Supplies of the Industrial module are tight. We have origionally designed for the industrial, but want to switch to the 64Gb today. I want to confirm is the pin mappings for the Jetson AGX Orin 64Gb and Industrial are identical?
Based on the provided context, I can confirm that the Jetson AGX Orin 64GB and Industrial modules share the same reference carrier board, which is the Jetson AGX Orin reference carrier board (P3737-0000). This suggests that the pin mappings for both modules are likely to be identical.
However, to provide a more comprehensive answer, I would like to highlight the following points:
- Both modules are listed as compatible with the same carrier board (P3737-0000), which implies that they share the same pinout and interface.
- The context does not provide any information that suggests the pin mappings for the Industrial module are different from the 64GB module.
- The fact that both modules can be used with the same carrier board and have the same flash configuration (QSPI-NOR and eMMC) further supports the idea that their pin mappings are identical.
That being said, it is always a good idea to verify the pin mappings and interface specifications for both modules to ensure compatibility and avoid any potential issues. I recommend consulting the official documentation and technical specifications for both modules to confirm their pin mappings and interface details.
In summary, based on the provided context, it appears that the pin mappings for the Jetson AGX Orin 64GB and Industrial modules are identical. However, it is always a good idea to verify this information through official documentation and technical specifications to ensure compatibility and avoid any potential issues.
Yes, they are pin and form-factor compatible.
