I have installed SR300 sdk on jetson AGX xavier and while using the camera to check the streams (without running any codes) the streams are like slow motion and have about 1 0r 2 seconds delay. when I run code on the realtime streams of camera, the delay gets worst, very slow. how can I fix it? since I want to use my code and camera for real time detection.
Please execute sudo nvpmodel -m 0 and sudo jetson_clocks and try again. It is max performance mode.
All modes are listed in
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fpower_management_jetson_xavier.html%23wwpID0E0NO0HA
instead of this solution (max performance mode), is there any other way to fix that issue?
Thx
I checked your solution but there is not much difference! The improvement is not considerable. is there any other way or solution to this issue?
and how can I check/be sure that max performance mode is activated now and is working?
There is a discussion about D455:
Realsense D455 cannot get 90FPS video frames on the Xaiver AGX
Please take a look and see if you can apply it to SR300. The RealSenses requires additional drivers and some driver packages help improve performance.
I have actualy asked two question. what is the answer to my second question? how can I be sure that I have already activated max performance mode?
You can take a look at power modes:
and tegrastats Utility:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2FAppendixTegraStats.html%23
