Problem with IntelRealsense
Hi, I had compile and install librealsense on my jetson nano, firt i tried version 1.12.1, my realsense F200 works fine, but the SR300 can not get depth image, no error, just a blank image. then i tried version2, got an error like “The requested pixel format ‘INZI’ is not natively supported by the Linux kernel…”, how do i patch the kernel?
thanks
Hi rogercao0112,
We haven’t tested with Intel RealSense series cameras on Nano yet, you can refer to from this repo https://github.com/jetsonhacks/buildLibrealsense2TX to see if can help.
Look at this repository instead:
It is still a work in progress, but it’s pretty close. Having trouble identifying the D435i camera.
I’m writing a driver for the donkeycar robotics project. I’ve used https://github.com/JetsonHacksNano/installLibrealsense to install on nano. I used the installlibrealsense.sh script. Realsense-viewer worked well. demos worked well. The python code could not import pyrealsense2. Pip install pyrealsense2 did not work (could not find it). I rebuild from source, after which python code could import pyrealsense2; however the code could not connect to the camera - I have a Intel Realsense D435i. Error is:
File "realsense435i.py", line 68, in __init__
profile = pipeline.start(config)
RumtimeError: Couldn't resolve requests
This code runs find on my MSI gaming laptop running Ubuntu 18.04. See the code here:https://raw.githubusercontent.com/autorope/donkeycar/RealSense-part/donkeycar/parts/realsense435i.py
version I used is pasted below:
Author: Ed Murphy
File: realsense435i.py
Date: April 14 2019
Notes: Donkeycar part for the Intel Realsense depth cameras D435 and D435i.
import time
import logging
import numpy as np
import pyrealsense2 as rs
WIDTH = 424
HEIGHT = 240
CHANNELS = 3
class RealSense435i(object):
    The Intel Realsense D435i camera is a device which uses an imu, twin fisheye cameras,
    and an Movidius chip to stream a depth map along with an rgb image and optionally,
    accelerometer and gyro data (the 'i' variant has an IMU, the non-i variant does not)
    NOTE: this ALWAYS captures 424 pixels wide x 240 pixels high x RGB at 60fps.
          If an image width, height or depth are passed with different values,
          the the outputs will be scaled to the requested size on the way out.
    def __init__(self, width = WIDTH, height = HEIGHT, channels = CHANNELS, enable_rgb=True, enable_depth=True, enable_imu=False, device_id = None):
        self.device_id = device_id  # "923322071108" # serial number of device to use or None to use default
        self.enable_imu = enable_imu
        self.enable_rgb = enable_rgb
        self.enable_depth = enable_depth
        self.width = width
        self.height = height
        self.channels = channels
        self.resize = (width != WIDTH) or (height != height) or (channels != CHANNELS)
        if self.resize:
            print("The output images will be resized from {} to {}.  This requires opencv.".format((WIDTH, HEIGHT, CHANNELS), (self.width, self.height, self.channels)))
        # Configure streams
        self.imu_pipeline = None
        if self.enable_imu:
            self.imu_pipeline = rs.pipeline()
            imu_config = rs.config()
            if None != self.device_id:
                imu_config.enable_device(self.device_id)
            imu_config.enable_stream(rs.stream.accel, rs.format.motion_xyz32f, 63)  # acceleration
            imu_config.enable_stream(rs.stream.gyro, rs.format.motion_xyz32f, 200)  # gyroscope
            imu_profile = self.imu_pipeline.start(imu_config)
        self.pipeline = None
        if self.enable_depth or self.enable_rgb:
            self.pipeline = rs.pipeline()
            # if we are provided with a specific device, then enable it
            if self.enable_depth:
                config.enable_stream(rs.stream.depth, 848, 480, rs.format.z16, 60)  # depth
            if self.enable_rgb:
                config.enable_stream(rs.stream.color, 424, 240, rs.format.bgr8, 60)  # rgb
            # Start streaming
            profile = self.pipeline.start(config)
            # Getting the depth sensor's depth scale (see rs-align example for explanation)
                depth_sensor = profile.get_device().first_depth_sensor()
                depth_scale = depth_sensor.get_depth_scale()
                print("Depth Scale is: ", depth_scale)
                if self.enable_rgb:
                    # Create an align object
                    # rs.align allows us to perform alignment of depth frames to others frames
                    # The "align_to" is the stream type to which we plan to align depth frames.
                    align_to = rs.stream.color
                    self.align = rs.align(align_to)
        time.sleep(1)   # let camera warm up
        # initialize frame state
        self.color_image = None
        self.depth_image = None
        self.acceleration_x = None
        self.acceleration_y = None
        self.acceleration_z = None
        self.gyroscope_x = None
        self.gyroscope_y = None
        self.gyroscope_z = None
        self.frame_count = 0
        self.start_time = time.time()
        self.frame_time = self.start_time
    def _poll(self):
        last_time = self.frame_time
        self.frame_time = time.time() - self.start_time
        self.frame_count += 1
        # get the frames
        try:
            if self.enable_rgb or self.enable_depth:
                frames = self.pipeline.wait_for_frames(200 if (self.frame_count > 1) else 10000) # wait 10 seconds for first frame
            if self.enable_imu:
                imu_frames = self.imu_pipeline.wait_for_frames(200 if (self.frame_count > 1) else 10000)
        except Exception as e:
            logging.error(e)
            return
        # convert camera frames to images
            # Align the depth frame to color frame
            aligned_frames = self.align.process(frames) if self.enable_depth and self.enable_rgb else None
            depth_frame = aligned_frames.get_depth_frame() if aligned_frames is not None else frames.get_depth_frame()
            color_frame = aligned_frames.get_color_frame() if aligned_frames is not None else frames.get_color_frame()
            # Convert images to numpy arrays
            self.depth_image = np.asanyarray(depth_frame.get_data()) if self.enable_depth else None
            self.color_image = np.asanyarray(color_frame.get_data()) if self.enable_rgb else None
            if self.resize:
                import cv2
                if self.width != WIDTH or self.height != HEIGHT:
                    self.color_image = cv2.resize(self.color_image, (self.width, self.height), cv2.INTER_NEAREST) if self.enable_rgb else None
                    self.depth_image = cv2.resize(self.depth_image, (self.width, self.height), cv2.INTER_NEAREST) if self.enable_depth else None
                if self.channels != CHANNELS:
                    self.color_image = cv2.cvtColor(self.color_image, cv2.COLOR_RGB2GRAY) if self.enable_rgb else None
        # output imu data as discrete values in the same order as the Mpu6050 code
        # so we can be compatible with any other parts that consume imu data.
        if self.enable_imu:
            acceleration = imu_frames.first_or_default(rs.stream.accel, rs.format.motion_xyz32f).as_motion_frame().get_motion_data()
            self.acceleration_x = acceleration.x
            self.acceleration_y = acceleration.y
            self.acceleration_z = acceleration.z
            gyroscope = imu_frames.first_or_default(rs.stream.gyro, rs.format.motion_xyz32f).as_motion_frame().get_motion_data()
            self.gyroscope_x = gyroscope.x
            self.gyroscope_y = gyroscope.y
            self.gyroscope_z = gyroscope.z
            logging.debug("imu frame {} in {} seconds: \n\taccel = {}, \n\tgyro = {}".format(
                str(self.frame_count),
                str(self.frame_time - last_time),
                str((self.acceleration_x, self.acceleration_y, self.acceleration_z)),
                str((self.gyroscope_x, self.gyroscope_y, self.gyroscope_z))))
    def update(self):
        When running threaded, update() is called from the background thread
        to update the state.  run_threaded() is called to return the latest state.
        while self.running:
            self._poll()
    def run_threaded(self):
        Return the lastest state read by update().  This will not block.
        All 4 states are returned, but may be None if the feature is not enabled when the camera part is constructed.
        For gyroscope, x is pitch, y is yaw and z is roll.
        :return: (rbg_image: nparray, depth_image: nparray, acceleration: (x:float, y:float, z:float), gyroscope: (x:float, y:float, z:float))
        return self.color_image, self.depth_image, self.acceleration_x, self.acceleration_y, self.acceleration_z, self.gyroscope_x, self.gyroscope_y, self.gyroscope_z
    def run(self):
        Read and return frame from camera.  This will block while reading the frame.
        see run_threaded() for return types.
        self._poll()
        return self.run_threaded()
    def shutdown(self):
        self.running = False
        time.sleep(0.1)
        if self.imu_pipeline is not None:
            self.imu_pipeline.stop()
        if self.pipeline is not None:
            self.pipeline.stop()
# self test
if __name__ == "__main__":
    show_opencv_window = False # True to show images in opencv window: note that default donkeycar environment is not configured for this.
    if show_opencv_window:
        import cv2
    enable_rgb = True
    enable_depth = True
    enable_imu = True
    device_id = None
    width = 212
    height = 120
    channels = 3
    profile_frames = 0 # set to non-zero to calculate the max frame rate using given number of frames
    try:
        # for D435i, enable_imu can be True, for D435 enable_imu should be false
        camera = RealSense435i(
            width=width, height=height, channels=channels,
            enable_rgb=enable_rgb, enable_depth=enable_depth, enable_imu=enable_imu, device_id=device_id)
        frame_count = 0
        frame_time = start_time
        while True:
            # read data from camera
            color_image, depth_image, acceleration_x, acceleration_y, acceleration_z, gyroscope_x, gyroscope_y, gyroscope_z = camera.run()
            # maintain frame timing
            frame_count += 1
            last_time = frame_time
            if enable_imu and not profile_frames:
                print("imu frame {} in {} seconds: \n\taccel = {}, \n\tgyro = {}".format(
                    str(frame_count),
                    str(frame_time - last_time),
                    str((acceleration_x, acceleration_y, acceleration_z)),
                    str((gyroscope_x, gyroscope_y, gyroscope_z))))
            # Show images
            if show_opencv_window and not profile_frames:
                cv2.namedWindow('RealSense', cv2.WINDOW_AUTOSIZE)
                if enable_rgb or enable_depth:
                    # make sure depth and color images have same number of channels so we can show them together in the window
                    if 3 == channels:
                        depth_colormap = cv2.applyColorMap(cv2.convertScaleAbs(depth_image, alpha=0.03), cv2.COLORMAP_JET) if enable_depth else None
                    else:
                        depth_colormap = cv2.cvtColor(cv2.applyColorMap(cv2.convertScaleAbs(depth_image, alpha=0.03), cv2.COLORMAP_JET), cv2.COLOR_RGB2GRAY) if enable_depth else None
                    # Stack both images horizontally
                    images = None
                    if enable_rgb:
                        images = np.hstack((color_image, depth_colormap)) if enable_depth else color_image
                    elif enable_depth:
                        images = depth_colormap
                    if images is not None:
                        cv2.imshow('RealSense', images)
                # Press esc or 'q' to close the image window
                key = cv2.waitKey(1)
                if key & 0xFF == ord('q') or key == 27:
                    cv2.destroyAllWindows()
                    break
            if profile_frames > 0:
                if frame_count == profile_frames:
                    print("Aquired {} frames in {} seconds for {} fps".format(str(frame_count), str(frame_time - start_time), str(frame_count / (frame_time - start_time))))
                    break
            else:
                time.sleep(0.05)
    finally:
        camera.shutdown()
Unfortunately the forum doesn’t support markdown. You need to use the “code” bb tags.
Update: If I don’t pass config for the pipeline (so everything is defaults), then it will work. If I use any config, even with values that match defaults, it does not work correctly; it fails trying to start the pipeline. It would be great to have an early check for valid config values and fail with a clear message if config is not valid for the camera/library. Again, this code all works on my gaming pc running ubuntu 18.04, but not on Jetson Nano running 18.04. librealsense 2.31 and 2.32 both had this problem on nano.
