i download and extract,then i cp iwlwifi-*.ucode /lib/firmware
but when i restat the nano,i can’t see the wifi icon,only wired options…
my os inf:
Linux lb-desktop 4.9.140-tegra #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019 aarch64 aarch64 aarch64 GNU/Linux
please help me.
thanks
~$ lspci -v
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 84
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: 13000000-130fffff
Capabilities: <access denied>
Kernel driver in use: pcieport
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 13100000-131fffff
01:00.0 Network controller: Intel Corporation Wireless 3165 (rev ff) (prog-if ff)
!!! Unknown header type 7f
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
Flags: bus master, fast devsel, latency 0, IRQ 404
I/O ports at 1000
Memory at 13104000 (64-bit, non-prefetchable)
Memory at 13100000 (64-bit, non-prefetchable)
Kernel driver in use: r8168
lb@lb-desktop:~$ lspci | grep Network
lb@lb-desktop:~$ dmesg | grep iwlwifi
[ 7.332191] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 7.492933] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-7265D-26.ucode failed with error -2
[ 7.506801] iwlwifi 0000:01:00.0: Falling back to user helper
[ 7.720621] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-7265D-25.ucode failed with error -2
[ 7.732292] iwlwifi 0000:01:00.0: Falling back to user helper
[ 7.744869] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-7265D-24.ucode failed with error -2
[ 7.756298] iwlwifi 0000:01:00.0: Falling back to user helper
[ 7.765824] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-7265D-23.ucode failed with error -2
[ 7.777209] iwlwifi 0000:01:00.0: Falling back to user helper
[ 7.815578] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 7.940583] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 3165, REV=0xFFFFFFFF
[ 7.942390] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 7.958049] WARNING: CPU: 1 PID: 3794 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/drivers/net/wireless/intel/iwlwifi/pcie/trans.c:1860 iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 7.958062] Modules linked in: iwlmvm(+) mac80211 nvs iwlwifi cfg80211 binfmt_misc iptable_filter ip6table_filter ip6_tables br_netfilter arp_tables nvgpu bluedroid_pm ip_tables x_tables
[ 7.958091] PC is at iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 7.958109] LR is at iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 7.958174] [<ffffff8001236bc4>] iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 7.958193] [<ffffff8001227760>] iwl_write_prph+0x38/0x80 [iwlwifi]
[ 7.958212] [<ffffff80012350d8>] iwl_trans_pcie_reclaim+0x880/0x3bb0 [iwlwifi]
[ 7.958231] [<ffffff8001238f9c>] iwl_trans_pcie_rf_kill+0xb94/0xe98 [iwlwifi]
[ 7.958302] [<ffffff8001228ee8>] iwl_opmode_deregister+0xba0/0x1410 [iwlwifi]
[ 7.958320] [<ffffff80012297cc>] iwl_opmode_register+0x74/0xf8 [iwlwifi]
[ 7.989638] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.668932] iwlwifi 0000:01:00.0: Could not load the [0] uCode section
[ 8.668950] iwlwifi 0000:01:00.0: Failed to start INIT ucode: -5
[ 10.294352] iwlwifi 0000:01:00.0: Failed to run INIT ucode: -5
[ 10.294366] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
lb@lb-desktop:~$ iwconfig
lo no wireless extensions.
usb0 no wireless extensions.
l4tbr0 no wireless extensions.
dummy0 no wireless extensions.
eth0 no wireless extensions.
rndis0 no wireless extensions.
lb@lb-desktop:~$ modinfo iwlwifi
filename: /lib/modules/4.9.140-tegra/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Copyright(c) 2003- 2015 Intel Corporation <linuxwifi@intel.com>
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-26.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-26.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-26.ucode
firmware: iwlwifi-8000C-26.ucode
firmware: iwlwifi-9000-pu-a0-lc-a0--26.ucode
firmware: iwlwifi-9260-th-a0-jf-a0--26.ucode
firmware: iwlwifi-9000-pu-a0-jf-a0--26.ucode
firmware: iwlwifi-Qu-a0-jf-b0--26.ucode
alias: pci:v00008086d00002720sv*sd00000A10bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00001030bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001030bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000030bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends: cfg80211
intree: Y
vermagic: 4.9.140-tegra SMP preempt mod_unload modversions aarch64
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 4K for other devices 1:4K 2:8K 3:12K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: antenna_coupling:specify antenna coupling in dB (default: 0 dB) (int)
parm: nvm_file:NVM file name (charp)
parm: d0i3_disable:disable d0i3 functionality (default: Y) (bool)
parm: lar_disable:disable LAR functionality (default: N) (bool)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: fw_monitor:firmware monitor - to debug FW (default: false - needs lots of memory) (bool)
parm: d0i3_timeout:Timeout to D0i3 entry when idle (ms) (uint)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
