Hello, I have tried various methods of getting the V4L2 Backend functioning to no avail. Just thought I’d post my efforts, maybe helping others. I am however total linux novice, am surprised I even got so far TBH…
What I managed:
- Recompile kernel with uvcvideo loaded as a module (by default it is builtin)
- Recompile UVCVideo module with the patch applied as per librealsense documentation
- Apply said kernel and modules
- Compile librealsense (I did copy the src/ from jetsonhack's verson, as s/he had removed sse3 dependencies)
- Install and confirm it is loaded
Results:
When I plug in a R200:
dmesg shows:
[ 155.355061] usb 3-2: new SuperSpeed USB device number 7 using tegra-xhci
[ 155.382711] usb 3-2: New USB device found, idVendor=8086, idProduct=0a80
[ 155.382838] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 155.382933] usb 3-2: Product: Intel RealSense 3D Camera R200
[ 155.383022] usb 3-2: Manufacturer: Intel Corp
[ 155.383103] usb 3-2: SerialNumber: SN_2481011935
[ 155.397762] uvcvideo: Unknown video format 49323159-0000-0010-8000-00aa00389b71
[ 155.397902] uvcvideo: Unknown video format 20493859-0000-0010-8000-00aa00389b71
[ 155.398065] uvcvideo: Found UVC 1.10 device Intel RealSense 3D Camera R200 (8086:0a80)
[ 155.412721] uvcvideo: Unknown video format 2036315a-0000-0010-8000-00aa00389b71
[ 155.412799] uvcvideo: Found UVC 1.10 device Intel RealSense 3D Camera R200 (8086:0a80)
[ 155.415389] uvcvideo: Unable to create debugfs 3-7 directory.
[ 155.416728] input: Intel RealSense 3D Camera R200 as /devices/platform/tegra-xhci/usb3/3-2/3-2:1.2/input/input14
[ 155.424863] uvcvideo: Unknown video format 30315752-0000-0010-8000-00aa00389b71
[ 155.424954] uvcvideo: Found UVC 1.10 device Intel RealSense 3D Camera R200 (8086:0a80)
[ 155.427627] uvcvideo: Unable to create debugfs 3-7 directory.
[ 155.429017] input: Intel RealSense 3D Camera R200 as /devices/platform/tegra-xhci/usb3/3-2/3-2:1.4/input/input15
[ 155.487884] uvcvideo: Unknown video format 49323159-0000-0010-8000-00aa00389b71
[ 155.487896] uvcvideo: Unknown video format 20493859-0000-0010-8000-00aa00389b71
[ 155.487936] uvcvideo: Found UVC 1.10 device Intel RealSense 3D Camera R200 (8086:0a80)
[ 155.490536] systemd-udevd[2126]: Failed to apply ACL on /dev/video0: No such file or directory
[ 155.616228] uvcvideo: Unknown video format 2036315a-0000-0010-8000-00aa00389b71
[ 155.616409] uvcvideo: Found UVC 1.10 device Intel RealSense 3D Camera R200 (8086:0a80)
[ 155.619937] uvcvideo: Unable to create debugfs 3-7 directory.
[ 155.622699] input: Intel RealSense 3D Camera R200 as /devices/platform/tegra-xhci/usb3/3-2/3-2:1.2/input/input16
[ 155.746497] uvcvideo: Unknown video format 30315752-0000-0010-8000-00aa00389b71
[ 155.746688] uvcvideo: Found UVC 1.10 device Intel RealSense 3D Camera R200 (8086:0a80)
[ 155.750889] uvcvideo: Unable to create debugfs 3-7 directory.
[ 155.754255] input: Intel RealSense 3D Camera R200 as /devices/platform/tegra-xhci/usb3/3-2/3-2:1.4/input/input17
lsusb shows:
Bus 003 Device 007: ID 8086:0a80 Intel Corp.
At boot dmesg says about uvcvideo:
[ 6.898575] usbcore: registered new interface driver uvcvideo
And the final straw, when I run cpp-headless, or cpp-capture:
./cpp-headless
There are 1 connected RealSense devices.
Using device 0, an Intel RealSense R200
Serial number: 2481011935
Firmware version: 1.0.72.06
[ 490.172470] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 490.180668] pgd = ffffffc00007d000
[ 490.184137] [00000000] *pgd=000000017fc06003, *pmd=000000017fc07003, *pte=00e0000050041407
[ 490.192625] Internal error: Oops: 96000045 [#1] PREEMPT SMP
[ 490.198258] Enter nvdumper_crash_setup_regs
[ 490.202724] nvdumper: all registers are saved.
[ 490.202747] nvdumper: all registers are saved.
[ 490.202771] nvdumper: all registers are saved.
[ 490.216272] nvdumper: all registers are saved.
[ 490.220776] Modules linked in: bnep rfcomm bcmdhd cfg80211 nvhost_vi bluedroid_pm
[ 490.228696] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.10.67-rex+ #1
[ 490.235210] task: ffffffc0010f1870 ti: ffffffc0010e4000 task.ti: ffffffc0010e4000
[ 490.242788] PC is at uvc_video_clock_decode+0x108/0x190
[ 490.248088] LR is at uvc_video_clock_decode+0xf0/0x190
And the system crashes… It would appear that maybe I didn’t correctly patch uvcvideo, but i checked modinfo and it has loaded the one i compiled from the modified files. Gi diff reports:
diff --git a/arch/arm64/kernel/vdso32/Makefile b/arch/arm64/kernel/vdso32/Makefile
index 0c2bc73..0ef7c9a 100644
--- a/arch/arm64/kernel/vdso32/Makefile
+++ b/arch/arm64/kernel/vdso32/Makefile
@@ -11,7 +11,7 @@ obj-vdso32 := $(addprefix $(obj)/, $(obj-vdso32))
GCOV_PROFILE := n
-ccflags-y := -shared -fPIC -fno-common -fno-builtin -march=armv7-a
+ccflags-y := -shared -fPIC -fomit-frame-pointer -fno-common -fno-builtin -march=armv7-a
ccflags-y += -nostdlib -Wl,-soname=linux-vdso32.so.1 \
$(call cc-ldoption, -Wl$(comma)--hash-style=sysv)
asflags-y := -D__VDSO32__ -s
diff --git a/drivers/media/usb/uvc/uvc_driver.c b/drivers/media/usb/uvc/uvc_driver.c
index 363cdbf..3440ba9 100644
--- a/drivers/media/usb/uvc/uvc_driver.c
+++ b/drivers/media/usb/uvc/uvc_driver.c
@@ -108,6 +108,56 @@ static struct uvc_format_desc uvc_fmts[] = {
.fcc = V4L2_PIX_FMT_Y16,
+ .name = "Greyscale 8 L/R (Y8I)",
+ .guid = UVC_GUID_FORMAT_Y8I,
+ .fcc = V4L2_PIX_FMT_Y8I,
+ .name = "Greyscale 12 L/R (Y12I)",
+ .guid = UVC_GUID_FORMAT_Y12I,
+ .fcc = V4L2_PIX_FMT_Y12I,
+ .name = "Depth data 16-bit (Z16)",
+ .guid = UVC_GUID_FORMAT_Z16,
+ .fcc = V4L2_PIX_FMT_Z16,
+ .name = "Raw data 10-bit (RW10)",
+ .guid = UVC_GUID_FORMAT_RW10,
+ .fcc = V4L2_PIX_FMT_RW10,
+ .name = "Depth 16-bit (INVZ)",
+ .guid = UVC_GUID_FORMAT_INVZ,
+ .fcc = V4L2_PIX_FMT_INVZ,
+ .name = "Depth:IR 16:8 24-bit (INZI)",
+ .guid = UVC_GUID_FORMAT_INZI,
+ .fcc = V4L2_PIX_FMT_INZI,
+ .name = "Depth 16-bit (INVR)",
+ .guid = UVC_GUID_FORMAT_INVR,
+ .fcc = V4L2_PIX_FMT_INVR,
+ .name = "Depth:IR 16:8 24-bit (INRI)",
+ .guid = UVC_GUID_FORMAT_INRI,
+ .fcc = V4L2_PIX_FMT_INRI,
+ .name = "Infrared 8-bit (INVI)",
+ .guid = UVC_GUID_FORMAT_INVI,
+ .fcc = V4L2_PIX_FMT_INVI,
+ .name = "FlickerIR 8-bit (RELI)",
+ .guid = UVC_GUID_FORMAT_RELI,
+ .fcc = V4L2_PIX_FMT_RELI,
.name = "RGB Bayer",
.guid = UVC_GUID_FORMAT_BY8,
.fcc = V4L2_PIX_FMT_SBGGR8,
diff --git a/drivers/media/usb/uvc/uvcvideo.h b/drivers/media/usb/uvc/uvcvideo.h
index af505fd..4af23e7 100644
--- a/drivers/media/usb/uvc/uvcvideo.h
+++ b/drivers/media/usb/uvc/uvcvideo.h
@@ -91,6 +91,36 @@
#define UVC_GUID_FORMAT_Y16 \
{ 'Y', '1', '6', ' ', 0x00, 0x00, 0x10, 0x00, \
0x80, 0x00, 0x00, 0xaa, 0x00, 0x38, 0x9b, 0x71}
+#define UVC_GUID_FORMAT_Y8I \
+ { 'Y', '8', 'I', ' ', 0x00, 0x00, 0x10, 0x00, \
+ 0x80, 0x00, 0x00, 0xaa, 0x00, 0x38, 0x9b, 0x71}
+#define UVC_GUID_FORMAT_Y12I \
+ { 'Y', '1', '2', 'I', 0x00, 0x00, 0x10, 0x00, \
+#define UVC_GUID_FORMAT_Z16 \
+ { 'Z', '1', '6', ' ', 0x00, 0x00, 0x10, 0x00, \
+#define UVC_GUID_FORMAT_RW10 \
+ { 'R', 'W', '1', '0', 0x00, 0x00, 0x10, 0x00, \
+#define UVC_GUID_FORMAT_INVZ \
+ { 'I', 'N', 'V', 'Z', 0x90, 0x2d, 0x58, 0x4a, \
+ 0x92, 0x0b, 0x77, 0x3f, 0x1f, 0x2c, 0x55, 0x6b}
+#define UVC_GUID_FORMAT_INZI \
+ { 'I', 'N', 'Z', 'I', 0x66, 0x1a, 0x42, 0xa2, \
+ 0x90, 0x65, 0xd0, 0x18, 0x14, 0xa8, 0xef, 0x8a}
+#define UVC_GUID_FORMAT_INVR \
+ { 'I', 'N', 'V', 'R', 0x90, 0x2d, 0x58, 0x4a, \
+#define UVC_GUID_FORMAT_INRI \
+ { 'I', 'N', 'R', 'I', 0x90, 0x2d, 0x58, 0x4a, \
+#define UVC_GUID_FORMAT_INVI \
+ { 'I', 'N', 'V', 'I', 0xdb, 0x57, 0x49, 0x5e, \
+ 0x8e, 0x3f, 0xf4, 0x79, 0x53, 0x2b, 0x94, 0x6f}
+#define UVC_GUID_FORMAT_RELI \
+ { 'R', 'E', 'L', 'I', 0x14, 0x13, 0x43, 0xf9, \
+ 0xa7, 0x5a, 0xee, 0x6b, 0xbf, 0x01, 0x2e, 0x23}
#define UVC_GUID_FORMAT_BY8 \
{ 'B', 'Y', '8', ' ', 0x00, 0x00, 0x10, 0x00, \
@@ -100,7 +130,6 @@
#define UVC_GUID_FORMAT_M420 \
{ 'M', '4', '2', '0', 0x00, 0x00, 0x10, 0x00, \
#define UVC_GUID_FORMAT_H264 \
{ 'H', '2', '6', '4', 0x00, 0x00, 0x10, 0x00, \
diff --git a/drivers/platform/tegra/tegra21_clocks.c b/drivers/platform/tegra/tegra21_clocks.c
index 0a0584f..cf0e277 100644
--- a/drivers/platform/tegra/tegra21_clocks.c
+++ b/drivers/platform/tegra/tegra21_clocks.c
@@ -1062,7 +1062,7 @@ static struct clk_ops tegra_super_ops = {
static void tegra21_cpu_clk_init(struct clk *c)
- c->state = (!is_lp_cluster() == (c->u.cpu.mode == MODE_G)) ? ON : OFF;
+ c->state = ((!is_lp_cluster()) == (c->u.cpu.mode == MODE_G)) ? ON : OFF;
static int tegra21_cpu_clk_enable(struct clk *c)
diff --git a/drivers/usb/host/xhci-mem.c b/drivers/usb/host/xhci-mem.c
index 677f032..032b014 100644
--- a/drivers/usb/host/xhci-mem.c
+++ b/drivers/usb/host/xhci-mem.c
@@ -1436,8 +1436,9 @@ int xhci_endpoint_init(struct xhci_hcd *xhci,
break;
case USB_SPEED_HIGH:
/* Some devices get this wrong */
- if (usb_endpoint_xfer_bulk(&ep->desc))
- max_packet = 512;
+//Duo3D Kernel Patch, applied 13/05/2016
+ //if (usb_endpoint_xfer_bulk(&ep->desc))
+ // max_packet = 512;
/* bits 11:12 specify the number of additional transaction
* opportunities per microframe (USB 2.0, section 9.6.6)
diff --git a/include/uapi/linux/videodev2.h b/include/uapi/linux/videodev2.h
index 51f3740..2692503 100644
--- a/include/uapi/linux/videodev2.h
+++ b/include/uapi/linux/videodev2.h
@@ -401,6 +401,18 @@ struct v4l2_pix_format {
#define V4L2_PIX_FMT_VC1_ANNEX_L v4l2_fourcc('V', 'C', '1', 'L') /* SMPTE 421M Annex L compliant stream */
#define V4L2_PIX_FMT_VP8 v4l2_fourcc('V', 'P', '8', '0') /* VP8 */
+/* Intel RealSense-specific formats */
+#define V4L2_PIX_FMT_Y8I v4l2_fourcc('Y', '8', 'I', ' ') /* Greyscale 8-bit L/R interleaved */
+#define V4L2_PIX_FMT_Y12I v4l2_fourcc('Y', '1', '2', 'I') /* Greyscale 12-bit L/R interleaved */
+#define V4L2_PIX_FMT_Z16 v4l2_fourcc('Z', '1', '6', ' ') /* Depth data 16-bit */
+#define V4L2_PIX_FMT_RW10 v4l2_fourcc('R', 'W', '1', '0') /* Raw data 10-bit */
+#define V4L2_PIX_FMT_INVZ v4l2_fourcc('I', 'N', 'V', 'Z') /* 16 Depth */
+#define V4L2_PIX_FMT_INZI v4l2_fourcc('I', 'N', 'Z', 'I') /* 24 Depth/IR 16:8 */
+#define V4L2_PIX_FMT_INVR v4l2_fourcc('I', 'N', 'V', 'R') /* 16 Depth */
+#define V4L2_PIX_FMT_INRI v4l2_fourcc('I', 'N', 'R', 'I') /* 24 Depth/IR 16:8 */
+#define V4L2_PIX_FMT_INVI v4l2_fourcc('I', 'N', 'V', 'I') /* 8 IR */
+#define V4L2_PIX_FMT_RELI v4l2_fourcc('R', 'E', 'L', 'I') /* 8 IR alternating on off illumination */
/* Vendor-specific formats */
#define V4L2_PIX_FMT_CPIA1 v4l2_fourcc('C', 'P', 'I', 'A') /* cpia1 YUV */
#define V4L2_PIX_FMT_WNVA v4l2_fourcc('W', 'N', 'V', 'A') /* Winnov hw compress */
NOTE: Ignore the other diffs, they are from adding DuoMLX support (WIP) and just to get git to compile…
