Hi Simon_L,
Bluetooth should work because it’s I2C that we masked out. BT on 8260 is a separate USB device which seems functional on nano. Here’s some info from the stock driver/kernel of R32.2 image:
$ dmesg | egrep -i “iwlwifi | blue”
[ 0.614861] Bluetooth: Core ver 2.22
[ 0.614919] Bluetooth: HCI device and connection manager initialized
[ 0.614933] Bluetooth: HCI socket layer initialized
[ 0.614942] Bluetooth: L2CAP socket layer initialized
[ 0.614967] Bluetooth: SCO socket layer initialized
[ 1.923957] Bluetooth: RFCOMM socket layer initialized
[ 1.923968] Bluetooth: RFCOMM ver 1.11
[ 1.923974] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.923979] Bluetooth: HIDP socket layer initialized
[ 5.883284] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 5.891915] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-26.ucode failed with error -2
[ 5.891922] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.892885] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-25.ucode failed with error -2
[ 5.892889] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.896148] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-24.ucode failed with error -2
[ 5.896154] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.899547] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8000C-23.ucode failed with error -2
[ 5.899553] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.995194] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 6.050941] Bluetooth: hci0: Firmware revision 0.0 build 176 week 45 2017
[ 6.803187] iwlwifi 0000:01:00.0: Detected Intel® Dual Band Wireless AC 8260, REV=0x208
[ 6.805617] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.806465] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 7.705053] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.705065] Bluetooth: BNEP socket layer initialized
[ 7.818634] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 7.819067] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 7.959963] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 7.960319] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
$ hciconfig hci0
hci0: Type: Primary Bus: USB
BD Address: A4:34:D9:6F:72:E5 ACL MTU: 1021:4 SCO MTU: 96:6
UP RUNNING
RX bytes:1349 acl:0 sco:0 events:85 errors:0
TX bytes:2889 acl:0 sco:0 commands:85 errors:0
$ ifconfig wlan0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.111 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::a634:d9ff:fe6f:72e1 prefixlen 64 scopeid 0x20
ether a4:34:d9:6f:72:e1 txqueuelen 1000 (Ethernet)
RX packets 1356 bytes 136846 (136.8 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 556 bytes 114020 (114.0 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/5p, 480M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 3: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
$ lsusb
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 8087:0a2b Intel Corp.
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
$ lspci -nn
00:01.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:0fae] (rev a1)
00:02.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:0faf] (rev a1)
01:00.0 Network controller [0280]: Intel Corporation Wireless 8260 [8086:24f3] (rev 3a)
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
I’m working on a headless setup without any BT devices at hand, so sorry I cannot verify it for you.
