Hi all,
I’m trying to get the WiFi card to work but I am now completely stuck on how to proceed further. Here is what I’ve done so far:
- I downloaded the firmware driver iwlwifi but that didn’t get me anywhere.
- I came across this thread: Issues with Intel 9620 WiFi Card/no wlan0 detected(search this up. I can only put one link. Sorry!). It suggested the kernel requires a backport driver.
- I downloaded the backport-iwlwifi-dkms by following this thread: drivers - Backport for iwlwifi - Ask Ubuntu. I saw some new changes when using lspci and dmesg. Kernel in use has changed to iwlwifi and now there are new errors in dmesg:
revolt@revolt-desktop:~$sudo lspci -v
0003:01:00.0 Network controller: Intel Corporation Wireless-AC 9260 (rev 29)
Subsystem: Intel Corporation Device 0014
Flags: bus master, fast devsel, latency 0, IRQ 36
Memory at 12b0000000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [154] L1 PM Substates
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
revolt@revolt-desktop:~$ dmesg | grep wlwifi
[ 7.289216] Loading modules backported from iwlwifi
[ 7.289223] iwlwifi-stack-public:master:8324:9176b151
[ 7.364408] iwlwifi 0003:01:00.0: enabling device (0000 -> 0002)
[ 7.368224] iwlwifi 0003:01:00.0: Direct firmware load for iwl-dbg-cfg.ini failed with error -2
[ 7.368406] iwlwifi 0003:01:00.0: Falling back to user helper
[ 69.025455] iwlwifi 0003:01:00.0: WRT: Overriding region id 0
[ 69.025625] iwlwifi 0003:01:00.0: WRT: Overriding region id 1
[ 69.025739] iwlwifi 0003:01:00.0: WRT: Overriding region id 2
[ 69.025851] iwlwifi 0003:01:00.0: WRT: Overriding region id 3
[ 69.025962] iwlwifi 0003:01:00.0: WRT: Overriding region id 4
[ 69.026082] iwlwifi 0003:01:00.0: WRT: Overriding region id 6
[ 69.026197] iwlwifi 0003:01:00.0: WRT: Overriding region id 8
[ 69.026312] iwlwifi 0003:01:00.0: WRT: Overriding region id 9
[ 69.026465] iwlwifi 0003:01:00.0: WRT: Overriding region id 10
[ 69.026582] iwlwifi 0003:01:00.0: WRT: Overriding region id 11
[ 69.026700] iwlwifi 0003:01:00.0: WRT: Overriding region id 15
[ 69.026831] iwlwifi 0003:01:00.0: WRT: Overriding region id 16
[ 69.026955] iwlwifi 0003:01:00.0: WRT: Overriding region id 18
[ 69.027280] iwlwifi 0003:01:00.0: WRT: Overriding region id 19
[ 69.027737] iwlwifi 0003:01:00.0: WRT: Overriding region id 20
[ 69.028194] iwlwifi 0003:01:00.0: WRT: Overriding region id 21
[ 69.028648] iwlwifi 0003:01:00.0: WRT: Overriding region id 28
[ 69.036057] iwlwifi 0003:01:00.0: loaded firmware version 46.50fdb42f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
[ 69.036169] iwlwifi 0003:01:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 69.043374] iwlwifi 0003:01:00.0: Falling back to user helper
[ 69.121193] iwlwifi 0003:01:00.0: Detected Intel(R) Wireless-AC 9260, REV=0x324
[ 69.175764] iwlwifi 0003:01:00.0: Can't parse empty family 8000 OTP/NVM sections
[ 69.176040] iwlwifi 0003:01:00.0: Failed to read NVM: -61
[ 69.188578] iwlwifi 0003:01:00.0: Failed to run INIT ucode: -61
- I’m currently stuck at
Can't parse empty family.... I’ve triedsudo iw reg set AU
I’ve read about this error being a hardware issue in a few threads but couldn’t find anything past that. I’m not totally convinced it is a hardware issue as it’s fresh out of the box.
Could anyone shed some light?
