Hello!
Is there any way to publish ros2 message PointCloud2 with intensity data?
Hello!
Hi @555kd - you can publish PointCloud2 messages with intensity data in Isaac Sim using the ROS2 bridge. The Isaac Sim provides a ROS2 bridge that allows you to publish and subscribe to ROS2 topics directly from the simulation environment.
Here is a general process:
omni.isaac.range_sensor
extension. The Lidar sensor will generate point cloud data with intensity information.omni.isaac.ros2_bridge
extension. You will need to create a ROS2 Publish Point Cloud node in the Action Graph.sensor_prim_path
property of the node to the path of the Lidar sensor in the stage.https://docs.omniverse.nvidia.com/isaacsim/latest/tutorial_ros2_rtx_lidar.html
Yes, I have already tried this.
ROS2 Publish Point Cloud node doesn’t publish intensity data.
I need a message contain XYZ and intensity fields.
This would be most likely resolved in the upcoming release in September
There’s still no way of publishing of intensity data using ROS2 Publish Point Cloud? I was also trying to make it work with Isaac Create Render Product + Isaac Compute RTX Lidar Point Cloud + ROS2 Publish Point Cloud, but with no sucess
Hello!
I did this by writing my own ros node that runs asynchronously in my standalone application, receives the “pointCloudData” and “intensity” attributes from Isaac’s “Compute RTX Lidar Point Cloud” node and then publishes PointCloud2 message.
@555kd could you share an example of this?
First of all you need to create ROS2 publisher:
import numpy as np
from omni.isaac.core.utils.prims import is_prim_path_valid
import omni.graph.core as og
from rclpy.node import Node
import sensor_msgs.msg as sensor_msgs
import std_msgs.msg as std_msgs
from builtin_interfaces.msg._time import Time
from astropy.coordinates import spherical_to_cartesian
PCL2_TOPIC_HZ = 10
RENDER_PATH = "/Render/PostProcess/SDGPipeline/"
class PCDPublisher(Node):
def __init__(self):
super().__init__('pcd_publisher_node')
self.points = np.array([[1, 1, 1, 1]]) # [x,y,z,i]
self.time = Time()
self.pcd_publisher = self.create_publisher(sensor_msgs.PointCloud2, '/lidar_points', 10)
timer_period = PCL2_TOPIC_HZ # 10 hz
self.timer = self.create_timer(timer_period, self._lidar_callback)
def _lidar_callback(self):
if is_prim_path_valid(RENDER_PATH + "RenderProduct_Isaac_RtxSensorCpuIsaacComputeRTXLidarPointCloud"):
lidar_compute_node_path = RENDER_PATH + "RenderProduct_Isaac_RtxSensorCpuIsaacComputeRTXLidarPointCloud"
for i in range(1,10):
if is_prim_path_valid(RENDER_PATH + f"RenderProduct_Isaac_0{i}_RtxSensorCpuIsaacComputeRTXLidarPointCloud"):
lidar_compute_node_path = RENDER_PATH + f"RenderProduct_Isaac_0{i}_RtxSensorCpuIsaacComputeRTXLidarPointCloud"
# receiving lidar data from Isaac
r_arr = og.Controller().node(lidar_compute_node_path).get_attribute("outputs:range").get()
lat_arr = og.Controller().node(lidar_compute_node_path).get_attribute("outputs:elevation").get()
lon_arr = og.Controller().node(lidar_compute_node_path).get_attribute("outputs:azimuth").get()
x_arr, y_arr, z_arr = spherical_to_cartesian(r_arr, lat_arr, lon_arr)
cartesian_arr = np.column_stack((x_arr.value, y_arr.value * (-1), z_arr.value))
intensity_from_isaac = og.Controller().node(lidar_compute_node_path).get_attribute("outputs:intensity").get()
# adding intensity in [x,y,z]
self.points = np.column_stack((cartesian_arr, intensity_from_isaac))
ros_time = self.get_clock().now().to_msg()
self.time = ros_time
self.pcd = self._create_point_cloud(self.points, self.time, 'base_scan')
self.pcd_publisher.publish(self.pcd)
def _create_point_cloud(self, points, time, parent_frame):
""" Creates a point cloud message.
Args:
points: Nx4 array of xyz positions and intensity data.
parent_frame: frame in which the point cloud is defined
Returns:
sensor_msgs/PointCloud2 message
ros_dtype = sensor_msgs.PointField.FLOAT32
dtype = np.float32
itemsize = np.dtype(dtype).itemsize # A 32-bit float takes 4 bytes.
data = points.astype(dtype).tobytes()
fields = [
sensor_msgs.PointField(name='x', offset=0, datatype=ros_dtype, count=1),
sensor_msgs.PointField(name='y', offset=4, datatype=ros_dtype, count=1),
sensor_msgs.PointField(name='z', offset=8, datatype=ros_dtype, count=1),
sensor_msgs.PointField(name='intensity', offset=12, datatype=ros_dtype, count=1),
header = std_msgs.Header(stamp=time, frame_id=parent_frame)
return sensor_msgs.PointCloud2(
header=header,
height=1,
width=points.shape[0],
is_dense=True,
is_bigendian=False,
fields=fields,
point_step=(itemsize * 4), # Every point consists of four float32s.
row_step=(itemsize * 4 * points.shape[0]),
data=data
Then you need to create async task for compute node due Isaac Sim is running
async def my_task_lidar():
publisher = PCDPublisher()
while rclpy.ok():
rclpy.spin_once(publisher)
await asyncio.sleep(0.05)
publisher.unregister()
publisher = None
Finally you need to start node:
frame = 0
while simulation_app.is_running():
if frame==48:
asyncio.ensure_future(my_task_lidar())
simulation_context.step(render=True)
frame = frame + 1
simulation_context.stop()
simulation_app.close()
@555kd thanks so much for the response, in the end I did something similar but it was slow and hard to get the intensities to match the real sensor. I’m not sure what your application is but I just set the intensity values to zero in my training data and used only xyz for each point. This means it matches the real world data much more easily and also it did not affect the precision of my detector.
