
buffer = info.get_buffer()
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buffer))
if not batch_meta:
return Gst.PadProbeReturn.OK
# Iterate over frames in the batch
frame_meta_list = batch_meta.frame_meta_list
while frame_meta_list is not None:
frame_meta = pyds.NvDsFrameMeta.cast(frame_meta_list.data)
# Run object detection on the frame
#detections = detector.detect_objects(frame)
# Convert the detection results to a format compatible with nvtracker
bbox_list = []
detections = []
detection = {}
for i in range(5):
detection['x'] = 1920/2 - i * 10
detection['y'] = 1080/2 - i * 10
detection['width'] = i * 2
detection['height'] = i * 2
for detection in detections:
# Convert bounding box coordinates to DeepStream format
bbox = pyds.NvDsRectangle()
bbox.left = detection['x']
bbox.top = detection['y']
bbox.width = detection['width']
bbox.height = detection['height']
# Create object metadata
obj_meta = pyds.NvDsObjectMeta()
obj_meta.rect_params = bbox
obj_meta.confidence = 1.0
obj_meta.class_id = 0
# Add more attributes as needed
# Append the object metadata to the list
bbox_list.append(obj_meta)
# Pass the detection results to nvtracker
# Your code to send detection results to nvtracker here
tracker_meta = batch_meta.get_tracker_meta(1)
if tracker_meta is None:
tracker_meta = pyds.nvds_add_tracker_meta_to_frame(frame_meta, 1)
# Append object metadata to object history in NvTrackerMeta
tracker_meta.append_object_info(obj_meta)
@kesong I added probe on streammux so that dummy metadata can be sent to tracker , but it gets stuck inside nvdstracker plugin. Do you know what could be causing it?
You may need compare the metadata with the one which works (nvinfer->nvtracker).
